Credor Twincharged November 29, 2017 Share November 29, 2017 Welcome bro!! See if you can join us for the opening run next Tuesday. Thanks. Will try to. Will confirm by this weekend. ↡ Advertisement Link to post Share on other sites More sharing options...
kdash Supersonic November 29, 2017 Share November 29, 2017 Bro, no worries, that is because I had started my run yet..else me will be the bottom one. Link to post Share on other sites More sharing options...
Easyrider 6th Gear November 30, 2017 Share November 30, 2017 UpdatedOur start of event run will be Date: 5 Dec 2017 (Tues)Time: 7pmLocation: Punggol waterway park10 Tebing lane, Singapore 828849(meet outside Popeyes)1) Tianmo2) Lala813) Ender4) Sadan 5) Jerminator6) Desrongrong7) Tohto (TBC) 8) Easyrider 3 Link to post Share on other sites More sharing options...
Jerminator Internal Moderator November 30, 2017 Share November 30, 2017 So far anyone had any problem using Strava to record your run? Yesterday, after running 1km+ then I realize the app only recorded 0.3km only :( 2 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 So far anyone had any problem using Strava to record your run? Yesterday, after running 1km+ then I realize the app only recorded 0.3km only :( hahahaha, me lor, but I have since sort it out liao. I think firstly you need to wait a while for the GPS to capture before you start running after pressing the start button, need to see the numbers start to jump before we keep the phone and move off. And then never off the screen, the screen has to be kept on always in order for it to work, if you off the screen, it will not work. if you run 2 apps, try to have strava running in front, I have it running at the background with runzi running in front and it didnt work also. I have the same issue with runzi before as well. 3 Link to post Share on other sites More sharing options...
Jerminator Internal Moderator November 30, 2017 Share November 30, 2017 hahahaha, me lor, but I have since sort it out liao. I think firstly you need to wait a while for the GPS to capture before you start running after pressing the start button, need to see the numbers start to jump before we keep the phone and move off. And then never off the screen, the screen has to be kept on always in order for it to work, if you off the screen, it will not work. if you run 2 apps, try to have strava running in front, I have it running at the background with runzi running in front and it didnt work also. I have the same issue with runzi before as well. Wah bro thanks for the solid and detailed solution for it. I'll do a test run again tonight, hope it works *fingerscross*. Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 Wah bro thanks for the solid and detailed solution for it. I'll do a test run again tonight, hope it works *fingerscross*. I had 4 runs with 2 runs having problem, one captured 500m, another one captured 100m after a 2km run. So i tried to figure out the problem, last 2 runs had both distances captured nicely. So I guess the trouble shooting i did works. Good luck bro! 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic November 30, 2017 Share November 30, 2017 (edited) So far anyone had any problem using Strava to record your run? Yesterday, after running 1km+ then I realize the app only recorded 0.3km only :(Check your phone energy saving mode, if it is on the higher saving mode. It may not run well.My others running apps Runkeeper also have problems. I always change the mode before the run. Edited November 30, 2017 by Tohto 1 Link to post Share on other sites More sharing options...
Credor Twincharged November 30, 2017 Share November 30, 2017 Went for a test run with strava this evening. Seems ok and can see my records in the board. Just to check, can you guys/ sis see my running location? Not sure if I am correct on the setting? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic November 30, 2017 Share November 30, 2017 Went for a test run with strava this evening. Seems ok and can see my records in the board. Just to check, can you guys/ sis see my running location? Not sure if I am correct on the setting?ððð I see your run, but not the map itself. Is this how you wanted it to be? 1 Link to post Share on other sites More sharing options...
Credor Twincharged November 30, 2017 Share November 30, 2017 I see your run, but not the map itself. Is this how you wanted it to be? Yes... Thank for your feedback/ info. Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 Went for a test run with strava this evening. Seems ok and can see my records in the board. Just to check, can you guys/ sis see my running location? Not sure if I am correct on the setting? Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 I see your run, but not the map itself. Is this how you wanted it to be? Strange I can see his run, location and map leh. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic November 30, 2017 Share November 30, 2017 Strange I can see his run, location and map leh.Cos you followed him I think 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 Cos you followed him I think I follow lala81 also, but I cannot see his location. Can you see my location? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic November 30, 2017 Share November 30, 2017 I follow lala81 also, but I cannot see his location. Can you see my location? Cannot. All blue 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic November 30, 2017 Author Share November 30, 2017 Cannot. All blue Link to post Share on other sites More sharing options...
Credor Twincharged November 30, 2017 Share November 30, 2017 (edited) I can see both your run and the location, and if I enlarge it I can see how many rounds you ran. I think you ran 6 rounds. If you don't want location seen, check a few post back, @lala81 posted how to make setting location private. I did the setting after he posted and now I think mine cannot see location. I already make setting location private leh.Will check it again. Edited November 30, 2017 by Credor ↡ Advertisement Link to post Share on other sites More sharing options...
Any Running Man fans?
Zeng, King of Geography from Singapore incidentally putting us on the world map
Lost in Singapore ??
Running Shoes - Are expensive running shoes a waste of money
MCF Bingo Challenge!
Running Injury - Plantar Fasciitis
Top 7 Electric Cars Will Challenge Tesla Model 3 in 2019/20
