Mustank Hypersonic July 30, 2017 Share July 30, 2017 No more delivery slot and $20 ↡ Advertisement Link to post Share on other sites More sharing options...
Kusje Supersonic July 30, 2017 Share July 30, 2017 I personally find them OK, won't leak but won't keep a charge as good as Eneloop. Not sure if it's just me or my charger.Buy the more expensive ones. They are eneloops in disguise. Link to post Share on other sites More sharing options...
Kb27 Supersonic July 30, 2017 Share July 30, 2017 Any good/bad experience with those battery? Will leak? Rechargeables very seldom leak, unlike primary batteries like alkaline. AmazonBasics rechargeables is rumoured to be eneloop oem. Some people did some testing and found the results very close. However, I had a couple of AmazonBasics that becomes 0V and could not charge in the standard charger. So i took a DC power supply, set it to 2V and zap the battery a few times. After that it can charge normally, no need to throw away. 2 Link to post Share on other sites More sharing options...
Raubern 6th Gear July 30, 2017 Share July 30, 2017 How to be amazon prime driver? can use own car to deliver? Link to post Share on other sites More sharing options...
Kklee 6th Gear July 30, 2017 Share July 30, 2017 I personally find them OK, won't leak but won't keep a charge as good as Eneloop. Not sure if it's just me or my charger. Thanks for the feedback. As long as don't leak, hold slightly less charge also nevermind. Rechargeables very seldom leak, unlike primary batteries like alkaline. AmazonBasics rechargeables is rumoured to be eneloop oem. Some people did some testing and found the results very close. However, I had a couple of AmazonBasics that becomes 0V and could not charge in the standard charger. So i took a DC power supply, set it to 2V and zap the battery a few times. After that it can charge normally, no need to throw away. Eh.. i oso don't want them to leak. I have IKEA LADDA AAs and AAAs leaking. The AAAs, never even open up from the packaging already leaked. Maybe give them a try. You zap them + to + and - to - or + to - ? Link to post Share on other sites More sharing options...
Mustank Hypersonic July 30, 2017 Share July 30, 2017 Leaking is bad Leak until whole thing soak with the green stuff Things spoil That's why whole house things use only the no leak eneloop Leaking is bad Leak until whole thing soak with the green stuff Things spoil That's why whole house things use only the no leak eneloop Link to post Share on other sites More sharing options...
Ender Hypersonic July 30, 2017 Author Share July 30, 2017 Got my items from them today. They use a freelancer. Probably doing it after office hour. Link to post Share on other sites More sharing options...
Kusje Supersonic July 30, 2017 Share July 30, 2017 Read the NLee the engineer reviews for these 2 batteries. Highly likely they are just rebranded eneloops based on tests. But they also have another model which is cheaper and made in China so better read the reviews first to be sure you are getting what you want. AmazonBasics AA High-Capacity Rechargeable Batteries (8-Pack) Pre-charged - Packaging May Vary https://www.amazon.com/dp/B00HZV9WTM/ref=cm_sw_r_cp_apa_opEFzb9N8RQNB AmazonBasics AA High-Capacity Rechargeable Batteries (8-Pack) Pre-charged - Packaging May Vary https://www.amazon.com/dp/B00HZV9WTM/ref=cm_sw_r_cp_apa_opEFzb9N8RQNB Link to post Share on other sites More sharing options...
Kb27 Supersonic July 30, 2017 Share July 30, 2017 Thanks for the feedback. As long as don't leak, hold slightly less charge also nevermind. Eh.. i oso don't want them to leak. I have IKEA LADDA AAs and AAAs leaking. The AAAs, never even open up from the packaging already leaked. Maybe give them a try. You zap them + to + and - to - or + to - ? Always use rechargeables where you can't afford them to leak. Like remote controls, flashlights, or devices you seldom use. When you use alkaline, use it where you are likely to find leakage, before it gets too bad. I lost a flashlight bcuz an alkaline battery leaked so badly that it's stuck in the tube.of the flashlight. Yeah, zap + to +. Amazonbasic rechargeables are good. Get the high capacity ones. They cost about $3 a piece. If you buy standard eneloop, say from Mustafa, it's about $5 a piece. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic July 30, 2017 Share July 30, 2017 Another battery I'm using is the 14500. This one comes with the safer LiFePo4 chemistry which doesn't blow up and explode like the regular LiCo https://www.aliexpress.com/item/Super-2pcs-Etinesan-3-2v-1500mAh-14500-AA-LiFePo4-lithium-rechargeable-battery-with-dummy-fake-battery/32536275078.html?ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10084_10083_10080_10307_10082_10081_10110_10137_10175_10111_10060_10112_10113_10155_10114_10154_10056_10055_10054_10310_10312_10059_100031_10099_10078_10079_10103_10073_10102_10052_10053_10142_10107_10050_10051-10050,searchweb201603_16,ppcSwitch_5&btsid=ba1831bb-1c07-4259-b12a-fa74db7314a4&algo_expid=21745724-ea35-425c-802b-c7b5c1d4e847-16&algo_pvid=21745724-ea35-425c-802b-c7b5c1d4e847 The charge is at a lower 3.2V (instead of 3.7V for LiCo). So if you connect a dummy (or short circuit) in series, it looks like 2 AA size battery in series, about 3V Link to post Share on other sites More sharing options...
