  • Search this thread
  • Reply to this topic
20 replies to this topic | 39 praises
#1
Posted 13 April 2018 - 02:59 PM
Kchew21
  • THREAD STARTER
  • Premium member
    Kchew21
    1st Gear
    Author Image
    85
Hi:
Advice needed.
Currently my Jap sedan (Nissan Slyphy) car is on stock 195/60/r16.
Other than petrol increase, will there be any other impact if I will change to the above R17 rim & tires?
Thank you!
#2
Posted 13 April 2018 - 03:29 PM
MQX87511
  • MQX87511
    5th Gear
    Author Image
    1,320
Hi:
Advice needed.
Thank you!
of course you can,
besides FC increase, you will gain better handling and cornering,
if the R17 tyer diameter is different from your original one, you will get Odometer and mileage error,
#3
Posted 13 April 2018 - 03:48 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    28,917
of course you can,
FC increase if new wheels is heavier
#4
Posted 14 April 2018 - 07:40 AM
Colin03
  • Premium member
    Colin03
    4th Gear
    Author Image
    817
Hi Kenchew21,
your pick-up will be must slower causing you more fc.
Is only for nice as your current tyres are good enough for this model of your car.
#5
Posted 14 April 2018 - 08:35 AM
merc280v6
  • merc280v6
    6th Gear
    Author Image
    2,834
- a tad slower acceleration from stop
- higher torque steer for high-torque FWD cars (tendency to shift sideways, upon initial hard acceleration from stop, on wet roads) ... won’t usually get this in B&B cars
- higher aquaplaning tendency (for same tyre thread design)
- costlier tyre changes
- slightly higher FC
- better turn in and cornering
- shorter braking distance
Most WRC cars go on smaller diameter wheels and are shod with narrower tyres, to circumvent many of the said limitations on the slippery mud tracks.
#6
Posted 14 April 2018 - 08:58 AM
Spring
Hi:
Advice needed.
Thank you!
Actually this 205/55/R17 is an odd size, i know cos I’m using this size. Maybe better to get a more common size 17in instead.
<!-- isHtml:1 -->
#7
Posted 14 April 2018 - 09:09 AM
Columbian78
  • Columbian78
    5th Gear
    Author Image
    2,036
205/50/17 is a stock size for b17 sylphy. So you are looking at 1 size profile up. Should be able to fit if stock suspension and height. I had used 215/50/17 before no issues
#8
Posted 14 April 2018 - 12:16 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,635
Brother You very good :a-m1212:
#9
Posted 14 April 2018 - 12:22 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,635
Hi:
Advice needed.
Thank you!
any changes come with a price .
If I am worry , I will stick to same original size but go for better Quality wheels and Tires (99% improvement)
UPsize advantages depends on what the Quality and size you are getting.
your 195/60/16 is already upsize from base model 195/65/15 , so don't see the need for go 17inch ,if you still go 17 take 205/50/17 closest conversion but not common size here (still available)
Don't have to worry to much about the Speedo reading so long is not too far out from Stock.
#10
Posted 14 April 2018 - 12:35 PM
Beregond
  • Beregond
    NOS-ed
    Author Image
    14,022
205.55.17 is the orginal size for stream rsz orginal rim.
17 x 5.5( i think )
Super odd.
If upgrade to 17' rims normally
17 x7 or x7.5
U wont use this size tyres.
#11
Posted 14 April 2018 - 06:13 PM
Kchew21
  • THREAD STARTER
  • Premium member
    Kchew21
    1st Gear
    Author Image
    85
17 x 5.5( i think )
Super odd.
17 x7 or x7.5
Hi:
I like the ride to be Comfy and yet the tires look big...size R17.
Therefore. For R17, what is most comfy tire profile to use? Thank you.
#12
Posted 14 April 2018 - 06:59 PM
Beregond
  • Beregond
    NOS-ed
    Author Image
    14,022
Hi:
u cannot see which size comfty. must see wat car u driving,  wat is your orginal size,
then u convert over.
after u convert, the over all diameter of the old and new size should be +- 3%
how wide your 17'             215, 225,235,245
should depend on your rim width, 7 x 7,7.5, 8 , 8.5 etc
like honda crv orginal size ( old crv ) is 225.65.17
this size very comfty, cos 65 profile very thick .
but u cannot put into for example a civic , cos diameter too big ,
and 205.55.17 is a very odd size,
u gonna have problem replacing it next time
i doubt the shop got any suitable rims for it also .
dun buy it cos they offer cheap, high chance they trying to clear stock :D
( i guess only) :XD:
#13
Posted 14 April 2018 - 08:37 PM
merc280v6
  • merc280v6
    6th Gear
    Author Image
    2,834
Hi:
You cannot liddat ask one lah! 😂
Need to know what is the stock rim size and tyre profile provided, per manufacturer’s design.
