  • 1
  • Search this thread
  • Reply to this topic
9 replies to this topic | 20 praises
#1
Posted 26 October 2017 - 10:22 AM
Kombahbao
  • THREAD STARTER
  • Premium member
    Kombahbao
    Clutched
    Author Image
    49
Tried searching the forum and the discussions were very old (10 years back!)
Would want to add a 12V socket (or 2 sockets, depends on cost and complexity) at the car boot area - anyone done it before? Any recommendation on workshops that can do it nicely?
TIA!
Tianmo praised this
#2
Posted 01 January 2018 - 09:42 AM
Bluemint
  • Premium member
    Bluemint
    2nd Gear
    Author Image
    135
Been doing it for almost all my cars without one in the boot.
I get something like this and have it flush mounted.  Because the primary purpose is to use my wired car vacuum cleaner, one of two outlet is wired directly to the battery.  The other is wired to turn on/off with the engine.
TB20N0feFXXXXaQXXXXXXXXXXXX-2258915412.g
Here's the relevant search in TaoBao:  https://s.taobao.com...earch?&q=点烟器 改装
Every installer will have no trouble installing it for you.  My regular installer is JK Audio in Sembawang.
Kombahbao and 2 Anonymous members praised this
#3
Posted 01 January 2018 - 04:03 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,201
may i know how much does JK Audio charge for the labor fee for this installation? I am planning to install one behind too for my car.
How is their workmanship? Are wiring all conceal nicely? I understand the is a need to drill hold on the plastic panel?
#4
Posted 01 January 2018 - 04:37 PM
Bluemint
  • Premium member
    Bluemint
    2nd Gear
    Author Image
    135
I don't know his rate, as I usually have a few things to install.  What I can say is like all the reviews on JK -- reasonable pricing & good workmanship.
http://www.sgcarmart...s.php?MID=10572
I've know him for over 8 years.  He's still the same highly experienced, hardworking, no-nonsense, one-man-show, who is still operating at the same location since I know him!
He's usually busy, so don't expect to just drop in and get things done right away, unless you're very lucky, but make a prior appointment, ok?
Meet him once and you'll know he's a trustworthy nice guy.
I'll be terribly disappointed when he retires.
#5
Posted 01 January 2018 - 04:47 PM
Bluemint
  • Premium member
    Bluemint
    2nd Gear
    Author Image
    135
TB29_ikbXXXXXcRXXXXXXXXXXXX_!!105668917.
BTW, this is the one I last had.  It's a real cigarette lighter that I can use as a 12V power point too.  A non-cigarette lighter option costs less because it does not need to withstand the heat generated.
I've picked this because I can have it mounted on the supporting shelf of my hatch cover, simply with 2 screws instead of boring a whole.
Oh to answer your question on exposed wiring....  If it's inevitable due to installation, JK will conceal the wiring with a black flexible trunking one; don't worry.
Edited by Bluemint, 01 January 2018 - 04:59 PM.
#6
Posted 01 January 2018 - 04:52 PM
Wildfaye29
  • Wildfaye29
    5th Gear
    Author Image
    1,898
outstanding recommendation, i may need to install sockets in my car too.
does he install lights too? i would like to have some red or white light at the rear wheel arc to aim rearwards to aid in reversing in dark carparks - to wire up with the reverse lamp.
#7
Posted 01 January 2018 - 05:15 PM
Bluemint
  • Premium member
    Bluemint
    2nd Gear
    Author Image
    135
Of course he does.
Sounds like a relatively simple wiring job to me, although I have never had wiring that went outside the car.  JK will advise you on potential water leakage and maybe rust corrosion on your car body panels.
I should add JK does not carry much accessories in stock but car audio systems.  He install my Air Purifier from TaoBao.  Fantastic workmanship eh?   [bounce2]
#8
Posted 04 January 2018 - 10:24 AM
Kombahbao
  • THREAD STARTER
  • Premium member
    Kombahbao
    Clutched
    Author Image
    49
Many thanks for this!!!
Will go check with JK
#9
Posted 07 January 2018 - 09:48 AM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,201
bro kombabao, if you managed to install kindly share what is the labour cost to install. thanks.
#10
Posted 21 January 2018 - 08:50 AM
Bluemint
  • Premium member
    Bluemint
    2nd Gear
    Author Image
    135
For those of you who don't know how to shop in TaoBao, you can get above in Lazada.sg too.
https://www.lazada.s...=empire 12v car
  • 1
Back to Accessories  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: 12v, socket, cabling, adding and 3 more...
