SZ_ford 5th Gear February 19, 2018 Share February 19, 2018 Ok....u 18 inch rim ar? so mine ok? https://tiresize.com/calculator/ u can play around with this. it will tell you the tire you can use. but it doesn't take into account your offset ↡ Advertisement Link to post Share on other sites More sharing options...
Axela525 4th Gear February 19, 2018 Author Share February 19, 2018 https://tiresize.com/calculator/ u can play around with this. it will tell you the tire you can use. but it doesn't take into account your offset thanks...just now i google oredi... Link to post Share on other sites More sharing options...
Roberttan 5th Gear February 22, 2018 Share February 22, 2018 appreciate all above sharing my personal views almost all car manufacturer has optional tire size for your car which can easily find them in your Owners book or Door pillar / fuel cap cover. Most car manufacturer recommend up size tire with lower overall height (Not profile). Some car owners prefer to have a higher overall height than original which make it looks nicer (gap btw tire and fender) Do remember if your car still under warranty especially those ex $ car, your SA may make your Life little difficult should you complaint any thing linked to your wheel and tire. Also changing your wheels alone may also cause some issue even using back your tire Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear March 14, 2018 Share March 14, 2018 appreciate all above sharing my personal views almost all car manufacturer has optional tire size for your car which can easily find them in your Owners book or Door pillar / fuel cap cover. Most car manufacturer recommend up size tire with lower overall height (Not profile). Some car owners prefer to have a higher overall height than original which make it looks nicer (gap btw tire and fender) Do remember if your car still under warranty especially those ex $ car, your SA may make your Life little difficult should you complaint any thing linked to your wheel and tire. Also changing your wheels alone may also cause some issue even using back your tire Hi, Is this your personal experience? Care to share more? Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear March 14, 2018 Share March 14, 2018 I just change my rims to 225/17/50 profile for my 17" OZ Leggera HLT 8J, is this the correct size? I wanted 215 width but Auto Kinetic says 225 is "Fuller" look. Don't quite understand. Any expert advice please? Thanks! Hi, You should be on 225/50/R17 tyres given that your rims are 8" wide. Luckily you did not go for 215 tyres. I am on 18" OZ Leggera HLT (Gloss Black) with 8J. I am using 225/45/R18 tyres, which I felt the tyres of 225 is not wrapping this 8" wide rims sufficiently. Quite easily prone to kerb rash even with the thick sidewalls of my Bridgestone RE003 tyres. 1 Link to post Share on other sites More sharing options...
Axela525 4th Gear March 15, 2018 Author Share March 15, 2018 Hi, You should be on 225/50/R17 tyres given that your rims are 8" wide. Luckily you did not go for 215 tyres. I am on 18" OZ Leggera HLT (Gloss Black) with 8J. I am using 225/45/R18 tyres, which I felt the tyres of 225 is not wrapping this 8" wide rims sufficiently. Quite easily prone to kerb rash even with the thick sidewalls of my Bridgestone RE003 tyres. any picture? Link to post Share on other sites More sharing options...
Discoburg Supersonic March 15, 2018 Share March 15, 2018 Sigh. Have not seen your new ride yet leh. Hi, You should be on 225/50/R17 tyres given that your rims are 8" wide. Luckily you did not go for 215 tyres. I am on 18" OZ Leggera HLT (Gloss Black) with 8J. I am using 225/45/R18 tyres, which I felt the tyres of 225 is not wrapping this 8" wide rims sufficiently. Quite easily prone to kerb rash even with the thick sidewalls of my Bridgestone RE003 tyres. Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 16, 2018 Share March 16, 2018 Hi, Is this your personal experience? Care to share more? Hi . I personally do not have this experience but other size like 225/45/18 on 7.5 and 8 inch wheel width. Just MHO changing wheels and tire size always follow what car manufacturers recommended size first. Link to post Share on other sites More sharing options...
SZ_ford 5th Gear March 16, 2018 Share March 16, 2018 Hi, You should be on 225/50/R17 tyres given that your rims are 8" wide. Luckily you did not go for 215 tyres. I am on 18" OZ Leggera HLT (Gloss Black) with 8J. I am using 225/45/R18 tyres, which I felt the tyres of 225 is not wrapping this 8" wide rims sufficiently. Quite easily prone to kerb rash even with the thick sidewalls of my Bridgestone RE003 tyres. Hey, i was in the same situation as u. Kerb my rims a few times I recently change to 245/40/18, looks better and rim fully wrapped. 1 Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear March 17, 2018 Share March 17, 2018 Sigh. Have not seen your new ride yet leh.Anytime for you Bro. 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic March 17, 2018 Share March 17, 2018 I know where to look for you for lunch. Anytime for you Bro. Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 19, 2018 Share March 19, 2018 Anytime for you Bro. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear March 19, 2018 Share March 19, 2018 warranty wont be void only valid on Sales and purchase Agreement written clearly any after market parts replaced wont void your warranty. I think they should not void your Sliding door warranty because of your wheels changed from outside , because wheels are not directly connected to your Sliding door. Haha.. Exactly.. Hence I am asking you in your previous quote "Do remember if your car still under warranty especially those ex $ car, your SA may make your Life little difficult should you complaint any thing linked to your wheel and tire. if you have any similar own experience to share that you have claimed warranty due to aftermarket wheels? Maybe I could not think or have not met/heard any car faults that are/ could be link to aftermarket wheels. Cheers. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 20, 2018 Share March 20, 2018 Haha.. Exactly.. Hence I am asking you in your previous quote "Do remember if your car still under warranty especially those ex $ car, your SA may make your Life little difficult should you complaint any thing linked to your wheel and tire. if you have any similar own experience to share that you have claimed warranty due to aftermarket wheels? Maybe I could not think or have not met/heard any car faults that are/ could be link to aftermarket wheels. Cheers. thanks for your sharing again. I personally do not have any issue putting larger wheels up to 19inch on any of my New car still under Warranty. My Quote stated YOur SA May (it depending your Complaints and attitude), because again under Any Sales and Purchased Agreement we are not allow to Install any After market parts or Not approved parts (strictly speaking). Do try them when you send your car for any service and repair by asking car we or allow change bigger or any after market wheels on your new car and see what The SA say. Anyway is just MHO and sharing Link to post Share on other sites More sharing options...
Gene96696 1st Gear March 25, 2018 Share March 25, 2018 I just change my rims to 225/17/50 profile for my 17" OZ Leggera HLT 8J, is this the correct size? I wanted 215 width but Auto Kinetic says 225 is "Fuller" look. Don't quite understand. Any expert advice please? Thanks! Swee Swee Link to post Share on other sites More sharing options...
Axela525 4th Gear March 25, 2018 Author Share March 25, 2018 Swee Swee Thanks...no more changing....will change ride...lol Link to post Share on other sites More sharing options...
Gene96696 1st Gear March 25, 2018 Share March 25, 2018 Thanks...no more changing....will change ride...lolLol cool man . What ride you will be getting ? Link to post Share on other sites More sharing options...
Axela525 4th Gear March 25, 2018 Author Share March 25, 2018 Lol cool man . What ride you will be getting ? no idea....maybe 2nd hand car....thinking of retiring... ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda EZ-6
2025 Mazda EZ-6
MAZDA 6
MAZDA 6
Does rims change shape/warp over time?
