  • 1
  • Search this thread
  • Reply to this topic
16 replies to this topic | 20 praises
#1
Posted 17 August 2017 - 11:18 AM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
Need some advice regarding tires.
I have the 2 tire size options, either a 285/25 or 265/30.
285/25 has only a 1% difference to my current wheels overall diameter but due to the low profile, load rating is only 95 (690kg)
265/30 has only a 3% difference to my current wheels overall diameter but due to the higher profile/sidewall, load rating is 97 (730kg)
Is 285 too wide for a 9.5J rim? I'm going to fit this on a 2ton MPV so not sure if load rating 95 is going to cut it.
#2
Posted 17 August 2017 - 11:36 AM
Unfair
  • Premium member
    Unfair
    6th Gear
    Author Image
    2,523
Check the min load rating for your vehicle.
If you tend to drive f&f, take the 285/25.
Pepi18022009 (For Fifa14/GTA V)
#3
Posted 17 August 2017 - 01:48 PM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
So from your point of view, safety comes first right?
So will a 285 be too wide on a 9.5J rim?
#4
Posted 17 August 2017 - 03:05 PM
Unfair
  • Premium member
    Unfair
    6th Gear
    Author Image
    2,523
Sorry I am not an expert on this.
I have the view that more traction is better.
Edited by Unfair, 17 August 2017 - 03:07 PM.
#5
Posted 17 August 2017 - 03:14 PM
Enye
  • Enye
    2Fast2Furious
    Author Image
    57,864
my mpv is "only" 1.8 ton kerb weight and it is already specced with load rating 98 XL tires
on a separate note, i cannot imagine what your FC would be like on 22" rims....3-4km/l?
[sweatdrop]
Edited by Enye, 17 August 2017 - 03:16 PM.
Pinobii, Pocy and Newbie26 praised this
#6
Posted 17 August 2017 - 03:33 PM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
[sweatdrop]
On the contrary, I have these wheels on my SUV now. Before upsizing, I was having 8km/L. After upsize, I'm getting 7.5km/L
This is still acceptable to me. I have driven worst at 7km/L on previous cars.
I did check the Gross Vehicle Weight of my MPV which is at 2600kg. Assuming load rating 95 is 690kg which makes a total of 2760kg. This is 160kg more than the max rating of the vehicle. Only issue is I'm not sure how 285 will sit on a 9.5J rim
#7
Posted 17 August 2017 - 03:41 PM
Mkl22
  • Mkl22
    Author Image
    8,720
check out tirerack
https://www.tirerack...romCompare1=yes
could only find one tire for 285/25/R22. which is pirelli. seems that 265/30/R22 is an exact fit. 285 needs a 10.5 in wheel. 285/25 might be too thin to allow a range of rims widths. it states only 10.5 and nothing else
#8
Posted 17 August 2017 - 04:40 PM
Unfair
  • Premium member
    Unfair
    6th Gear
    Author Image
    2,523
2600kg + 5 x 75kg passengers = 2975kg.
2975kg / 4 = 743.75kg load.....
Careful your insurance gets voided during claims
#9
Posted 17 August 2017 - 05:24 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,688
285 definitely too wide for your 9.5 inch
265 is just acceptable to me
good that you are concern about this tire issue
another issue to look up is the Wheels that you are putting in ?
If one worry about Safety , Wheels Quality is First thing to look into before your tires , And I believe the 22inch   size is quite limited here.
by the way can share the MPV you are referring and wheels size ?
Edited by Roberttan, 17 August 2017 - 05:25 PM.
#10
Posted 17 August 2017 - 05:33 PM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
Think you are wrong.
Gross is the weight rating
Curb weight is weight of the car without passengers. My MPV is rated at 2075kg. Lets give it 2100kg which means I'm left with 500kg to the max rating of 2600kg. Makes me wonder how 500kg can accommodate 7 person....
I have been using this rim for years so quality should not be an issue.
Getting an Alphard soon.
Roberttan praised this
#11
Posted 17 August 2017 - 10:35 PM
Chucky2007
  • Premium member
    Chucky2007
    NOS-ed
    Author Image
    12,007
How many ponies does your 2 ton MPV have? If nothing more than 250 horse.. go for 265/30-22 which is just nice wide enough to wrap 9.5j rims. 285 maybe the tyres will bear hug the rims?
有❤️就好👌
多做少说,多听👂少讲
做人吃点亏,莫占人便宜
#12
Posted 19 August 2017 - 11:26 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
I dont know what MPV you drive but 25 profile tyres would be quite harsh on SG roads I think.
Rule of thumb for tyre width to rim width is just take rim width x 25.4 (1 inch is 25.4mm) and the wheel should be at least as wide as the rim.
#13
Posted 20 August 2017 - 06:19 PM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
Getting the 3rd Gen Alphard soon
#14
Posted 16 September 2017 - 11:19 PM
Qaz20
  • Premium member
    Qaz20
    3rd Gear
    Author Image
    307
Actually 285 should fit into a 9.5jj rims. I had 275 on a 9.5jj it looks pretty ok, but it about the max it can go. Am on 19" thou. 1 of the tyre shop had made mistake before by installing my 275/30 tyres on my 8.5jj front rims. And it fits.. Just look a little fatter.
Btw, am on staggered setup
#15
Posted 17 September 2017 - 12:15 PM
Woes
  • THREAD STARTER
  • Premium member
    Woes
    1st Gear
    Author Image
    79
This how my 265 R22 rim looks like on my Alphard. It is a bit protruding from the fender. Time to get new rubbers
#16
Posted 17 September 2017 - 06:20 PM
Chucky2007
  • Premium member
    Chucky2007
    NOS-ed
    Author Image
    12,007
Wow big bad ass shiny rims 👍🏻
有❤️就好👌
多做少说,多听👂少讲
做人吃点亏,莫占人便宜
#17
Posted 19 September 2017 - 11:58 AM
Ahbengdriver
  • Ahbengdriver
    Supercharged
    Author Image
    5,735
I used 265cm on a 9.5J rim before, but it was a 19 inch rim.
I think you could go up to 285 on a 9.5J but what for?
I am looking for another word other than "disgusting" to describe 4.62 minion but bcos I neber pass my PSLE, the only word I know is "KNNBCBB"
  • 1
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Chip Soon Auto Pte Ltd
Chip Soon Auto Pte Ltd  |  Rating   Submit Review
Reviewed by Anglerso  |  Neutral Newbie
Sales enquiry is good, detail breakdown of costs.
Mechanic is good, good knowledge. Although i am not technically convinced on the wear and tear of rotor disc.
Price is reasonable. For changing brake pad and rotor disc.
Main thing is fast job, send in at around 1145am, job done by 1230pm. Not wasting time like in C&C. » Read More
Tyre Track & Accessories Trading
Tyre Track & Accessories Trading  |  Rating   Submit Review
Reviewed by Defelio  |  3rd Gear
I had gotten my rims with lower inset and ask the them whether could I use their place to roll my fenders( I have the rolling fender tool) while they swap out the tyres onto the new rims. Borrow a power extension for the heatgun and also was advised on how to roll the fender. They didn't rush me at all during the whole process!
A previous experience which they... » Read More
Related Motor Directory search on sgCarMart.com : Tyres & Rims
Quick Reply
Tags: toyota, toyotaupsize, rim, mpv and 3 more...