Let’s just say (using unverified numbers here):
Stock BMW 3-er comes with 16” wheels and profile-65 tyres
Stock VW Vento comes with 15” wheels and profile-55 tyres
If both are upgraded to 17”, the 3-er will need to be shod with (say) profile-55 tyres ... still deemed comfortable enuf.
The Vento may need to go down to (say) profile-40 tyres ... which will be very crashy indeed! Not comfortable at all 👎🏼
Edited by merc280v6, 14 April 2018 - 08:38 PM.
#14
Posted 14 April 2018 - 09:45 PM
Kchew21
  • THREAD STARTER
  • Premium member
    Kchew21
    1st Gear
    Author Image
    85
You cannot liddat ask one lah! ð
Need to know what is the stock rim size and tyre profile provided, per manufacturerâs design.
Letâs just say (using unverified numbers here):
Stock BMW 3-er comes with 16â wheels and profile-65 tyres
Stock VW Vento comes with 15â wheels and profile-55 tyres
If both are upgraded to 17â, the 3-er will need to be shod with (say) profile-55 tyres ... still deemed comfortable enuf.
The Vento may need to go down to (say) profile-40 tyres ... which will be very crashy indeed! Not comfortable at all ðð¼
Hi: my stock is 195/60/r16. Maybe u can advice the what comfy progile in R17 range? Thank you!
#15
Posted 16 April 2018 - 04:54 PM
SZ_ford
  • SZ_ford
    1st Gear
    Author Image
    93
i switched from 215/60/16 to 225/45/18 to 245/40/18 for my mondeo.
FC - did increase for sure.
Acceleration - didnt feel any slower or maybe it's slower but not significant to me (i didnt measure it)
Comfort - can feel more bumps on the road but not unbearable
grip - a lot better, feel  more confident when cornering
looks - better, at least for me
#16
Posted 16 April 2018 - 05:13 PM
Beregond
  • Beregond
    NOS-ed
    Author Image
    14,022
either 225.45.17 slightly smaller abit.
or 225.50.17 slightly bigger abit ( more comfort )
both size very common and popular, got plenty of choice
( assume u dun buy any funny size rim)
either 17 x7
or more accurate 17 x 7.5
if 17 x 7 , u can go for 215.50.17 also,
also a common size
Edited by Beregond, 16 April 2018 - 05:14 PM.
#17
Posted 16 April 2018 - 05:31 PM
Kchew21
  • THREAD STARTER
  • Premium member
    Kchew21
    1st Gear
    Author Image
    85
either 17 x7
also a common size
Thank you all for your kind advice.
I will not go for funny size rims...I will go with 17 x 7 size rims then ...:)
#18
Posted 16 April 2018 - 05:37 PM
Columbian78
  • Columbian78
    5th Gear
    Author Image
    2,036
Go for 17x7.5. Then use 225/45/17 tyres. Great variety of tyres to choose from and cheap.
If you emphasize looks, go for 18 inch. 17 is best for balance between comfort, perfo and looks.
I am driving same car as you, B17. Rims now are 17x7.5, offset +40.
Car is lowered by 2 fingers, no problem.
#19
Posted 16 April 2018 - 06:28 PM
Kchew21
  • THREAD STARTER
  • Premium member
    Kchew21
    1st Gear
    Author Image
    85
U mean u lower yr car suspension by 2 fingers?
Or u mean by changing to 17 inch rims, the car is lowered by 2 fingers?
#20
Posted 16 April 2018 - 06:54 PM
ntuc2018
  • ntuc2018
    1st Gear
    Author Image
    55
I think got some website will tell u for ur make, what size u can go for. Plus how much error is the speedometer.
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
SSW S007 Eternity
SSW S007 Eternity  |  Rating   Submit Review
Reviewed by Chuckwaggon  |  Neutral Newbie
Worth Spending on
Came across this rim and is decently priced so took it up, quite durable and fits well. The tyre also does not seem to be very heavy for carrying and steering wise seem lighter. I don't know, maybe is my mind playing tricks on me but anyway h... » Read More
SSW E101 Eurotechnik 17
SSW E101 Eurotechnik 17" Rims  |  Rating   Submit Review
Reviewed by Jomar  |  Clutched
Reasonable Priced Rims
Got it changed as I like the design and also not looking into expensive rim due to tight budget. I personally like the design and it is durable so far. Slightly on the heavier side but overall still good. Price wise is reasonable and there is... » Read More
Related Product Guide search on sgCarMart.com : Rim
Quick Reply
Tags: nissan, japanese car, tires, rims and 5 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
