  • 1
  • Search this thread
  • Reply to this topic
15 replies to this topic | 41 praises
#1
Posted 05 October 2017 - 06:29 PM
carloverguy2017
  • THREAD STARTER
  • carloverguy2017
    5th Gear
    Author Image
    1,830
Shark Fin Antenna DIY installation in 3 minutes
Super easy to install.
Cheap to buy.
Up your Ricerboy status by +5.5 points
Atrecord, Tianmo, BabyBlade, pChou and 1 Anonymous member praised this
It's PNE ! PLay Not Enough lah...
#2
Posted 05 October 2017 - 07:40 PM
Volvobrick
  • Volvobrick
    2Fast2Furious
    Author Image
    24,726
Frankly i find it quite ugly.... I hate the fat one on my car.
Some of my previous cars had antenna integrated into the rear windscreen giving a totally clean look.  Reception was no worse.  Now that is good engineering design.
kykh praised this
#3
Posted 06 October 2017 - 11:28 AM
carloverguy2017
  • THREAD STARTER
  • carloverguy2017
    5th Gear
    Author Image
    1,830
To each his own because stick antenna looks OK to me too.
Internal antenna also nice to have.
But I already have an antenna mounting built onto the roof of the car which ccost a lot of money to remove and patch it up, paint etc.
The Shark Fin antenna, I would say, its a 5.5 out of 10 satisfaction, thus my joke on the +5.5 points for RicerBoy status.
But the stock antenna looks like 3.5 to me due to its helical wrapped style around the rubbery flexi rod, which is slanted to one side due to rubber material. I hated that Helical coil look of the stock.
#4
Posted 06 October 2017 - 12:22 PM
Heman75
  • Premium member
    Heman75
    Supercharged
    Author Image
    5,890
bro an advise. generally you should not peel the liner for the 3M tape off 100% as your fingers will be touching the sticky surface while handling . this is no good for the surface as contaminants are transfer to it reducing the effectiveness of the stickiness. you should peel of the liner abit , align on the plastic fin and slowling peel of while sticking on the fin as you press on the fin. for the car sticking is ok as you wont touch the sticky side since you are holding to the fin. just my few cents for you.
Fuelsaver and Vratenza praised this
#5
Posted 09 October 2017 - 10:25 PM
Atrecord
  • Premium member
    Atrecord
    2Fast2Furious
    Author Image
    35,613
Cheap to buy.
How much did you pay for the shark fin antenna?
I wanted to get one for my Tucson, but the stockists here don't carry it, and even M'sia doesn't have it. One stockist brought one in but said that it doesn't fit the roof of the car perfectly, so they stopped selling it.
#6
Posted 12 October 2017 - 11:58 PM
carloverguy2017
  • THREAD STARTER
  • carloverguy2017
    5th Gear
    Author Image
    1,830
I bought from Wish Online Store.
Yes it doesn't fit perfectly.
Just DIY and notice a little gap due to curvature of the car roof doesn't match.
But Im OK with the gap for now.
$5 only.
#7
Posted 13 October 2017 - 03:02 PM
BabyBlade
Good job on the video, no matter how simple the job is.
So keep the DIY car videos coming!
I like my hair messy, my life high, and my soul wild.
#8
Posted 13 October 2017 - 03:19 PM
Atrecord
  • Premium member
    Atrecord
    2Fast2Furious
    Author Image
    35,613
$5 only.
wah $5 only.  [thumbsup]
I checked the original one for tucson costs upwards of $200...
#9
Posted 13 October 2017 - 05:51 PM
Xers007
  • Premium member
    Xers007
    Supercharged
    Author Image
    6,823
 Tao Bao sure have but only if u have order from there b4 if not a bit of research to do... if not try asking in the tucson group in facebook...
back to the same old days ...
#10
Posted 13 October 2017 - 06:04 PM
Fuelsaver
  • Premium member
    Fuelsaver
    Author Image
    7,969
Concorde auto along jln lembeh kallang selling 40$ for j's racing sharking ant, provided it match ur ant base
I've used Tom before. Reception on pat w stock
FS
#11
Posted 15 October 2017 - 10:53 PM
carloverguy2017
  • THREAD STARTER
  • carloverguy2017
    5th Gear
    Author Image
    1,830
Looks simple but I am betting 5 out of 10 don't have a clue to do any simple DIY
#12
Posted 16 October 2017 - 01:30 PM
Vratenza
  • Premium member
    Vratenza
    2Fast2Furious
    Author Image
    49,462
A few suggestions:
1) use some masking tape or blue painter's tape with a measuring tape to find and mark the final. position of the shark fin before peeling the sticker backings.
2) clean the surface thoroughly with alcohol to remove any debris/car wax
3) use 3M tape primer to prep the surface to ensure maximum adhesion.
4) before even installing the sharkfin, place it on and check for fitment (eg.  curvature fitment) before going ahead with the DIY.  $5 product, can just write it off as a wrong cheap online purchase.
Edited by Vratenza, 16 October 2017 - 01:47 PM.
Pocy praised this
Circles Life Referral Code: HTWWD
#13
Posted 16 October 2017 - 01:48 PM
Arogab
  • Premium member
    Arogab
    5th Gear
    Author Image
    1,920
Sharkfins......delicious. Haha.
#14
Posted 16 October 2017 - 04:30 PM
Tjkbeluga
  • Premium member
    Tjkbeluga
    Supercharged
    Author Image
    7,067
When I first got my car, my car's antenna hot swapped by some SOB. So I decided to change to sharkfin antenna.
Latio Premium Sedan
#15
Posted 17 January 2018 - 12:13 AM
ckiat
  • Premium member
    ckiat
    Author Image
    1
Hi, anyone experienced poor reception when the shark fin antenna is put in place? The reception is good when the shark fin is tangling. Any solution? Thanks in advance.
#16
Posted 10 February 2018 - 11:08 AM
Hyde
  • Hyde
    Author Image
    14
Any tips on removing a sharkfin as the painting dropped, planning to replace new sharkfin?
  • 1
Back to Cosmetics  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: shark fin, antenna and 5 more...
