hpmf1978 Neutral Newbie September 1, 2017 Share September 1, 2017 anybody changed to a normal battery and has no problem. I changed mine to amaron, i realise the voltage keep on reducing until I have problem cranking, I already discon my camera but still the same. some people recommend should use efb battery for vezel. just want to hear from the people here, do u use normal battery and has no problem? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kopites Supersonic September 2, 2017 Share September 2, 2017 anybody changed to a normal battery and has no problem. I changed mine to amaron, i realise the voltage keep on reducing until I have problem cranking, I already discon my camera but still the same. some people recommend should use efb battery for vezel. just want to hear from the people here, do u use normal battery and has no problem? 3 months now..normal battery still working fine. Anyway all batteries should come with one year warranty. After one year than worry s about battery flat.. Link to post Share on other sites More sharing options...
hpmf1978 Neutral Newbie September 2, 2017 Share September 2, 2017 3 months now..normal battery still working fine. Anyway all batteries should come with one year warranty. After one year than worry s about battery flat.. mine last for 5 months then the hard to crank behaviour start to surface. I checked my cteck monitor, actually it is already at very low level for months. I cannot be very sure that this is battery problem. just want to hear from the people here who is using normal amaron battery and has no problem for more than 5 months. Link to post Share on other sites More sharing options...
therock Supersonic September 2, 2017 Share September 2, 2017 mine last for 5 months then the hard to crank behaviour start to surface. I checked my cteck monitor, actually it is already at very low level for months. I cannot be very sure that this is battery problem. just want to hear from the people here who is using normal amaron battery and has no problem for more than 5 months. Do you use the start-stop function? Do you go for long rides or merely drive short journeys? Park mode enabled? Charge your phone and other items in the car? Switch off the engine and listen to the radio / CD? Vacuum your car? Dilly dally after the engine is switched off leaving the lights on for prolonged periods? Link to post Share on other sites More sharing options...
hpmf1978 Neutral Newbie September 2, 2017 Share September 2, 2017 Do you use the start-stop function? Do you go for long rides or merely drive short journeys? Park mode enabled? Charge your phone and other items in the car? Switch off the engine and listen to the radio / CD? Vacuum your car? Dilly dally after the engine is switched off leaving the lights on for prolonged periods? i always off the start stop function. i drive only 15 mins to and back from work. I dont do all those funny stuff, i even off the camera to test. i agree i dont drive much so the charging is not much. but then, why will the battery drain so much without anything using it? I am wondering if vezel really cannot use this amaron normal battery or need to change to efb kind? 1 Link to post Share on other sites More sharing options...
Andyngps 5th Gear September 2, 2017 Share September 2, 2017 (edited) i always off the start stop function. i drive only 15 mins to and back from work. I dont do all those funny stuff, i even off the camera to test. i agree i dont drive much so the charging is not much. but then, why will the battery drain so much without anything using it? I am wondering if vezel really cannot use this amaron normal battery or need to change to efb kind? Its the charge. Very common. Normal battery also ok one. Edited September 2, 2017 by Andyngps Link to post Share on other sites More sharing options...
hpmf1978 Neutral Newbie September 2, 2017 Share September 2, 2017 Its the charge. Very common. Normal battery also ok one.but the engine start is really not smooth when it is low in charge Link to post Share on other sites More sharing options...
Kopites Supersonic September 2, 2017 Share September 2, 2017 (edited) mine last for 5 months then the hard to crank behaviour start to surface. I checked my cteck monitor, actually it is already at very low level for months. I cannot be very sure that this is battery problem. just want to hear from the people here who is using normal amaron battery and has no problem for more than 5 months.Is your battery a replacement or stock from PI? If former reckon you can give the supplier/workshop a call. Check still under any warranty? If later straight go get a new battery. Edited September 2, 2017 by Kopites Link to post Share on other sites More sharing options...
Andyngps 5th Gear September 3, 2017 Share September 3, 2017 but the engine start is really not smooth when it is low in chargeQuite common too. But do give your main battery a check. Link to post Share on other sites More sharing options...
therock Supersonic September 3, 2017 Share September 3, 2017 Quite common too. But do give your main battery a check.Is there a secondary battery in a Vezel? Link to post Share on other sites More sharing options...
Raubern 6th Gear September 3, 2017 Share September 3, 2017 Is this rim and tyre specs ok for Honda Vezel? Will the wheel protrude out? 18 x 8 offset 40 225/50/18 1 Link to post Share on other sites More sharing options...
Andre1288 1st Gear September 5, 2017 Share September 5, 2017 Quite common too. But do give your main battery a check.What do you mean by common? When my vezel battery is low and charging I get a knock when pulling off or coming to a stop. It only happens when the battery is charging. You're saying this is normal? 1 Link to post Share on other sites More sharing options...
Cypher 4th Gear September 11, 2017 Share September 11, 2017 I bought from taobao...Possible to post link here or PM me if not possible. Thanks. 1 Link to post Share on other sites More sharing options...
Magical26 Neutral Newbie September 12, 2017 Share September 12, 2017 (edited) Hi Vezel owners, i have recently bought a Vezel X (with Honda Sensing) from SG Car Choice due to the recent drop in COE. Car will only be delivered in mid November. My question is... will the car electronics be in English or Japanese? I read that all Vezel from P.I are in Japanese language (unless you buy from this P.I called Motorland). Is this true? If it is really in Japanese, anyway to change it to English? Thanks in advance to any Vezel owners out there who are willing to assist with a reply, appreciate it. Edited September 12, 2017 by Magical26 1 Link to post Share on other sites More sharing options...
Hweehim Neutral Newbie September 13, 2017 Share September 13, 2017 All Vezel display will be in Japanese. same for the manual. doesnt matter which PI you buy from. No way to change to English. There is a english manual in the vezel facebook, can always refer to that. 1 Link to post Share on other sites More sharing options...
Magical26 Neutral Newbie September 14, 2017 Share September 14, 2017 All Vezel display will be in Japanese. same for the manual. doesnt matter which PI you buy from. No way to change to English. There is a english manual in the vezel facebook, can always refer to that. Hi bro, but when i check with some of my friends who bought from other P.I, theirs are in English. Why is that so? Attached are some pictures sent to me vs the Jap version. Anyone know why the difference, or how to change it? 1 Link to post Share on other sites More sharing options...
Tutc Neutral Newbie September 15, 2017 Share September 15, 2017 Hi bro, but when i check with some of my friends who bought from other P.I, theirs are in English. Why is that so? Attached are some pictures sent to me vs the Jap version. Anyone know why the difference, or how to change it? Your 2 photos are from different cars - the 1st one is a petrol HRV/Vezel. The 2nd one is a hybrid Vezel. So cannot compare them like that. 1 Link to post Share on other sites More sharing options...
Magical26 Neutral Newbie September 15, 2017 Share September 15, 2017 Your 2 photos are from different cars - the 1st one is a petrol HRV/Vezel. The 2nd one is a hybrid Vezel. So cannot compare them like that. If that is the case, can i assume that non-hybrid will be like the one in the pic (without jap), and only those that are hybrid comes with the Jap text in the dashboard? Cos it was earlier mentioned that all Vezels are PI and comes with the Jap text in the dashboard. So which are the ones that has English version like the picture? ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
