Stone-Cold 1st Gear May 22, 2017 Share May 22, 2017 I don't like the stock rim, but don't mind keeping the size for FC/comfort... Should I consider change rim but keep the size and use back tyre? Anyone done such move before? ↡ Advertisement Link to post Share on other sites More sharing options...
Icetee168 3rd Gear May 22, 2017 Share May 22, 2017 it really depends on the size of the rims u r getting...u might think that the size old rims r the same as your new rims like 17", 18' n etc but one has the consider the width of the rims as well which goes like 7JJ, 8JJ n etc unless u dun mind the looks of an overstretch tires which also constitutes a safety concern...further there r offset of the rims that u need to consider otherwise u might b getting rims that rub on your fenders...better to seek expert advice or do some research first...2 cents Link to post Share on other sites More sharing options...
Stone-Cold 1st Gear May 22, 2017 Author Share May 22, 2017 it really depends on the size of the rims u r getting...u might think that the size old rims r the same as your new rims like 17", 18' n etc but one has the consider the width of the rims as well which goes like 7JJ, 8JJ n etc unless u dun mind the looks of an overstretch tires which also constitutes a safety concern...further there r offset of the rims that u need to consider otherwise u might b getting rims that rub on your fenders...better to seek expert advice or do some research first...2 centsWhat you mean is must make sure the tyre match the new rim right? Google search found the tyre and rim come together: 225/65r17, 7jx17 et39 or 6.5jx17 et39 Link to post Share on other sites More sharing options...
Macrosszero Turbocharged May 23, 2017 Share May 23, 2017 Sure, why not? You're just after a different look for your car. Go for it as your budget permits. 1 Link to post Share on other sites More sharing options...
Stone-Cold 1st Gear May 23, 2017 Author Share May 23, 2017 Just did some search, really difficult to find the rim with this dimension 7jx17 et39 or 6.5jx17 et39 Especially the et39. All many inset 45... is et39=inset 39? (Sorry for noob question) Any website link can compare rim? Many discussed on compare tyre on rim, but not the other way round. Thank you for looking at all these noob question. Link to post Share on other sites More sharing options...
flashbang Turbocharged May 23, 2017 Share May 23, 2017 Just did some search, really difficult to find the rim with this dimension 7jx17 et39 or 6.5jx17 et39 Especially the et39. All many inset 45... is et39=inset 39? (Sorry for noob question) Any website link can compare rim? Many discussed on compare tyre on rim, but not the other way round. Thank you for looking at all these noob question. Yes it is. If you can't find the exact one, might be possible to find one similar. Slight differences might still be able to fit, depending on your car. Link to post Share on other sites More sharing options...
Mkl22 Twincharged May 23, 2017 Share May 23, 2017 Just did some search, really difficult to find the rim with this dimension 7jx17 et39 or 6.5jx17 et39 Especially the et39. All many inset 45... is et39=inset 39? (Sorry for noob question) Any website link can compare rim? Many discussed on compare tyre on rim, but not the other way round. Thank you for looking at all these noob question. What car? Better to get 17x7.5. 225/45r17 fits well and plenty of such a size in the market. Please don't choose odd rims sizes which restrict your tire choice. Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 24, 2017 Share May 24, 2017 I don't like the stock rim, but don't mind keeping the size for FC/comfort... Should I consider change rim but keep the size and use back tyre? Anyone done such move before? Yes. Me. Link to post Share on other sites More sharing options...
Stone-Cold 1st Gear May 24, 2017 Author Share May 24, 2017 OK, thank you all! Input appreciated. Now is the time to look for the rim to replace. One last question, would workshop/PI use this change of wheel to void warranty? Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 24, 2017 Share May 24, 2017 OK, thank you all! Input appreciated. Now is the time to look for the rim to replace. One last question, would workshop/PI use this change of wheel to void warranty? I dont think so if you stick to manufacturer's recommended rims and tyres specifications which are indicated in the manual or at door frame. Link to post Share on other sites More sharing options...
Cypher 4th Gear May 25, 2017 Share May 25, 2017 (edited) I dont think so if you stick to manufacturer's recommended rims and tyres specifications which are indicated in the manual or at door frame.Correct me if I'm wrong. Nowadays manufacturer only specify one tyre size unlike in the past where they provide a few sizes at the door frame. So where do we get the correct specification which will not void the warranty? Edited May 25, 2017 by Cypher Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 25, 2017 Share May 25, 2017 Correct me if I'm wrong. Nowadays manufacturer only specify one tyre size unlike in the past where they provide a few sizes. So where do we get the correct specification which will not void the warranty? From my current car's manual : From my current car's door frame : Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 25, 2017 Share May 25, 2017 OK, thank you all! Input appreciated. Now is the time to look for the rim to replace. One last question, would workshop/PI use this change of wheel to void warranty? standard warranty T & C anything other than Original specification or Parts , they can void your Warranty. So long you follow the Original specification like tire size (some car make does provide Optional tire size) refer to Owners handbook or Tire pressure label. frankly speaker not all Parts like wheels came with your new car are Factory fitted (not Original) , But approved but your Car Seller. should you want to upsize your wheels or tires ,I will go for better Quality / Premium brand so they have no reason to void. Just MHO . Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 25, 2017 Share May 25, 2017 From my previous korean car manual : Link to post Share on other sites More sharing options...
Cypher 4th Gear May 25, 2017 Share May 25, 2017 (edited) @Adrianli Thanks for the info. At the end of the day we really are at the ADs mercy aren't we.. when it comes to warranty.. Edited May 25, 2017 by Cypher Link to post Share on other sites More sharing options...
walkofwinners 4th Gear May 25, 2017 Share May 25, 2017 Why not respray the rim for <$150 since rims are for aesthetic pleasure at the end of the day. Can get 2nd hand ones from workshops at around <$300 too. Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 25, 2017 Share May 25, 2017 Why not respray the rim for <$150 since rims are for aesthetic pleasure at the end of the day. Can get 2nd hand ones from workshops at around <$300 too. I changed due to brake dust. Multi spokes, very difficult to clean. Five spokes only, very easy to clean. Multi spokes Five spokes 1 Link to post Share on other sites More sharing options...
Mason016 Supersonic May 25, 2017 Share May 25, 2017 I changed due to brake dust. Multi spokes, very difficult to clean. Five spokes only, very easy to clean. Multi spokes Five spokes My A6 Avant 009.jpg Haha, looks like its true. The more sui the rim, the more difficult to clean. Your previous multi spoke very sui! Fits your car to the T. ↡ Advertisement Link to post Share on other sites More sharing options...
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
