  • 1
  • Search this thread
  • Reply to this topic
16 replies to this topic | 20 praises
#1
Posted 07 November 2017 - 03:02 PM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
NEUTO™ Dry Hydrogen Auto Therapy™ is the world first Hydrogen Dry Cleaning System that can effectively DIAGNOSE, PRESCRIBE, MONITOR and CLEAN the car engine with pure and dry Hydrogen Gas stored in the Solid State Metal Hydride Canister. It is exclusively invented for vehicles running on Internal Combustion Engines. NEUTO™ THERAPY™ removes stubborn micro molecular carbon layers at hard to reach places like air manifolds, piston rings, valves, and spark plugs without causing any damage to the car engine wall and components in the engine. NEUTO™ Dry Hydrogen Auto Therapy™ can naturally cleanse the car engine in the most sustainable organic way.
Green and Organic
Hydrogen is one part of the hydrocarbon molecules present in the fuel and it has higher heat capacity than carbon atom. When hydrogen gas enters the car engine compartment via vacuum inlet manifolds, it chemically reacts with the carbon deposits to form hydrocarbons such as Methane gas. Hydrogen reverses the carbonization process and improves the combustion efficiency close to perfection. The end products of the complete combustion are carbon dioxide and water vapor. This is a green and organic way to better clean the engine by converting the carbon deposits into hydrocarbons that get burnt away with no other pollutants or harmful byproducts to the environment.
Safe and Effective
Hydrogen gas is stored in the Solid State Metal Hydride Canister. Metal hydride storage technology produces 100% dry and 99.9999% purity hydrogen gas. It has the highest hydrogen mass density at room temperature and much lower storage pressure compared to highly pressurize compressed gas tank and freezing temperature cryogenic hydrogen storage cylinder. Safety is never compromised. High purity of hydrogen gas also means that NEUTO™ THERAPY™ can effectively clean your car engine to breathe new life within 20 to 30 minutes of the process duration.
Restore and Revive
No two cars are exactly alike even with the same make of brand and model. Every car has different technologies, engine capacities, traveling mileages and most dynamically every human driver is uniquely different with his/her own driving habits and behaviors. NEUTO™ THERAPY™ world first patented iEGA technology tailors every treatment for your car engine with precise control of dry hydrogen gas amount released at calibrated flow rate and optimal process duration. When the carbon deposits are effectively removed, car engine performance is restored and revived to its former glory. Symptoms of bad carbon buildups such as rough cold start, unpleasant engine noises and vibrations during idling or premature detonation conditions will improve significantly. You can expect maximum drivability performance in torque power and fuel efficiency improvement by 10-20% statistically. Due to varied engine technology used, capacity, mileage traveled and the unique characteristic of the driver habits and behaviors, no two cars is the same. Our first in the world patented iEGA technology customized treatment tailored to your car at the right hydrogen flow rate within an optimum duration defined. The Best Engine Doctor you could ever have Restore and Revive We care for you and your car.
___________________________________________________________________________________________________________________________
Awards:
Singapore Apex Corporate Sustainability Awards 2017, Clean Technology Winner
UNIDO Global CleanTech Innovation Program, National winner
Singapore Sustainability Awards, Green Technology, Winner
Singapore Environmental Achievement Award,  Green Innovation, Merit Winner
SiTF Best Innovative Infocomm Product (Enterprise) Finalist
Visit NEUTO workshops and experience the Magic of Hydrogen today!
Edited by Neutrinos, 12 February 2018 - 08:49 PM.
Tianmo, Lightsabre and Ben5266 praised this
http://www.neutogroup.com
Neuto uses pure hydrogen gas to dry clean your engine. Neuto helps your car breathes smoothly and revives the performance to improve horsepower, fuel efficiency and driving pleasure.
#2
Posted 10 November 2017 - 09:45 AM
Galantspeedz
  • Premium member
    Galantspeedz
    2Fast2Furious
    Author Image
    48,792
huh?
MCF PS3 Gang
MCF Hamsup Tiko Ranger
#3
Posted 10 November 2017 - 10:07 AM
Mits_jc
  • Premium member
    Mits_jc
    5th Gear
    Author Image
    1,815
NPNT.
Hydrogen is explosive, you know?
#4
Posted 10 November 2017 - 10:23 AM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
This is singapore product.
#5
Posted 10 November 2017 - 10:59 AM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
Hydrogen Safety is our the number one concern. Without hydrogen safety, we don’t talk about innovation.
Hydrogen can be dangerous if it is stored in compressed Hydrogen tank or Liquified hydrogen gas tank.  Those common hydrogen carrier are high pressure and unstable in room temperature.  It requires professionals to handle it.
That is why we choose Metal Hydride as the hydrogen carrier.  Metal Hydride stores the hydrogen gas in solid form in room temperature.  It is low pressure, highly stable, highly pure and safe for transport and operation.   We also add sensors and safety features to ensure hydrogen safety, so that you can reap the maximum benefit of hydrogen without worry.
#6
Posted 10 November 2017 - 06:05 PM
Ben5266
  • Premium member
    Ben5266
    NOS-ed
    Author Image
    11,218
huh?
old way of clear carbon is to rav high or use chemical.
