  • Search this thread
  • Reply to this topic
21 replies to this topic | 42 praises
#1
Posted 01 December 2017 - 01:34 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
May interest some runners.
https://www.runnersw...893ce980c0c7fa8
And what can happen if your ticker’s not beating up to par.
2.5 billion. No, it’s not how old the Earth is. It’s the average amount of times the heart beats in a lifetime, according to the American Heart Association.
Breaking it down even further, your heart beats 100,000 times every day, pumping about 2,000 gallons of blood.
Your heart rate dictates the exact number of times your heart beats per minute. And while your specific number for that might not be as familiar to you as, say, your blood pressure or your weight, it’s still pretty important. That’s because your resting heart tells a great deal about your heart muscle is functioning.
Your resting heart rate refers to the number of beats your heart pumps when you’re not exerting yourself—like when you’re relaxed, lying down, and calm. Your heart rate is typically lowest when sleeping or otherwise inactive and then increases with physical activity.
WHAT IS A NORMAL RESTING HEART RATE?
A normal resting heart rate is between 60 and 100 beats per minute.
Having a heart rate in that sweet spot is important, because it decreases the demand of your heart muscle, meaning it doesn’t have to work as hard, explains Kate Traynor, M.S., R.N., director of Cardiovascular Disease Prevention Center at Massachusetts General Hospital.
RELATED: Why It’s Important to Pay Attention to Your Resting Heart Rate
“Think of your heart as a car and your blood’s oxygen as the gas. The faster you drive, the more gas you use (the more blood that needs to be pumped). More gas means more work for the heart, which can put it in constant overdrive,” says Traynor.
WHAT IS A SLOW OR FAST HEART RATE?
Heart rate that averages above 100 beats per minute is called tachycardia. You can develop a high heart rate because of things like fever, anemia, dehydration, or physical or emotional stress, which triggers the release of the fight-or-flight hormone adrenaline.
“Adrenaline is like gasoline on a fire for heart rate,” says Traynor. It can also lead to bigger problems—everything from fainting spells to more serious issues like blood clots that lead to stroke, or eventual heart failure (Here’s how to know if you have a blood clot).
RELATED: How an Apple Watch Saved This Man From a Life-Threatening Blood Clot
A 2010 study found that people with a resting heart rate at or above 84 beats per minutes over the span of five years were 55 percent more likely to die of heart disease than those with lower resting heart rates were.
On the other hand, a resting heart rate below 60 beats per minute is called bradycardia, and can cause insufficient blood flow to the brain.
“An abnormally low heart rate can lead to symptoms such as feeling tired, lightheaded, dizzy, and may even cause loss of consciousness,” says Suneet Mittal, M.D, FHRS, of the Heart Rhythm Society (Here’s what it means if you feel dizzy when you stand up).
You can develop a low resting heart if you take certain meds, like beta blockers for high blood pressure, or meds for hypothyroidism. Electrical abnormalities in the heart’s pathways can also lower your rate, too.
But a low rate resting heart isn’t always a bad thing. Endurance athletes—say, cyclists or runners—can have resting heart rates below 40 beats per minute.
RELATED: Is My Resting Heart Rate Too Low?
So while there are exceptions—in some cases, too much intense athletic conditioning can cause “athlete’s heart,” where the heart is enlarged along with a low resting heart rate—it’s generally a good thing for your heart rate to skew lower rather than higher.
Without overdoing it, one of the best things you can do to maintain a healthy resting heart rate is exercise. You should be incorporating both cardio and weights into your routine, for a total of 150 minutes per week, says Traynor.
HOW CAN YOU FIND OUT YOUR RESTING HEART RATE?
Fitness trackers with heart rate monitors can be surprising accurate. A 2017 Stanford study found that six out of seven fitness trackers they tested were 95 percent accurate in measuring heart rate.
However, you shouldn’t always rely on technology to give you measurements.
Dr. Jordan Metzl debunks some myths about running's effects on the heart and discusses warning signs and risk factors all runners should look out for:
“The best way to determine your resting heart rate is to learn to take your pulse,” says Dr. Mittal. “This can be taken by palpating the pulse at your wrist or neck.”
Here’s how to do it: Place your index and third fingers on your neck to the side of your windpipe. If you want to check it at your wrist, place two fingers between the bone and the tendon, looking for your radial artery—which is located on the thumb side of your wrist.
Once you find your pulse, count the number of beats in 15 seconds, then multiply that number by 4 to calculate your beats a minute, according to the Mayo Clinic.
RELATED: 5 Max Heart Rate Training Myths, Busted
While your heart rate may vary, it’s important to keep a healthy base rate. Once you know what that is for your body, keep tabs. If you start to notice changes with your heart rate, you should check in with you primary care doctor, especially if you notice it consistently dipping way below your normal resting heart rate, or frequent episodes of unexplained fast beating.
“If you’re a regular exerciser, but start to notice your routine takes more effort, or if you’re breathless or more tired than normal during your workout, it’s time to see a doctor,” says Traynor.
Plus, a sudden change in heart rate—either becoming too slow to too fast—should raise concern, too, Dr. Mittal says. Call your doctor to get checked out.
The article What Should Your Normal Resting Heart Rate Really Be?originally appeared on Men’s Health.
Edited by Ender, 01 December 2017 - 01:35 PM.
Tianmo, Dleodleo, Lala81, kdash and Blueray praised this
#2
Posted 01 December 2017 - 01:35 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
Running is great for the heart.
https://www.runnersw...-and-your-heart
#3
Posted 01 December 2017 - 01:41 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    29,995
Other than resting pulse, nowadays Heart Rate Variability is also very important.
https://en.wikipedia...ate_variability
https://www.training...ify-weaknesses/
Tianmo and Dleodleo praised this
#4
Posted 01 December 2017 - 01:45 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
This one how to measure?
