  • 1
  • Search this thread
  • Reply to this topic
12 replies to this topic | 7 praises
#1
Posted 22 April 2018 - 12:37 PM
Ki113r
  • THREAD STARTER
  • Premium member
    Ki113r
    Author Image
    8
Hi guys, my Audi 1.8TFSI was on MTM staged 1 tune.
I did an engine overhaul with new sets of Wossner pistons recently.
Would it be recommended to go for a re-tune of the ECU?
Angcheek praised this
#2
Posted 22 April 2018 - 12:48 PM
UncleAtas
  • Premium member
    UncleAtas
    Supercharged
    Author Image
    6,620
Yes.
Change new guitar strings also need to retune.
Aaronlkl praised this
Refer to signature guidelines
#3
Posted 22 April 2018 - 07:22 PM
Ki113r
  • THREAD STARTER
  • Premium member
    Ki113r
    Author Image
    8
Yes.
Thanks. Premium-MTM says no need to retune. Who should I approach for retune? They will take away my old map right?
#4
Posted 22 April 2018 - 08:03 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    78,833
You changed piston probably of the same spec but of better quality.
I see no reason to retune as the mtm stage 1 is already optimized through test and trial run baaed on original spec.
Unless you lookind at another tune that i feel is reducdant. Stick with the proven one.
QUOTE
do to others what you want others to do to you......
#5
Posted 22 April 2018 - 08:28 PM
Ki113r
  • THREAD STARTER
  • Premium member
    Ki113r
    Author Image
    8
Hmm ok thanks for the tips.
#6
Posted 25 April 2018 - 09:25 PM
Ake109
  • Premium member
    Ake109
    6th Gear
    Author Image
    3,331
2 things IMHO:
The tune from MTM would be optimized for a stock car in new/good condition.
So your new pistons would bring you closer to stock condition assuming you had worn parts. So no need re-tune.
2nd, my understanding is that the ECU for Audis are smart enough to make such minor adjustments, so shouldn't need re-tune.
ANyway, if MTM don't want take your money say no need re-tune, I would believe em!
#7
Posted 01 May 2018 - 06:55 PM
Hmanxx
  • Premium member
    Hmanxx
    4th Gear
    Author Image
    541
If your new pistons come back with different compression ratio, you need to use custom tuning, those canned map (tuner can't change any parameters) will not help.
#8
Posted 20 May 2018 - 02:55 PM
DTA
  • DTA
    Author Image
    9
With Forged pistons, you can run higher timing + higher boost ;-)
#9
Posted 20 May 2018 - 03:36 PM
Ki113r
  • THREAD STARTER
  • Premium member
    Ki113r
    Author Image
    8
But the DQ200 can only take 250NM max?
#10
Posted 22 May 2018 - 10:03 AM
DTA
  • DTA
    Author Image
    9
can take up to 400Nm easily, llike those stage 3 guys
#11
Posted 03 July 2018 - 04:12 PM
Davidtch
  • Premium member
    Davidtch
    2Fast2Furious
    Author Image
    32,256
RadX
#12
Posted 10 July 2018 - 05:23 PM
r0bie86
  • r0bie86
    Author Image
    0
hi bros, as far as my knowledge goes, dont need to retune. my tuner at kaki bukit advice me when i ask him the same thing and hes quite experienced. I had stage 1 non-MTM but i changed to wossner pistons oso. the mapping stays in the ecu microchip, wont lose one even if car complete reset.
no point retuning because Ake109 say one...…..Audi ECU quite smart.
#13
Posted 12 July 2018 - 05:22 PM
Hmanxx
  • Premium member
    Hmanxx
    4th Gear
    Author Image
    541
You didnt really interpret your tuner remarks correctly.
1. Point of program stayed in Non-Volatile memory is Valid . Your program is not stayed on RAM ( Power off , no more).
2. Stage-1 non-MTM settings could be not fully optimized to push to limit, as such quite a large range of  Piston  Compression ratio could be run with the Map. Typically stock map is doing so.
Your tuner might have statistic on this and do this recommendation.
I believe in science , I will not make bold assumption but experiment it out . At least run through data log to confirm the map can match the new hardware.
  • 1
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: audi, mtm, apr, tune, stage
1 user(s) are reading this topic
    Google (1)
