SGCMHello 4th Gear February 10, 2018 Share February 10, 2018 New cars usually come with free camera, but the camera will off when engine off. If you connect camera to draw power from battery, it will void warranty. Heard that if we install a battery Power Pack to ensure camera is running when engine is off, it will not void warranty, but some say it will void warranty. Anybody knows if battery Power Pack voids warranty ? ↡ Advertisement Link to post Share on other sites More sharing options...
kdash Supersonic February 10, 2018 Share February 10, 2018 strange to hear about the warranty being void if camera is connected to battery. anyway best is to check with your dealer. Link to post Share on other sites More sharing options...
inlinesix Supersonic February 10, 2018 Share February 10, 2018 As long as fuse is not tapped, it will avoid all problems. Link to post Share on other sites More sharing options...
juansan Neutral Newbie February 21, 2018 Share February 21, 2018 As long as I know, any change or modification will void warranty, so I will ask it before install it. Link to post Share on other sites More sharing options...
Kb27 Supersonic February 21, 2018 Share February 21, 2018 Voiding warranty is a means to protect AD. Bcuz if you drained the battery flat, due to installing camera or any 3rd party device, some functions may not work properly. A lot of cars nowadays depends on battery voltage to keep ECU settings, like power windows, seat memory, clock, radio, engine idling, etc. Link to post Share on other sites More sharing options...
Buadongdong Twincharged February 21, 2018 Share February 21, 2018 It will void all warranty if the car catches fire and when investigation concludes that the cause of fire is the battery pack. Link to post Share on other sites More sharing options...
Lomfy 2nd Gear February 21, 2018 Share February 21, 2018 As long as I know, any change or modification will void warranty, so I will ask it before install it. It is adding on ( camera and power pack ) not modify current or existing.....thats what my SA told me Link to post Share on other sites More sharing options...
inlinesix Supersonic February 21, 2018 Share February 21, 2018 It will void all warranty if the car catches fire and when investigation concludes that the cause of fire is the battery pack. Still can claim own damage from insurer Link to post Share on other sites More sharing options...
Buadongdong Twincharged February 21, 2018 Share February 21, 2018 Still can claim own damage from insurer Dunno man.. can meh?? Its similar to illegal modifications whereby insurer will void right?? Grey area here.. Link to post Share on other sites More sharing options...
inlinesix Supersonic February 21, 2018 Share February 21, 2018 Dunno man.. can meh?? Its similar to illegal modifications whereby insurer will void right?? Grey area here.. Is charging your phone using ciggy port illegal mod? 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged February 21, 2018 Share February 21, 2018 Is charging your phone using ciggy port illegal mod?I wouldn't know.. Not defined by me.. If insurer insist it is we also LL right? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 21, 2018 Share February 21, 2018 Warranty is always based on acceptable and normal usage. If you "abuse" it, warranty can be voided. Example, it's normal for you to plug a charger in the ciggie socket and use it to charge a handphone. Since it consumes very little current, no one will void warranty. However, if you plug in a 3 port extension with very thin wires and you overload the extension and it catches fire, then warranty is voided. The same as if you plug in a 12v heater to cook maggi mee in the ciggie socket. If it doesn't blow a fuse, but melts wire and start a fire, then warranty can be voided. Ciggie socket is normally protected by a fuse of 10A or some newer car 15A, it means the power is limited, to protect internal wiring from overheating and going up in flames. Link to post Share on other sites More sharing options...
Sotong07 3rd Gear March 2, 2018 Share March 2, 2018 It will void all warranty if the car catches fire and when investigation concludes that the cause of fire is the battery pack. Then insurance can claim? Warranty and Insurance different issues or back to back connected? 1 Link to post Share on other sites More sharing options...
Lionsworld March 5, 2018 Share March 5, 2018 I'm also concerned about this, my car is under the sun frequently, will my battery pack catch fire? 1 Link to post Share on other sites More sharing options...
Sharkles Clutched May 11, 2018 Share May 11, 2018 I'm also concerned about this, my car is under the sun frequently, will my battery pack catch fire? The camera that comes with the car dont have the function to be on 24hrs so i was told to go to a 3rd party and add power pack for the camera. has anyone done it in a way that it doesnt void the warranty and dont pose as a safety issue? Link to post Share on other sites More sharing options...
CronusWeer May 12, 2018 Share May 12, 2018 surely i ll ask 2 Link to post Share on other sites More sharing options...
Matrix88 Clutched May 26, 2018 Share May 26, 2018 hi, any one use Mightcell LifePo4 battery pack for car dvr ? Is it good ? Link to post Share on other sites More sharing options...
alexahbk Clutched May 26, 2018 Share May 26, 2018 When you do any modification to your car's electronic/wiring system, the warranty will get void. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Car camera recommendation
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
sgCarMart rolls out its Car Protection Initiative for buyer peace-of-mind (sgCarMart Warranty)
EPS car park gantry - no entry record
