  • Search this thread
  • Reply to this topic
46 replies to this topic | 60 praises
#1
Posted 30 November 2017 - 09:50 AM
Extremme
  • THREAD STARTER
  • Premium member
    Extremme
    4th Gear
    Author Image
    772
Hi guys , how often do you rotate your tyres? I was told ideally every 10k?
Tianmo praised this
#2
Posted 30 November 2017 - 10:20 AM
Sunny
  • Premium member
    Sunny
    2Fast2Furious
    Author Image
    85,585
ideally rotate whenever you do servicing 10~15k km
Uncle2 praised this
#3
Posted 30 November 2017 - 10:34 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,567
It depends on your usage pattern.
Ideally should look at the wear of the threads especially for the front, one side wears out faster than the other.
For mine,  ideally for the front is about 8k.
Usually the front wear much faster, so I change per pair and put the new ones behind.
#4
Posted 30 November 2017 - 01:29 PM
Extremme
  • THREAD STARTER
  • Premium member
    Extremme
    4th Gear
    Author Image
    772
My car (new) is exactly 1 year and just hit 20k. Gonna do my 2nd rotation
#5
Posted 30 November 2017 - 04:53 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    3,058
I do it every 10,000km
#6
Posted 30 November 2017 - 11:31 PM
zipping
  • zipping
    NOS-ed
    Author Image
    18,361
i rotate mine whenever i do servicing..
AltisOwner, FourZero, Pocy and Beregond praised this
#7
Posted 30 November 2017 - 11:44 PM
Acewin
  • Acewin
    4th Gear
    Author Image
    726
Ideally every 10K do it together with servicing.
#8
Posted 05 December 2017 - 12:38 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,650
rotation is usually every 10k , and don't forget to re balance the 4 wheels before switching them and also your Spare tire if you have.
Rotation sound like simple job to some peoples, but to me it can be done in simple or more professional way depending whats your expectation .
1 ; switch them without any balancing
2 : switch them with just front 2 balancing
3:  switch them with all 4 balancing
4 : = 3 but the process is more works and time
what is  the more works and time?
step  1 the service provider will remove all 4 wheels from your car , lubricate the nuts / bolts if necessary also your hub center.
step 2 clean and wash all wheels before putting  on Machine to spin and re-confirm any out of balance.
step 3 re check all tire pressure.
step 4 dry and wax/ polish your tires
step 5 remount the wheels back to your car manually
step 6 Fasten all wheels manually by Hand to prevent any over tightened the nuts / bolts
step 7 which most WS overlooked is Checking your spare wheel tire pressure if you have one.
step 8 update you when is your next rotation.
step 9 Say thankyou whether you need to pay or free service
step 10  see you next time
#9
Posted 05 December 2017 - 01:59 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    3,058
does the workshop use a torque wrench to tighten the wheel nuts/bolts?
#10
Posted 05 December 2017 - 02:38 PM
Eyke
  • Premium member
    Eyke
    Author Image
    9,993
if ur car has more -ve camber than should rotate earlier, maybe 8K km, else uneven wear.
#11
Posted 05 December 2017 - 03:15 PM
ECONOMIC
  • ECONOMIC
    3rd Gear
    Author Image
    449
Anyone here include spare tyre in the rotation?
#12
Posted 05 December 2017 - 03:29 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    3,058
me
ECONOMIC praised this
#13
Posted 05 December 2017 - 03:31 PM
Eyke
  • Premium member
    Eyke
    Author Image
    9,993
provided the spare isn't a space-saver type
#14
Posted 06 December 2017 - 10:16 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,650
Pang, I am sure that is  tire WS use torque wrench , but very little.
first of all , one must understand why the need of Torque wrench and advantages ?
any sharing here ?
TIA
#15
Posted 06 December 2017 - 10:21 AM
nazerath
  • nazerath
    NOS-ed
    Author Image
    17,979
My 10k though I think 9 k is better. I prefer those that use hand tools to tighten rather than the impact.