Kklee 6th Gear July 30, 2017 Share July 30, 2017 Always use rechargeables where you can't afford them to leak. Like remote controls, flashlights, or devices you seldom use. When you use alkaline, use it where you are likely to find leakage, before it gets too bad. I lost a flashlight bcuz an alkaline battery leaked so badly that it's stuck in the tube.of the flashlight. Yeah, zap + to +. Amazonbasic rechargeables are good. Get the high capacity ones. They cost about $3 a piece. If you buy standard eneloop, say from Mustafa, it's about $5 a piece. Already converted to rechargeables.... more devices, need to get more ! I likely get Eneloops but will try Amazonbasics. Another battery I'm using is the 14500. This one comes with the safer LiFePo4 chemistry which doesn't blow up and explode like the regular LiCo https://www.aliexpress.com/item/Super-2pcs-Etinesan-3-2v-1500mAh-14500-AA-LiFePo4-lithium-rechargeable-battery-with-dummy-fake-battery/32536275078.html?ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10084_10083_10080_10307_10082_10081_10110_10137_10175_10111_10060_10112_10113_10155_10114_10154_10056_10055_10054_10310_10312_10059_100031_10099_10078_10079_10103_10073_10102_10052_10053_10142_10107_10050_10051-10050,searchweb201603_16,ppcSwitch_5&btsid=ba1831bb-1c07-4259-b12a-fa74db7314a4&algo_expid=21745724-ea35-425c-802b-c7b5c1d4e847-16&algo_pvid=21745724-ea35-425c-802b-c7b5c1d4e847 The charge is at a lower 3.2V (instead of 3.7V for LiCo). So if you connect a dummy (or short circuit) in series, it looks like 2 AA size battery in series, about 3V Eh... more stuffs to buy.... Link to post Share on other sites More sharing options...
Mustank Hypersonic July 31, 2017 Share July 31, 2017 The Lazada like machiam no more credit card discount liao Link to post Share on other sites More sharing options...
Lala81 Hypersonic July 31, 2017 Share July 31, 2017 The Lazada like machiam no more credit card discount liao Safra got a small discount. but think must be first few per month to get it. Link to post Share on other sites More sharing options...
Kusje Supersonic July 31, 2017 Share July 31, 2017 The Lazada like machiam no more credit card discount liao Got la. It's right there on the front page. Everyday also have. Link to post Share on other sites More sharing options...
Mockngbrd Supersonic July 31, 2017 Share July 31, 2017 No more visa promo, don't want buy liao... Pui Link to post Share on other sites More sharing options...
Lotr 6th Gear July 31, 2017 Share July 31, 2017 The Lazada like machiam no more credit card discount liao still have ... standard chartered, citibank, uob . going to try the standard chartered discount later Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 2, 2017 Share August 2, 2017 http://www.straitstimes.com/singapore/transport/cabbies-private-hire-drivers-cannot-do-courier-jobs-lta Taxi drivers and private-hire drivers are not allowed to be couriers or deliverymen for goods if there is no passenger on board, the Land Transport Authority (LTA) said yesterday. In response to queries from The Straits Times, an LTA spokesman said: "Under our regulations, taxis and private-hire cars are meant to carry passengers for hire and reward, and cannot be used solely for the conveyance of goods. "However, passengers who hire a taxi or a private-hire car are allowed to carry goods with them." LTA was unable to comment immediately on the penalties for infringement, or if anyone has been taken to task yet. Get The Straits Times newsletters in your inboxSIGN UP ComfortDelGro, the biggest taxi company here, confirmed its drivers have taken jobs from delivery companies such as Amazon Prime, but maintained that the goods are always accompanied by a passenger. Drivers, however, said this was not always the case. Cabby Henry Tay, 48, said: "Previously, there was a fear that what we delivered would be contraband or drugs. But now, with an established company like Amazon, we feel it is quite safe. "The taxi business is getting slow, so cabbies need to do something to supplement their earnings." amazon29.jpg Related Story Amazon hires more drivers to meet demand Private-hire driver Tan Ee Hsing, 41, said he has not done any deliveries himself, but has helped direct some 200 drivers to Adecco, Amazon's hiring agent here. "The rates these delivery companies pay are generally higher than what drivers make from passenger fares," he said. Premier Taxi managing director Lim Chong Boo said: "We remind our drivers that they are not allowed to perform courier services without anyone on board." However, he said it was "very difficult" for the authorities to enforce regulations, given that there are about 26,000 taxis and more than 40,000 chauffeured private- hire cars here. Prime Taxi chairman Neo Nam Heng said the courier business helps drivers optimise capacity during the off-peak hours between 10am and 4pm. "I have encouraged all the drivers of my fleet of 1,500 taxis to take up such bookings," he said. Housewife C.N. Yeo, 51, said she has had purchases delivered to her home by a Comfort taxi driver. Amazon could not respond by press time yesterday. Lazada, which also owns online grocer RedMart, said it does not use taxis or private-hire cars for deliveries. • Additional reporting by Tiffany Fumiko Tay 1 Link to post Share on other sites More sharing options...
RadX Moderator August 2, 2017 Share August 2, 2017 our LTA really knee jerk and not prepared for the new economy...wtf...this oso want to regulate and control Come on lah, Amazon giving jobs and keeping these ppl employed.... ↡ Advertisement 2 Link to post Share on other sites More sharing options...
