GravityBlue 4th Gear February 20, 2018 Share February 20, 2018 How does the variable displacement compressor knows how much to vary with manual control ? Its a much simpler concept. Eg , u set at coldest temp at fan speed 1 , comp will run at max capacity. Once reach low temp setting , control valve inside comp will self adjust operating pressure (internal bypass) to maintain that temp range , it will still continue running. If set temp at 3~4 click up (from max cold temp) , assuming its at 22~23 deg , since no digital LCD to indicate temp. Comp is actually running at max capacity , and it wont stop too. Just that heater flap is partially opened to mix hot & cold air , to achieve your desired temp. The only way to save fuel is to achieve max coolness quickly , then off A/C but fan still running , switch on A/C when u feels slight warm. But u got to do it frequently in a cyclic action. But what's the point of doing that , just to save a mere few CENTS ? I only off A/C , when i need the extra horse during pickup , try that n u'll be amazed by the difference in pulling away. Hope my limited knowledge on A/C helps. ↡ Advertisement Link to post Share on other sites More sharing options...
kdash Supersonic February 20, 2018 Share February 20, 2018 If I am driving alone, usually I will set the about 23 degrees and the lowest fan speed with most of the air vents blowing at me. Sufficient for me to cool down. for me, 25 deg and vary fan speed only. if really hot day and park under the sun then lower to 21 deg until car cools down then back to 25. Link to post Share on other sites More sharing options...
Kklee 6th Gear February 20, 2018 Share February 20, 2018 Its a much simpler concept. Eg , u set at coldest temp at fan speed 1 , comp will run at max capacity. Once reach low temp setting , control valve inside comp will self adjust operating pressure (internal bypass) to maintain that temp range , it will still continue running. If set temp at 3~4 click up (from max cold temp) , assuming its at 22~23 deg , since no digital LCD to indicate temp. Comp is actually running at max capacity , and it wont stop too. Just that heater flap is partially opened to mix hot & cold air , to achieve your desired temp. The only way to save fuel is to achieve max coolness quickly , then off A/C but fan still running , switch on A/C when u feels slight warm. But u got to do it frequently in a cyclic action. But what's the point of doing that , just to save a mere few CENTS ? I only off A/C , when i need the extra horse during pickup , try that n u'll be amazed by the difference in pulling away. Hope my limited knowledge on A/C helps. How the compressor knows that it has reach the low temperature setting? Link to post Share on other sites More sharing options...
GravityBlue 4th Gear February 20, 2018 Share February 20, 2018 How the compressor knows that it has reach the low temperature setting? By pressure differentiate Link to post Share on other sites More sharing options...
Kklee 6th Gear February 20, 2018 Share February 20, 2018 By pressure differentiate That should be the method. I am trying to understand how does the compressor knows when to vary? Link to post Share on other sites More sharing options...
Vidz 6th Gear February 21, 2018 Share February 21, 2018 one word - wind chill factor (erm.. ok 3 words) the least energy to cool is with fan. it requires more energy to cool by compressor. like a bro mention use AUTO, cos you paid for the car and the car makers had already solved it for you. Link to post Share on other sites More sharing options...
Simplecar 4th Gear February 21, 2018 Share February 21, 2018 By pressure differentiate I thought temperature controls is by thermostat? Link to post Share on other sites More sharing options...
GravityBlue 4th Gear February 21, 2018 Share February 21, 2018 I thought temperature controls is by thermostat?That's true, applies to fixed type of comp.For variable type, it serve as a second key to prevent icing, cos the control valve takes center stage. Link to post Share on other sites More sharing options...
Dannnn 4th Gear February 21, 2018 Share February 21, 2018 So just use auto fan, n control the temp will do? Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 21, 2018 Share February 21, 2018 So just use auto fan, n control the temp will do?If the auto function is there, just use it Link to post Share on other sites More sharing options...
GravityBlue 4th Gear February 21, 2018 Share February 21, 2018 Yupper , whether u set at 18 or 25 deg , comp works as usual. Your desired temp setting is achieved thru heated air mix. Even if A/C is off (comp at rest) , most significant gain is actually the torque gain (due to no load from comp). With e exception of older car which uses fixed displacement comp without heater , some fuel saved if u set at higher temp range. Link to post Share on other sites More sharing options...
Kklee 6th Gear February 21, 2018 Share February 21, 2018 That should be the method. I am trying to understand how does the compressor knows when to vary? @GravityBlue - You have any answer to this? Basically, the compressor can vary, but when does it knows when to vary when there is no sensor or feedback? Link to post Share on other sites More sharing options...
GravityBlue 4th Gear February 21, 2018 Share February 21, 2018 (edited) @GravityBlue - You have any answer to this? Basically, the compressor can vary, but when does it knows when to vary when there is no sensor or feedback?Before i compose an essay, can i know u in which trade? If u r technically inclined, i shall use more chim terms ,if not will try to use simple/common description. Btw, youtube is pretty informative. Edited February 21, 2018 by GravityBlue Link to post Share on other sites More sharing options...
Kklee 6th Gear February 21, 2018 Share February 21, 2018 Before i compose an essay, can i know u in which trade? If u r technically inclined, i shall use more chim terms ,if not will try to use simple/common description. Btw, youtube is pretty informative. Admin. I just want to know how the variable displacement compressor knows how much to vary without climate control. Link to post Share on other sites More sharing options...
GravityBlue 4th Gear February 21, 2018 Share February 21, 2018 Admin. I just want to know how the variable displacement compressor knows how much to vary without climate control. What's e problem bro, i had answered all your previous questios diligently . But u give me the impression that u seems to understand / not so understand type. So I'm trying to tailor my answers to your level of understanding, any wrong ? Link to post Share on other sites More sharing options...
Kklee 6th Gear February 21, 2018 Share February 21, 2018 What's e problem bro, i had answered all your previous questios diligently . But u give me the impression that u seems to understand / not so understand type. So I'm trying to tailor my answers to your level of understanding, any wrong ? You never really answer my question. You only answer how the variable displacement compressor work - it varies using gas pressure / pressure differential My question is simply - how does the variable displacement compressor knows when to vary ? Let me then rephrase....what causes the gas pressure / pressure differential so that the variable displacement compressor varies? My previous car has a V5 compressor but no climate control. The V5 doesn't seem to vary because the temperature will go lower and lower at night. If you don't want to answer just say lor. Don't ask me which trade I am in and try to tailor your essay and the next moment ask me what is the problem. 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 21, 2018 Share February 21, 2018 (edited) Anyone knows which will consume more FC?What car you driving? Cos if u specify the model, the members here can advise better Edited February 21, 2018 by RogerNg_185295 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 21, 2018 Share February 21, 2018 Yupper , whether u set at 18 or 25 deg , comp works as usual. Your desired temp setting is achieved thru heated air mix. Even if A/C is off (comp at rest) , most significant gain is actually the torque gain (due to no load from comp). With e exception of older car which uses fixed displacement comp without heater , some fuel saved if u set at higher temp range. Finally someone has come forward to say what I have been telling all these while. Regardless of what you set, 18deg or 25deg, the air con comp works just as much. So just blast it at the coldest setting. And if I find it too cold at times, I turn off the air con switch manually. Before i compose an essay, can i know u in which trade? If u r technically inclined, i shall use more chim terms ,if not will try to use simple/common description. Btw, youtube is pretty informative. Appreciate if you can fill in more with your knowledge. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
How problematic is VW's 7 speed DSG?
Marriage registration fees in Singapore to increase
No increase in gambling addicts since 2 casinos opened.
8 town councils to increase service & conservancy charges
ERP rates increase/decrease thread monitor!