#5
Posted 01 December 2017 - 02:10 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    29,995
ECG
HR Strap
App like HRV4Training
#6
Posted 01 December 2017 - 02:23 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
ECG
HR Strap
I see, I have the Garmin HR strap which I kept away in favor for the wrist measurement, Don't think it can measure HRV either.
ECG, I think not practical for daily use. [laugh]
#7
Posted 01 December 2017 - 02:31 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    29,995
I thought of buying HRV4TRAINING.  It is is SGD15.
I think HR4 & resting pulse is more a health tool rather than exercise tools.
#8
Posted 01 December 2017 - 02:48 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
For exercise tool, with HR, is more than enough to tell me whether I pushed myself enough.
Resting HR,  for me is telling us that all these time we have been running has the exercise benefit us. i.e. try not to have resting Heart rate more than 84, as seen from the article I posted.  More than 55% risk of dying of heart disease.
$15, can try and play around.
#9
Posted 01 December 2017 - 02:51 PM
Jman888
  • Jman888
    Moderator
some samsung S phone got sensor to measure   [laugh]  [laugh]   i always get around 60 on resting, make me worried for a while  [sweatdrop]
<p><span style="font-size: 10px;">骑白马的不一定是王子,可能是唐僧;带翅膀的也不一定是天使,有时候是鸟人。 </span></p>
#10
Posted 01 December 2017 - 02:53 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
ya, that is quite convenient, last time my S5 does that.   60 is normal rate, so nothing to worried.
#11
Posted 01 December 2017 - 02:56 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    29,995
I used to be 60.
Now around 67
#12
Posted 02 December 2017 - 01:29 PM
Nzy
  • Premium member
    Nzy
    2Fast2Furious
    Author Image
    27,840
Mine usually around 55 when I just wake up. But throughout the day it hovers around 65-70 unless I'm exercising.
I have to use HRM when running cuz my doctor said I shouldn't push myself too hard when running or cycling cuz of my heart condition.
#13
Posted 02 December 2017 - 03:46 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
If got heart condition, better don't push..
#14
Posted 02 December 2017 - 04:07 PM
Dleodleo
  • Premium member
    Dleodleo
    NOS-ed
    Author Image
    18,207
Buy from where? Use it to measure heartbeat?
#15
Posted 02 December 2017 - 04:12 PM
Nzy
  • Premium member
    Nzy
    2Fast2Furious
    Author Image
    27,840
Yeah. That's why my runs all slow pace. Cuz the doctor did say still need cardio to stay healthy but can't push too hard or it'll wear down my heart even faster.
#16
Posted 02 December 2017 - 05:24 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    31,944
I've a omron hem-7200.
It measured both bp and pulse rate.
#17
Posted 03 December 2017 - 02:25 PM
golden_eagle
  • golden_eagle
    Author Image
    17
between 70 and 80?
#18
Posted 04 December 2017 - 10:44 AM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    29,995
Apple
or
Google
store
#19
Posted 07 December 2017 - 05:43 PM
racergem
  • racergem
    Author Image
    17
Usually it's around 55 to 80 beats per minute. I think around 90 to 120 is the fat burn mode.
#20
Posted 12 April 2018 - 11:09 PM
Ender
  • THREAD STARTER
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    57,163
If you don't want to spend money for a VO2max test in a sport clinic, here's a quick check to see how fit you are. Just need a Heart rate monitor which most runners should have. Or a blood pressure monitor.
https://www.justrunl...ys-to-find-out/
Do You Know How Fit You Are? – 3 Ways To Find Out!
BY
MEL AUTHOR  MARCH 30, 2018
It’s not easy to tell whether you are fit or not by how much you weigh, or how often you exercise, or the way you look. A good example is that of a weight-lifter. His BMI could indicate that he is overweight, however, this would be due to his muscle mass. His would be lean and his body fat percentage would be in the healthy range. Whether you are fit is not how many kilometers you can run, how many repetitions you can lift, or how heavy you can lift, or how far you can swim.
A good indication of your fitness is actually your heart rate. Here are 3 ways your heart rate can tell you how fit you are:-
#1 Heart Rate Before & After Exercise
Take your heart rate before you start your warm up and after you have completed your workout. A healthy heart will typically go back to a normal heart rate within 15 minutes of exercise. On the other hand, an unhealthy heart would struggle to return to your pre-workout heart rate. If it remains high, this possibly indicates an unconditioned heart, or that your exercise intensity was way too high for you. It could also mean that you are overtraining.
#2 Resting Heart Rate
guide-to-lowering-your-resting-heart-rat
This is one of the most effective ways to gauge your fitness. Your resting heart rate is the number of heart beats per minute while you’re at rest. An athlete typically will have a lower resting heart rate as compared to a normal person. Resting heart rate also increases with age. You should be having a RHR of about 60 – 100 bpm. Anything higher indicates that you may be having heart problems.
Read More: Understanding Your Heart Rate Zones
#3 Heart Rate During Sleep
When you sleep, it’s your body’s chance to recuperate and rejuvenate. Your heart rate during sleep should be lower than normal. This serves as a strong indicator of fitness. If your body is still high during sleep, your heart is still working hard even though it should be resting and recuperating. This is not good. Some people who exercise in the night before they sleep will find a higher heart rate during sleep. Perhaps you could switch it up and try to exercise in the morning instead.
Your heart rate provides good insight into your physical fitness levels. So, do take note!
Edited by Ender, 12 April 2018 - 11:10 PM.
Mason016 and Baleno praised this
Back to Healthcare & Wellness  ·  Non-Car Related Top Reply to this topic
Quick Reply
Tags: heart rateresting heart rate and 7 more...
