SGCMHello 4th Gear March 25, 2018 Share March 25, 2018 Anyone knows if dashing across hump will spoil anything in the car? My friend intend to change his car and started to dash across humps, jam brakes, hard acceleration etc. Basically anyhow drive. Then fuel pump start to spoil, then alternator, then one side of lights cannot light up. Hahaha. Is it wear and tear or dashing hump causing all these. Kind of asking for it. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 25, 2018 Share March 25, 2018 Anyone knows if dashing across hump will spoil anything in the car? My friend intend to change his car and started to dash across humps, jam brakes, hard acceleration etc. Basically anyhow drive. Then fuel pump start to spoil, then alternator, then one side of lights cannot light up. Hahaha. Is it wear and tear or dashing hump causing all these. Kind of asking for it. Mostly Suspension Parts may be affected,hey,Humps is to slow down the Car[area may be alot of people],dashing across it is NOT a good Idea.. Link to post Share on other sites More sharing options...
DACH Supersonic March 25, 2018 Share March 25, 2018 Suspension systems confirm damaged. Is he going to scrap the car? Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 25, 2018 Share March 25, 2018 Even he is to scrap the Car,he should not drive like this in Public Roads ...what happen if he broke a Ball joint & the Car lost Control.? Link to post Share on other sites More sharing options...
Watwheels Supersonic March 25, 2018 Share March 25, 2018 Tell your friend to drive off a cliff. Much faster. 5 Link to post Share on other sites More sharing options...
inlinesix Supersonic March 25, 2018 Share March 25, 2018 Is he PRC? Link to post Share on other sites More sharing options...
Friendstar Supercharged March 25, 2018 Share March 25, 2018 Anyone knows if dashing across hump will spoil anything in the car? My friend intend to change his car and started to dash across humps, jam brakes, hard acceleration etc. Basically anyhow drive. Then fuel pump start to spoil, then alternator, then one side of lights cannot light up. Hahaha. Is it wear and tear or dashing hump causing all these. Kind of asking for it. Which car is he changing from? I'll make sure I inform all my relatives colleagues n friends to stay away. 1 Link to post Share on other sites More sharing options...
Mahjong74 Supercharged March 25, 2018 Share March 25, 2018 Anyone knows if dashing across hump will spoil anything in the car? My friend intend to change his car and started to dash across humps, jam brakes, hard acceleration etc. Basically anyhow drive. Then fuel pump start to spoil, then alternator, then one side of lights cannot light up. Hahaha. Is it wear and tear or dashing hump causing all these. Kind of asking for it. Your friend mindset a bit childish leh............... Better don't caused any necessary accident because of his immature and childish behavior and mindset Did he do similar things when he about to dump or break off with all his ex GF??? Side track a bit, I don't mind to treat your friend to good meal and beer, provided he bring my MIL for a 1 day anyhow ride 3 Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 25, 2018 Share March 25, 2018 Chiong hump car would spoilt? More like he never takes care of his car all the while. Link to post Share on other sites More sharing options...
Baleno 4th Gear March 25, 2018 Share March 25, 2018 Rear upper & lower control arms sure damage. Your friend does not seem to be a nice guy from the way he treated things that he intended to let go Link to post Share on other sites More sharing options...
Kb27 Supersonic March 25, 2018 Share March 25, 2018 It's like doing broad jump all the way, instead of walking normally. You keep hitting the body's suspension system..and the knee will go eventually. Link to post Share on other sites More sharing options...
Mockngbrd Supersonic March 25, 2018 Share March 25, 2018 Orbit goot 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 25, 2018 Share March 25, 2018 (edited) Other than dashing over humps, hard acceleration and hard brake , one can imagine that TS friend did a lot more stupid things to the car than what have been mentioned. It is a childish and irresponsible mentality. Many of the MCFers here would hope his car could breakdown completely sooner to reduce a rubish driver from the road. Edited March 25, 2018 by Ct3833 Link to post Share on other sites More sharing options...
SwirL 2nd Gear March 25, 2018 Share March 25, 2018 Lol.. what's next? He will go choose a car to buang into on the day he is going to scrap his car? Link to post Share on other sites More sharing options...
Mkl22 Twincharged March 25, 2018 Share March 25, 2018 (edited) Anyone knows if dashing across hump will spoil anything in the car? My friend intend to change his car and started to dash across humps, jam brakes, hard acceleration etc. Basically anyhow drive. Then fuel pump start to spoil, then alternator, then one side of lights cannot light up. Hahaha. Is it wear and tear or dashing hump causing all these. Kind of asking for it. Fuel pump and alternator is wear and tear. Nobody that I know and that includes mechanics can predict when a fuel pump will spoil. For alternator unless you remove the brushes to check, you also cannot tell when the brushes are worn. All these will never be able to be detected during routine maintenance. Depending on how old the suspension is, knocking sounds will appear as the parts are stressed. Could take some time before effects are see . For hard acceleration, the driveshafts cv joints will be stressed as well as engine mounts. Hard braking won’t really wear out the pads that much unless he goes to track. Edited March 25, 2018 by Mkl22 1 Link to post Share on other sites More sharing options...
kdash Supersonic March 25, 2018 Share March 25, 2018 the friend's butt so much meat... can tahan the humps Link to post Share on other sites More sharing options...
Vratenza Supersonic March 25, 2018 Share March 25, 2018 The problems listed don't seem to be related to the action of dashing across humps. Simply just wear and tear of an aging car. Link to post Share on other sites More sharing options...
Jtb 6th Gear March 26, 2018 Share March 26, 2018 hump has a purpose for us & the vehicle to slow down to prevent injury for us and the vehicle. Without stopping r slowing down will loosen the bolts & nuts as well as loosening our joints and eventually drop off in the cabin! ↡ Advertisement Link to post Share on other sites More sharing options...
Sticker Bomb Cars
Sticker Bomb Cars
How to solve unwanted noises in your car
Dash cam from Online Retailers
Cashcard Machine spoil~~ So Unlucky
Aircon spoil
Aircon spoil
Is my car Suspension Spoil ?
Where to get MCF dash mat?
