Charmaine12 3rd Gear February 19, 2018 Share February 19, 2018 Anyone knows which will consume more FC? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic February 19, 2018 Share February 19, 2018 Fan consumes electricity. Lower temp increases compressor load cycles, which means more drag on the engine, which means, more fuel consumption. Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 19, 2018 Share February 19, 2018 Fan consumes electricity. Lower temp increases compressor load cycles, which means more drag on the engine, which means, more fuel consumption. Which is better? Link to post Share on other sites More sharing options...
Volvobrick Supersonic February 19, 2018 Share February 19, 2018 This is like asking turn on Air Con better or turn on fan better. Want to be colder turn on both.... Want to save money turn on fan only, or don't turn on anything. Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 19, 2018 Share February 19, 2018 Wear less clothes. Wont feel so hot and less weight better fc. 2 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 19, 2018 Share February 19, 2018 Wear less clothes. Wont feel so hot and less weight better fc. Guys can wear lesser. However woman cannot dun wear bra Link to post Share on other sites More sharing options...
Dannnn 4th Gear February 19, 2018 Share February 19, 2018 I read that some.car compressor no matter low or high temperature set also load same on compressor Link to post Share on other sites More sharing options...
inlinesix Supersonic February 19, 2018 Share February 19, 2018 Guys can wear lesser. However woman cannot dun wear bra Nowadays, more & more women wear tank top to run. No different from wear bra. Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 19, 2018 Share February 19, 2018 Nowadays, more & more women wear tank top to run. No different from wear bra. I think bra will make the woman hotter. Tank top I not sure Link to post Share on other sites More sharing options...
inlinesix Supersonic February 19, 2018 Share February 19, 2018 I think bra will make the woman hotter. Tank top I not sure Hot woman wear 1/4 cup bra with slim bra strap. Hot woman wear tank top & shows her 6 packs. Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 19, 2018 Share February 19, 2018 (edited) I am not sure if it is all but i know some of those climate control aircon cars actually having fixed cycle of compressor clutching on and off regardless of the temperature setting. Essentially what it does is the compressor will generate cold air at constant interval regardless of temperature setting, the system uses hot air to mix with cold air to achieve the desire temperature, that is how it achieve climate control or zoning or split temperature setting. So whether the temperature is set high or low makes no impact or benefit to FCm Edited February 19, 2018 by Ct3833 4 Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 19, 2018 Share February 19, 2018 I am not sure if it is all but i know some of those climate control aircon cars actually having fixed cycle of compressor clutching on and off regardless of the temperature setting. Essentially what it does is the compressor will generate cold air at constant interval regardless of temperature setting, the system uses hot air to mix with cold air to achieve the desire temperature, that is how it achieve climate control or zoning or split temperature setting. So whether the temperature is set high or low makes no impact or benefit to FCm Yup so the best thing to save on fuel is cold temp max and fan speed min. That's what I usually do. If too cold just redirect the vent or close a few. Link to post Share on other sites More sharing options...
Zze121 3rd Gear February 19, 2018 Share February 19, 2018 Change coolant, lower temp thermostat might helps. Link to post Share on other sites More sharing options...
Dannnn 4th Gear February 19, 2018 Share February 19, 2018 For some car i can hear thE compressor turned on sometimes n off again etc, when standing outside the car. But some car totally no such sound? Why ah Link to post Share on other sites More sharing options...
Neutrino Supercharged February 19, 2018 Share February 19, 2018 Can't remember the TV programme name but they compared A/C with open window. Which had higher f/c. Open window had higher f/c iirc. Link to post Share on other sites More sharing options...
Vinceng Turbocharged February 19, 2018 Share February 19, 2018 It works the same way as turning on the fan in an air conditioned room to aid circulation – cools the room faster. For max fuel economy. Set air con temp in car to 25 degrees, and max the fan speed to at least 2 to 3. Good to have an additional fan on board, plugged in to the ciga lighter Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear February 19, 2018 Author Share February 19, 2018 It works the same way as turning on the fan in an air conditioned room to aid circulation – cools the room faster. For max fuel economy. Set air con temp in car to 25 degrees, and max the fan speed to at least 2 to 3. Good to have an additional fan on board, plugged in to the ciga lighter home aircon doesnt work the same as Car aircon. Car Aircon uses radiator heat to adjust the temp. Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 19, 2018 Share February 19, 2018 Yup so the best thing to save on fuel is cold temp max and fan speed min. That's what I usually do. If too cold just redirect the vent or close a few. if too cold, switch off the aircon for a while, when temperature goes up again, turn on aircon again. this will really help save FC. But I am not sure this will accelerate the breakdown of the switch or button or not ↡ Advertisement Link to post Share on other sites More sharing options...
How problematic is VW's 7 speed DSG?
Marriage registration fees in Singapore to increase
No increase in gambling addicts since 2 casinos opened.
8 town councils to increase service & conservancy charges
ERP rates increase/decrease thread monitor!
