  • Search this thread
  • Reply to this topic
42 replies to this topic | 109 praises
#1
Posted 03 May 2018 - 05:39 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
Hi guys,
Anyone can recommend where can I change my front brake pads? I believe they need to be replaced. My car is Honda Civic FD4.
And my tyres are producing sounds when I drive at higher speed. Normally the sounds will come out when I drive above 80/90km/h. Is it because it needed to do tyre rotation or alignment? Please share the info if you know. Thank you so much
#2
Posted 03 May 2018 - 07:36 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,201
i suggest you go stockist and buy the brake pads than ask workshop to install for you.
are you sure the sound is from tyres and not wheel bearing noise?
Volvobrick praised this
#3
Posted 03 May 2018 - 08:48 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    50,157
Simi sound? Troubleshooting based on sound is not easy. Somemore your description is so vague. Yours is accelerate to 90km/hr got sound why does it got to do with brake pads?
One thing to do is not anyhow tikum and say brake pads to the mechanic. Not all mechanics are good ppl. You tell them brake pads they will replace them for you. They dun care still got sound or not.
"You tell me it's the brake pads so I change them lo." Based on what you say coz you are the boss.
Your problem not fixed and you go back to them they will continue to [knife] you into little pieces.
Just say there are noise coming from wherever at this speed. Go take a drive with the mechanic if he's available.
lausai88 and kobayashiGT praised this
#4
Posted 03 May 2018 - 08:50 PM
Optramagnum
  • Premium member
    Optramagnum
    5th Gear
    Author Image
    2,362
Actually you can check the pads by looking thru your rims. Unless you are using those wheel cap type.. Any workshop can do the change job, quite straightforward.
#5
Posted 03 May 2018 - 09:18 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    50,157
Ppl are often too lazy to read and browse the internet they expect instant answers from forums. Even if you expect instant answers you also need to write something descriptive so that ppl can at least understand. There are so many words you can use to describe a noise.
#6
Posted 03 May 2018 - 10:01 PM
zipping
  • zipping
    2Fast2Furious
    Author Image
    24,679
Hi guys,
best go 2 a reliable ws n hav e guys there chk it out.....
i had some sound issue similar 2 urs not too long ago...as i drive faster e sound gets louder. end up brought 2 a ws to chk, e mech test drv w me to single out e "noise"..end up is wheel bearing worn....
#7
Posted 04 May 2018 - 12:43 AM
Jumpmanz
  • Premium member
    Jumpmanz
    6th Gear
    Author Image
    2,645
civic wheel bearing worn is pretty common. around 100k need to change. i did mine in jb so its significantly cheaper.
#8
Posted 04 May 2018 - 09:24 AM
UncleAtas
  • Premium member
    UncleAtas
    Supercharged
    Author Image
    7,135
TS is asking 2 separate things.
1) Which workshop recommended to change brake pad.
2) There is sound coming from the wheels when travelling above 90km/h.
Andyong praised this
Refer to signature guidelines
#9
Posted 05 May 2018 - 09:14 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
Well i'm not sure bro..it's just when I speed up, I can hear a sound coming from behind..the faster I go, the louder the sound. So I thought is it because my tyres need alignment or rotation.
Jamesc and 1 Anonymous member praised this
#10
Posted 05 May 2018 - 09:19 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
I assume brake pads coz last 2 servicing, the mechanic ever mention that my brake pads next time might need to change so since it was like a year ago, I thought may be it's time to change. But the sound that I mention, i do not assume it's from brake pads..actually I don't know what is that, that's why I ask here, and what I know, is it because my tyres need alignment or rotation.
But thanks man for your input, I agree what you say.
#11
Posted 05 May 2018 - 09:21 PM
Jamesc
  • Premium member
    Jamesc
    2Fast2Furious
    Author Image
    167,086
I also have the same sound.
The faster I go the louder the noise is.
That's the exhaust pipe.
The other source when I go faster and the louder it get
is my MIL in the back seat.
:D
Say no to harsh artificial chemicals
that pollute the earth
and go natural. [thumbsup]
#12
Posted 05 May 2018 - 09:24 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
Thank you bro for your info
Thanks for your info bro. Don't mind can share with me where did you do it?did you bring your own or the ws supply all the parts and labour?
#13
Posted 06 May 2018 - 11:59 PM
Baleno
  • Baleno
    4th Gear
    Author Image
    677
Hi guys,
Sound like wheel bearing problem because happen to my car. Noise louder when above 70kph.
Better have it fixed as it can cause car to lose control on wet road.
#14
Posted 29 May 2018 - 04:59 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
Bros, just to update that i went to ws and the mech told me not the bearing problem. Its the rear tyre problem. They asked me to change both rear tyres.The mech said bearings are fine. Anyone can share some input?my tyres changed around 1-2years ago
#15
Posted 29 May 2018 - 05:40 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    33,524
swap the rear tyres to the front.
if the sound goes to the front or go away, then it's the tyres.
if the sound is still at the rear, it's probably the bearings.
#16
Posted 29 May 2018 - 08:16 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
The mech said its useless to rotate so i didnt do it. But he confirm not bearing coz when he rotate the tyre using his hand, he said he can feel rotatting smoothly. If bearing problem, he said he could feel the tyre not rotating smoothly. He just asked me to change the rear tyres. He didnt sell tyres btw, just when i serviced my car he checked for me when i told him i heard sounds from hear tyres
#17
Posted 29 May 2018 - 09:02 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,201
are both your front and rear tyres different brands? also are both the front and rear using same type of size and profile?
#18
Posted 29 May 2018 - 09:03 PM
Franwilliam
  • THREAD STARTER
  • Premium member
    Franwilliam
    1st Gear
    Author Image
    64
My 4 tyres are all same brands and using the exacts profile
#19
Posted 29 May 2018 - 09:08 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,201
ok. have you inspected the rear tyres compared to the front? any difference? if no. unlikely is the tyre noise. it could be some other parts creating the noise?
Edited by StreamRSZ, 29 May 2018 - 09:08 PM.
#20
Posted 29 May 2018 - 10:39 PM
Spinelli_ck
  • Premium member
    Spinelli_ck
    6th Gear
    Author Image
    3,401
how did the mechanic verify that the sound issue is due to the rear tyres? what is the exact issue?
it is much cheaper to rotate the tyres than to buy a pair of new tyres wor.
Dynamics Mechanic Pte Ltd
HELLA PAGID Brake Pads
HELLA PAGID Brake Pads  |  Rating   Submit Review
Reviewed by Peterlim808  |  1st Gear
Good product from Hella Pagid
Got this brake pad together with the brake disc from PAGID. Was sceptical on this brand as I did not hear much on it before and went to do a bit of research. Realised that this brand is actually supplies OEM parts for major automotive car mak... » Read More
Akebono Pro-ACT Ultra Premium Brake Pads
Akebono Pro-ACT Ultra Premium Brake Pads  |  Rating   Submit Review
Reviewed by TurboLag  |  Neutral Newbie
Good OEM replacement
Used it on Lancer CS3 to replace OEM pads. Braking performance is just normal on these pads. Price may be a little high for normal brake pads, if you want to get performance brake pads, just have to top up a little more. But these brake pads... » Read More
Related Product Guide search on sgCarMart.com : Brake Pad
Quick Reply
Tags: honda, hondabrake, honda civic and 4 more...
