Ash2017 Twincharged June 2, 2018 Share June 2, 2018 Gresat review and your pictures are tok kong. No wonder upgrade to be moderator. Hope you are not eyeing the CEO's job. I bought a 15000mAh battery pack but the most it can be used for is 5L. It is bigger than the H1. I seriously doubt if H1 can be used for a 7L. My personal advice, dont seal in a ziploc bag, the battery pack needs to breath, otherwise sooner or later you will get a very pregnant battery pack keep it away from the sun and heat, fastest way to kill the battery pack if buy spend a bit more on a good brand dont want the pack to explore and make you even more ugly always but one model higher that is if your car is <1L then buy a battery pack that can start up a 2L car, you will appreciate this when the battery pack deteriorates over time also make sure you have this feature: reverse cable protection (otherwise your carpark may experience the biggest bond fire yet) sometimes when you have a very flat battery, despite using the battery pack, it will not start, most people will wait and press the ignition button again, the real solution is remove the battery pack and clamps and reapply again after a few minutes, there appears to be some memory issue, I have witness this I stop using all these other brand car battery and have installed only the Panasonic CAOS Pro maintenance free car battery in my cars. They were recommended to by authorized agent. Never look back. A bit more expensive but can leave the car without moving for more than 4-6weeks still can drive off without any issue. OK, here is my long overdue review of the Hummer H1 Power Bank Jump Starter. @vratenza, @Mercury1, @discoburg, @mersaylee, @nzy, @dach 1) What is it? It is a multi-function car battery jump starter of an excellent military quality, high configuration and high performance, all in a compact package. 2) How compact it is? Everything fit into the compact casing (205mm (L) x 155mm (W) x 75mm (D)), and the full set weighing just 1.16Kg (the 15,000 mAh power bank weigh 515g, 175mm x 83mm x 28mm). 3) What is in the package? Top: 3 pin AC charger, 12V cigarette lighter socket charger, 12V cigarette lighter socket adapter, micro USB cable Bottom: Sparkless jump start cable, user guide, 15,000mAh power bank, casing 4) What can be found on the power bank? Front and back: Power button, battery life indicator, LED (torch light) on/off button and jump start instructions Side: AC/14V input, 12V output (cigarette lighter socket adapter), 12V jump starter socket, 1.1A & 2.1A USB port, and LED light. 5) How to charge the power bank? The power back may be charged using either the provided 3 pin charger or 14V cigarette lighter socket charger. 6) What are it functions? Jump start kit for vehicle up to 7.0L engine capacity It can be used to charge your mobile phone, power your in-car camcorder, and even run an ionizing purifier, all at one go! I can use it to power my in-car camcorder and ionizing purifier even when my engine is switch off. The good: - Compact and light weight (ease of storage) - Multi-functional power bank with useful accessories - Allow operating / charging of multiple portable devices at one go - Power bank has built-in safety features to prevent short-circuit when using the jump start cable The no so good: - Pricey (recommended retail price at S$288) Would I recommend this product to others? YES ↡ Advertisement 10 Link to post Share on other sites More sharing options...
DACH Supersonic June 2, 2018 Author Share June 2, 2018 I agree. If really have to keep this battery packs in the car, make sure it doesn't become a fire hazard. Especially if you always park in the open car park, best is not keep it in the car. Link to post Share on other sites More sharing options...
DACH Supersonic June 2, 2018 Author Share June 2, 2018 Special coke bought from 7-Eleven. 2 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 3, 2018 Share June 3, 2018 Loots for today. 4 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged June 3, 2018 Share June 3, 2018 Loot for the day from Cold Storage Interest Fruit from NZ 5 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged June 3, 2018 Share June 3, 2018 Loot for the day from Cold Storage Interest Fruit from NZ Interesting * Link to post Share on other sites More sharing options...
Ender Hypersonic June 3, 2018 Share June 3, 2018 Ownself reply to ownself Interesting * 3 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged June 3, 2018 Share June 3, 2018 Interesting *It was typo error. It shld be the word “ interesting. “and not “interest” I am not replying to my own posting. Clarify Link to post Share on other sites More sharing options...
Volvobrick Supersonic June 3, 2018 Share June 3, 2018 NZ's version of 刺参. 2 Link to post Share on other sites More sharing options...
Jman888 Moderator June 4, 2018 Share June 4, 2018 Loot this on impulse at special price, probably end up as white elephant. 2 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 4, 2018 Share June 4, 2018 Give me 3 Link to post Share on other sites More sharing options...
Ash2017 Twincharged June 4, 2018 Share June 4, 2018 Loot for the day from Cold Storage Interest Fruit from NZ can imagine if someone use this as suppository 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic June 4, 2018 Share June 4, 2018 You have very vivid imagination......worried for you can imagine if someone use this as suppository 2 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 4, 2018 Share June 4, 2018 My most recent loot Huawei P20 Pro No picture 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic June 4, 2018 Share June 4, 2018 Loot this on impulse at special price, probably end up as white elephant. rps20180604_100400.jpg Can 自编自导自演 1 Link to post Share on other sites More sharing options...
DACH Supersonic June 4, 2018 Author Share June 4, 2018 Loot this on impulse at special price, probably end up as white elephant. rps20180604_100400.jpg Looks like Thor's hammer. Link to post Share on other sites More sharing options...
Freeder Hypersonic June 4, 2018 Share June 4, 2018 Special coke bought from 7-Eleven. 41607033925_c3fb086192_k.jpg Special drink after piak piak 5 Link to post Share on other sites More sharing options...
DACH Supersonic June 4, 2018 Author Share June 4, 2018 Special drink after piak piak ↡ Advertisement Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
KSL City shopping mall in JB
Any good buy at Daiso?
Where can get big-size lady's court shoes?
Capital 21 - largest mall in JB
Shopping Malls Offering Vouchers For Shopping With Them
