  • Search this thread
  • Reply to this topic
38 replies to this topic | 25 praises
#1
Posted 18 February 2018 - 10:56 PM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
I just change my rims to 225/17/50 profile for my 17" OZ Leggera HLT 8J, is this the correct size? I wanted 215 width but Auto Kinetic says 225 is "Fuller" look. Don't quite understand. Any expert advice please? Thanks!
27500874_10215555471138261_4525237692862
BabyBlade praised this
100A F 2/Nissan Sunny 1.3GL/Suzuki GTi/Civic VTi 2 Dr/Mitsubitshi MR/Mazda 3/Lancer EX/Mazda 3 standard
#2
Posted 18 February 2018 - 11:15 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
Your 8J rims basically are 8 x 2.54 = 20.3cm wide
You can fit 215 (21.5cm wide) tyres but 225 means the rubber bulge out a bit more to cover the edges of the rim so when you kerb the rims, the rubber hits the curb before the metal.
Fuller look just means fatter tyre I assume. Some people like the tyre stretched so that the rim is wider than the tyre but its all a personal pref as far as looks go.
#3
Posted 18 February 2018 - 11:19 PM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
OIC, thks....so next tyres change i can fit 215? I scare now 225 fuel consumption and pick up will be worse...
#4
Posted 18 February 2018 - 11:30 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
You could BUT with an 8J rim, 215 is a bit small (e.g. you get a bit less kerb rash protection). Basically you bought a pretty fat rim for I assume an Axela/Maz3.
There are some generally accepted rim widths for any given tyre width. There is some leeway but Auto Kinetics is not wrong suggesting 225 for an 8J rim. Basically tyre companies would also recommend a minimum 225 tyre for a 8J rim.
You can use this site to calculate.
http://www.tyresizec...size-calculator
Recommended Rim Sizes
for Tyre Size: 225/50 R 17 From 6.00" x 17" To 8.00" x 17" Measuring Rim
Width 7.00" Standard
Rim Size 7.00" x 17"
for Tyre Size: 215/50 R 17 From 6.00" x 17" To 7.50" x 17" Measuring Rim
Anyway, just enjoy your new rims lah. How much were they? Flow form or forged?
Edited by Ake109, 18 February 2018 - 11:35 PM.
#5
Posted 18 February 2018 - 11:33 PM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
after trade in my Enkie rim need to top up 2.3k heart pain....won't be changing anymore.....lol..215 to 225 pickup affected?
#6
Posted 18 February 2018 - 11:36 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
Yes because heavier and also rolling radius bigger. But really the difference is so small that I don't think your butt dyno can tell.
You want fatty 8J rim is like this lor. Was there a 17 x7.5J rim of the same model available?
#7
Posted 18 February 2018 - 11:39 PM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
nope, that size not available...i like the rims design and easy to wash....i forgot about the 8J...aiyah too late liao....
#8
Posted 18 February 2018 - 11:55 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
Did you also check the offset of the rims? If too aggressive (e.g. too low) is not good. Maz3 stock should be ET+50
Don't worry about the 215 vs 225 lah. It is really negligible. I assume 215 is stock size for your car?
Edited by Ake109, 18 February 2018 - 11:59 PM.
#9
Posted 19 February 2018 - 12:30 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
Wah..I forgotten the offset....later I ask Auto Kinetic.....headache...I check online is 45mm...ok?
https://www.tirerack...RG&showRear=no
Edited by Axela525, 19 February 2018 - 12:52 AM.
#10
Posted 19 February 2018 - 01:04 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
Original is
205/60R16 92H 6.5Jx16 ET50
#11
Posted 19 February 2018 - 01:56 AM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,196
You are fine. 5mm diff is safe.
Your tyres are still within fender right? Not sticking out of wheel arch? (since your tyre now approx. +5mm + (1.5*25.4)/2mm closer to outside)
Edited by Ake109, 19 February 2018 - 02:03 AM.
#12
Posted 19 February 2018 - 07:32 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
I ask my tyre shop he says is 48mm....nope...not sticking out....turning full lock no rubbing...just that i scare affect my pickup only....fuel so far ok....
#13
Posted 19 February 2018 - 07:54 AM
SZ_ford
  • SZ_ford
    2nd Gear
    Author Image
    107
i change from 225 to 245, didn't notice any change in pickup. cornering stability did improve.
fuel consumption did suffer a bit
#14
Posted 19 February 2018 - 07:59 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
Yours not mazda 3 right? lol
Edited by Axela525, 19 February 2018 - 08:10 AM.
#15
Posted 19 February 2018 - 08:27 AM
SZ_ford
  • SZ_ford
    2nd Gear
    Author Image
    107
nope, haha
i used the tire calculator, 8inch rim can use 215 - 245mm tire, depending on your offset
#16
Posted 19 February 2018 - 08:36 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
nope, haha
Ok....u 18 inch rim ar? so mine ok?
#17
Posted 19 February 2018 - 08:45 AM
Columbian78
  • Columbian78
    5th Gear
    Author Image
    2,163
What is the conditions when u say "turning full lock no rubbing"? Cos hard cornering or with heavy load the car will dip down further and hence more likely to hit than if just normal turns. I once attempted to increase the diameter of my tyres by using next higher side size profile (eveything else same). But changed mind in the tyre shop when the wheel was removed and we saw there is sign of a rubbing patch internal of the wheel wheel size of 50c coin. This means the tyre had already been rubbing the plastic from daily drives even though i had felt nothing. My car not mazda3 and is lowered btw.
For your case since you had already changed and no issues observed just carry on and observe.
#18
Posted 19 February 2018 - 09:02 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
Thanks for the input....will monitor...I usually drive alone....mine not lowered....so abit better than yours....lol
#19
SZ_ford
  • SZ_ford
    2nd Gear
    Author Image
    107
https://tiresize.com/calculator/
u can play around with this. it will tell you the tire you can use. but it doesn't take into account your offset
#20
Posted 19 February 2018 - 09:03 AM
Axela525
  • THREAD STARTER
  • Premium member
    Axela525
    Supercharged
    Author Image
    7,106
thanks...just now i google oredi...
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Rial Padua
Rial Padua  |  Rating   Submit Review
Reviewed by Walse  |  Neutral Newbie
Great European rims
Nice and unique design, compatible with steelmate TPMS. European quality and finishing :) Installed these rims at South East Tyres at Khaki Bukit and got them at a very good price, considering these are German made rims :) PCD was 5x11... » Read More
SSW S007 Eternity
SSW S007 Eternity  |  Rating   Submit Review
Reviewed by Chuckwaggon  |  Neutral Newbie
Worth Spending on
Came across this rim and is decently priced so took it up, quite durable and fits well. The tyre also does not seem to be very heavy for carrying and steering wise seem lighter. I don't know, maybe is my mind playing tricks on me but anyway h... » Read More
Related Product Guide search on sgCarMart.com : Rim
Quick Reply
Tags: mazda, mazdatyres/rims/mazda and 3 more...