I can then check with torque wrench when I am free but there are 5 nuts, don’t think so easy to loosen.
I don’t use the spare wheel cos mine is Ugly.
I just remember to TOP up air for the spare
Edited by nazerath, 06 December 2017 - 10:22 AM.
#16
Posted 06 December 2017 - 10:30 AM
Acewin
  • Acewin
    4th Gear
    Author Image
    726
Can you share if base on all the steps you mention how much will the shop charge?
#17
Posted 06 December 2017 - 11:03 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
Hardly come across tyre shops using torques wrenches, customers should thanks their lucky star if they happen to visit shops that use wheel torsion sockets ( much cheaper to invest than a professional torques wrench )
Edited by Yeobh, 06 December 2017 - 11:06 AM.
Eyke praised this
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#18
Posted 06 December 2017 - 12:56 PM
Eyke
  • Premium member
    Eyke
    Author Image
    9,993
torque wrench i've only seen in workshops, these are something new all together.
thanks, learnt about something new!
any sharing here ?
TIA
http://www.crashfore...hubfailures.cfm
"Crashes caused by wheels coming off of vehicles are commonly referred to as wheel runoff crashes. Two primary failures cause wheel runoff crashes. One is a failure of the wheel mounting system, such as the wheel studs, lug nuts, etc. The other cause is a failure of the hub and wheel bearing assembly.
Wheel system failures are primarily caused by the improper installation of a wheel that causes it to be loose or become loose. Commonly, a loose wheel causes the wheels studs to break and the wheel and tire to separate from the vehicle. Many root causes lead to loose wheels, but most of them are associated with over-torquing or under-torquing the lug nuts.
Over-torquing is likely the most common wheel system failure due to the widespread use of impact wrenches to install wheels. Using an impact wrench to install wheels commonly causes the wheels to have 3 to 5 times the specified lug nut torque.
Under-torquing is just simply not tightening the wheel lug nuts enough, causing the wheel to be loose. Under-torquing can be caused by corroded and damaged wheel system components. It can also be caused by using a cheap or worn-out impact wrench or by having a low air-pressure supply to an impact wrench."
#19
Posted 06 December 2017 - 12:57 PM
Enye
  • Enye
    2Fast2Furious
    Author Image
    56,895
erm...$20?
:D
#20
Posted 06 December 2017 - 01:38 PM
ECONOMIC
  • ECONOMIC
    3rd Gear
    Author Image
    449
Yeah. Mine is a full sized spare. Even same rim. Motor Image where i send for servicing told me they don't practice that. Even though the car manual says so.
Now the 4 wheels already have 20k travelled. The spare wheel still untouched. Any recommendation?
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Tong Hin & Co.
Tong Hin & Co.  |  Rating   Submit Review
Reviewed by Dorothy5552  |  Neutral Newbie
I have been going to Tong Hin & Co at Blk 119 Bukit Merah Lane 1 (Tel: 62717976) when I need to change tyre/batteries/rims or just do simple services, eg. Alignment, balancing etc. The owner of the shop Mr. Benjamin Ng is very knowledgeable as he has been in this trade for more than 40 years. He knows the performance and differences of different brands and gives me good... » Read More
Pitstop Tyres Pte Ltd
Pitstop Tyres Pte Ltd  |  Rating   Submit Review
Reviewed by Pinninfarina  |  Neutral Newbie
I came to know about Pitstop Tyres through this forum and am thankful for it. Visited the outlet at Upper Thomson road for the first time this afternoon and spoke to the boss Edmund to seek his advice on rim and tyre replacements for my Kizashi. He was patient and helpful and finally, settled on a deal which I find is priced reasonably. I left a happy man with a new s... » Read More
Related Motor Directory search on sgCarMart.com : Tyres & Rims
Quick Reply
Tags: tyres car rotation, rotation and 2 more...
