  • Search this thread
  • Reply to this topic
29 replies to this topic | 55 praises
#1
Posted 01 December 2017 - 06:37 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
any shop that repairs thread of wheel lug bolt hole?
#2
Posted 01 December 2017 - 06:57 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,229
German car ?
#3
Posted 01 December 2017 - 07:05 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
Swedish: Volvo
#4
Posted 02 December 2017 - 02:03 AM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,229
I'm assuming your car use lug bolts (not lug nuts), like German cars.
And the threads on the holes are damaged.
My fren used to own this shop and he can do repair of holes with helicoil.
Although the business has now changed hands, you may try to contact this shop,
Google for address: Oldvolks Place
Eyke praised this
#5
Posted 02 December 2017 - 02:10 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
thanks, tried them but they say they don't do re-thread.
eventually tried Motor EDGEvantage, and the nice pple there helped me fix it for free!
anyway, Poh Heng was the culprit:
Went to change tyres, after paying THEN they tell me one of the wheel lug bolt cannot be screwed back in.
Instead of helping to resolve the issue they caused by improper reinstallation of the wheel, they gave me the lug bolt and ask me go fix it myself.
Will never go back there again.
Edited by Eyke, 02 December 2017 - 02:18 PM.
#6
Posted 02 December 2017 - 02:26 PM
t0y0ta
  • t0y0ta
    6th Gear
    Author Image
    2,752
Seriously..... this type of black shop deserves to close down. Poh Heng used to be quite well reputed.
Did you screw them for this type of black service?
#7
Posted 02 December 2017 - 02:29 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
i was a bit stunned, coz 1st time kena this issue, so i thought just go buy a new lug bolt can liao,
thus didn't kick up a fuss.
but after getting a new lug bolt, oso can't screw in coz the hole's thread oso screwed up.
had to spend whole morning running shop to shop in industrial park to ask shops if can help,
luckily remembered Motor EDGEvantage does Volvo, so got them to help.
#8
Posted 02 December 2017 - 02:37 PM
Fitvip
  • Fitvip
    Author Image
    8,917
The threads won't get spoiled easily if the mech had handle the bolts/nuts correctly.
I think it is before the threads of the bolt and the hole get inline, they just use the air gun to force it in, thus damaging the thread!
Beregond, Eyke and Volvobrick praised this
#9
Posted 02 December 2017 - 02:47 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
yeah, should hand screw in the bolt before tightening (preferably with torque wrench set to car manufacturer's stated torque),
but the worker probably just put the bolt into the air gun/wrench and bam: cost me 1 wasted morning, petrol, & 1 new lug bolt.
henceforth, will always ask shop to hand tighten then I ownself use torque wrench to tighten.
#10
Posted 02 December 2017 - 02:56 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    82,134
what seems to be a simple and idiot proof way of damaging screw thread but yet failed to do so.
so much for professionalism. Haiz....
QUOTE
do to others what you want others to do to you......
#11
Posted 02 December 2017 - 03:53 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,229
The new owners probably didn't want to do it. Heli-coil inserts need skill and specialized tools.
My old VW van had some problem with the hole thread as well.
After going through many tyre shops, it tends to get damaged by careless mechanics.
Lug bolts can be easily replaced, but not the threads.
And now, many shops employ PRC. Once, I had to stop one guy from over-tightening. He looks hell-bent on breaking it.
#12
Posted 02 December 2017 - 04:02 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
actually, if you have the correct tool/insert, it's very easy to do, just screw in.
#13
Posted 02 December 2017 - 04:12 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,229
Yeap, that's one thing I never get to learn.
What I know from my fren, is that you need to drill a slightly bigger hole, use a special size tap to thread
And then a tool to insert the coil and snap it off.
Thus leaving the coil inside the hole and a new thread.
I had thought of doing the heli-coil earlier when the van oil plug hole was damaged.
But soon, I realized that hand-tightened is not that bad.
Surprisingly, the oil didn't leaked away too much and most of it remains until the next oil change.
So I didn't bother to fix the hole thread.
I did most of my own servicing.
#14
Posted 02 December 2017 - 04:23 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
oh, maybe that's when the thread is all stripped out.
mine still salvageable by just screwing in the insert to fix the few messed up thread turns.
#15
Posted 02 December 2017 - 04:38 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,229
The thread is usually damaged by not inserting the bolt squarely in.
And then forcing it in, even after it hit restriction, causing cross-threading.
The force is usually the air gun.
With 1000 ft-lb of torque, the bolt now cuts new thread and the old one is damaged.
Edited by Kb27, 02 December 2017 - 04:41 PM.
#16
Posted 02 December 2017 - 06:07 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
For female crossed thread , you either need a thread chaser or tap to clean up / form the thread back to original form.
For stripped female thread , you either use a thread insert or drill a next oversize tapping hole and tap the next tread size.
Eyke praised this
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#17
Posted 02 December 2017 - 06:16 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
For use on vehicles that use wheel bolts
#18
Posted 02 December 2017 - 06:19 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
thanks, u the most knowledgeable regarding workshop tools!
#19
Posted 02 December 2017 - 06:20 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
For repair of stripped internal thread
#20
Posted 02 December 2017 - 06:27 PM
Eyke
  • THREAD STARTER
  • Premium member
    Eyke
    NOS-ed
    Author Image
    10,162
Problem lies in locating workshops that have these tools.
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Sat Motors (Workshop)
Sat Motors (Workshop)  |  Rating   Submit Review
Reviewed by Hadrami17  |  Neutral Newbie
Based on a recommendation, I came here to do my servicing for my pre-owned PI Harrier ride. Both Sean and Clement were very patient and explained what it would entail for the servicing. Sean even explained the various Japanese screens on the odometer - something I never thought workshops folks would want to spend time to explain to new customer.
They kno... » Read More
Reviewed by keeganteng  |  Neutral Newbie
Sent my car in for repairs after a hit & Run case. Was assisted by Jessie who was very helpful and prompt in answering all my queries regarding the claims and the procedures. Very patient and professional. The workshop was fast in handling my repairs and was done very well. Very friendly service there and will definitely go back there if I need repairs works and also re... » Read More
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Tags: lug bolt, stripped, thread and 5 more...
