golden_eagle 2nd Gear May 5, 2018 Share May 5, 2018 For example the Heritage East, which is a Conservation Shophouse. What are the pros and cons? Will the government forbid you enbloc or certain renovations or require particularly good maintenances? ↡ Advertisement Link to post Share on other sites More sharing options...
LPPL 6th Gear May 5, 2018 Share May 5, 2018 Higher maintenance over time and difficult to enbloc? Link to post Share on other sites More sharing options...
pwrlara1990 1st Gear May 8, 2018 Share May 8, 2018 I believe you might be limited to the amount of structural change you can do to such conservation houses. renovation to the exterior is highly likely a no go. and the interior is rather dependent. theres a row of shophouses along geylang 24A that's bought over by a developer and the interiors are renovated rather beautifully for residential purposes. you might want to go take a look Link to post Share on other sites More sharing options...
13177 Supersonic May 8, 2018 Share May 8, 2018 Higher maintenance over time and difficult to enbloc? If it is called Conservation Shophouse, dont think it will get enbloc liao. Link to post Share on other sites More sharing options...
audioo 1st Gear July 15, 2018 Share July 15, 2018 If it is called Conservation Shophouse, dont think it will get enbloc liao. No en bloc potential, high maintenance fee. hefty reno cost before you can rent it out. Link to post Share on other sites More sharing options...
DACH Supersonic August 6, 2018 Share August 6, 2018 Expensive, inflexible and difficult to enbloc. Link to post Share on other sites More sharing options...
Throttle2 Supersonic August 8, 2018 Share August 8, 2018 I tell you whats the biggest issue for me when i was looking to buy one. The Parking. Imagine going home and having to drive around looking for parking. And finding one which is 50m away from your house. That sucks The ones with reserved parking are usually above $5mil a pop. ↡ Advertisement Link to post Share on other sites More sharing options...
Properties info
Properties info
Mercs: property news & updates
my renovation before and after pics
Renovation budget that blows your mind