But rav high need to rav some time, like going NSHW then effective.
Chemical itself is causing pollution to the environment.
They use H2 at high temperature to react with the carbon deposits become HC (hydro carbon).
Then burn it with O2.The end result is CO2 and H2O.
Simple Chemistry theory but they managed to make it commercially possible.
[thumbsup]
The part I don't understand is how their machine could "teach" our ECU to inject correct quantity of O2 and HC for complete combustion.
Perhaps that's their IP.
My old pok car, after cleaning has zero CO and zero HC (un-consumed petrol).
dcb praised this
Champion of the Champions 2016 & 2017!
#7
Posted 07 January 2018 - 05:27 PM
Sdf4786k
  • Premium member
    Sdf4786k
    Author Image
    9,389
looks like quite useful for diesel cars and trucks
#8
Posted 08 January 2018 - 10:00 AM
Galantspeedz
  • Premium member
    Galantspeedz
    2Fast2Furious
    Author Image
    48,792
[thumbsup]
Ben5266 oh thanks.... i did not even know what they were selling initially lol
you tried with them?
Edited by Galantspeedz, 08 January 2018 - 10:02 AM.
MCF PS3 Gang
#9
Posted 12 January 2018 - 01:19 AM
GotTurboInside
  • Premium member
    GotTurboInside
    Author Image
    12
How much?
#10
Posted 12 January 2018 - 05:23 PM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
How much?
Thanks for enquiry, for petrol vehicles,
less than 3000cc   - $138
more than 3000cc  - $188
Thank you.
#11
Posted 13 January 2018 - 08:03 AM
hydron
  • Premium member
    hydron
    Author Image
    2
Can this be used on hybrid cars?
#12
Posted 15 January 2018 - 12:44 PM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
Hi hydron,
Yes, it can be used for Hybrid, but only for the combustion engine portion.  Your mechanics has to ensure that the car doesn't switch to electric motor while doing Hydrogen cleaning.
Thanks.
Best,
NEUTO Team
#13
Posted 20 January 2018 - 05:05 PM
Track
  • Premium member
    Track
    3rd Gear
    Author Image
    311
Hi
What is the main benefit to this treatment? Better power? Better FC? Etc
How often do we need to do this?
Thanks
#14
Posted 20 January 2018 - 10:08 PM
GotTurboInside
  • Premium member
    GotTurboInside
    Author Image
    12
Anyone tried it? Seems like no real review so far
#15
Posted 24 January 2018 - 05:57 PM
Neutrinos
  • THREAD STARTER
  • Neutrinos
    Author Image
    20
Attached File  Dyno Test neuto-gasoline.pdf   394.04KB   24 downloadsAttached File  Dyno test neuto-diesel.pdf   397.92KB   23 downloadsAttached File  VICOM Test Before NEUTO.pdf   340.3KB   18 downloads
Hi
Thanks
Hi Track,
NEUTO Therapy revitalizes your car back to original designed condition. After NEUTO Therapy, your car will be more responsive, perform better fuel efficiency, higher torque and horsepower.  Dynomometer test shows impressive horsepower and torque gain up to 20% after NEUTO Therapy.
Cleaner engine prolongs the lifespan of your car and give you better driving experience, which includes smoother and lighter drive, more responsive and cold starting of your car early in the morning will never be the same again.
On top of that, NEUTO is an eco-friendly product.  Report shows that NEUTO Therapy reduces that hazardous gas such as Hydrocarbon, Carbon Monoxide and black smoke up to 70% to 90%.  NEUTO improves the air quality we breathe. When you do NEUTO Therapy, you are contributing to the environment too!
Check out the test result from our website
http://www.neutother...rtificates.html
Best,
NEUTO Team
Edited by Neutrinos, 24 January 2018 - 06:01 PM.
#16
Posted 07 March 2018 - 10:50 PM
miao
  • miao
    Author Image
    0
Nea inspection is coming up. Why i hear my friends say can do neuto therapy at the workshop first before inspection will be better than nothing to do?
can advise ?
#17
Posted 06 August 2018 - 10:40 PM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,788
Hi,
Will it be able to totally clean the dirty valves caused by direct injection?
Any before and after picture?
Edited by Kklee, 06 August 2018 - 10:41 PM.
  • 1
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
Neuto Dry Hydrogen Auto-Therapy
Neuto Dry Hydrogen Auto-Therapy  |  Rating   Submit Review
Reviewed by Lightsabre  |  3rd Gear
Awesome Treatment
Did a try with Neuto Dry Hydrogen Auto-Therapy last month. I do feel that the engine is smoother with better torque. Accelerating seems to be slightly faster as compared to before the treatment. What do I personally like is that the engine is... » Read More
Reviewed by SpeedRider  |  Neutral Newbie
Very effective and environmental friendly engine cleaning method
Tried this on my 8 yrs old car which has clocked 200k+ mileage. After the cleaning process, idling smoother and less engine noise. On the road the drive is more responsive and more willing to rev up when needed. FC improve, before less tha... » Read More
Related Product Guide search on sgCarMart.com : Neuto Dry Hydrogen Auto-Therapy
Quick Reply
Tags: neuto therapy and 7 more...
