vkmagik 1st Gear May 21, 2017 Share May 21, 2017 (edited) I am driving Proton EXORA (Year 2009 model) Front Door - 2 x speaker [1 left / 1 right] Rear Door - 2 x speaker [1 left / 1 right] Wanted to change speaker Reasons: during Head Unit installation at Malaysia Feedback my Right side door area no sound So mechanics open up to check, saw existing speaker Rusty - including the contact at speaker end Offer RM450 to change 4 x MOHAWK - but I declined as no time, urgently went back Singapore to fetch my kids Saw item @ MY Lazada http://www.lazada.com.my/mohawk-plug-amp-play-oem-speaker-for-honda-city-front-amprear-13115501.html?spm=a2o4k.brand-54815.0.0.Iw3yCh&ff=1&sc=MR/W&rb=54815&boost=3 Went to MUSTAFA - saw Pioneer model TS-A1676S [Max Ouput up to 320W] Per set (2) @ $42.50, cheap and good Thinking of buying 2 set to install @ my Front and Read Door - is it OK to install 4 x Coaxial Speaker? Will there by any problem? Asking for opinion from Experts as me still newbie *Paiseh as looking for item Cheap - as long as can use, I am satisfied already - Kindly excuse if asking such noob question + no money to buy High End Stuff Edited May 22, 2017 by Lightsabre ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Jtb 6th Gear May 21, 2017 Share May 21, 2017 speakers bundled with head unit then no probem speakers from elsewhere not the same brand, just make sure it matches the impedance or else just dont turn on the volume loud is fine! 1 Link to post Share on other sites More sharing options...
Othello Supersonic May 21, 2017 Share May 21, 2017 definitely will be better than stock, but I'm not sure whether the HU can support 4 speakers properly Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 21, 2017 Share May 21, 2017 Pls know ur head unit wattage. Next ensure spkrs minimum wattage requirements match ur head unit one. Lastly, get spkrs with high sensitivity of at least 90bB. No issue with 4 coaxials. I'm even using a pair of component spkrs in front wo tweeter cos gonna handover my ride next mth. They sound perfectly fine n clearer than spkrs in similar price range wo amp. Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear May 21, 2017 Share May 21, 2017 Using my Pioneer unit as a comparison, I ran them direct without amplifier. The recommended power for speaker to handle is around 250 W Link to post Share on other sites More sharing options...
vkmagik 1st Gear May 22, 2017 Author Share May 22, 2017 (edited) Just check, using Head Unit Sansui SA-2100 ... Any speaker expert to advice? I do want later HU BURNT Edited May 22, 2017 by vkmagik Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear May 22, 2017 Share May 22, 2017 Nominal is 50w. no issue for stock unit just that might to to turn up the volume slightly higher then ur stock speakers.... Link to post Share on other sites More sharing options...
vkmagik 1st Gear June 7, 2017 Author Share June 7, 2017 Nominal is 50w. no issue for stock unit just that might to to turn up the volume slightly higher then ur stock speakers.... Ok, noted ... shall get those normal type instead of high wattage Else later burnt out, more headache Thanks for advice ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato speakers spoilt. Advise pls
Speaker Tan Chuan-Jin, MP Cheng Li Hui resign
Xtremez Audio - Your Choice for Audio Installation & Upgrade
New Proton Perdona.
New Proton Perdona.
Is a subwoofer necessary?
