  • Search this thread
  • Reply to this topic
51 replies to this topic | 106 praises
#1
Posted 18 May 2018 - 09:28 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
AC was not cold a few days back so went to a car ac shop near my workplace. Mechanic checked and said ac gas not enough and need to top up. However he also told me that it’s usually a leakage somewhere as car do not need to top up ac gas at all. Ask me to monitor. Is what he said true on the car do not need to top up ac gas at all if there is no leak?
#2
Posted 18 May 2018 - 09:39 PM
RogerNg_185295
  • Premium member
    RogerNg_185295
    5th Gear
    Author Image
    1,538
Which ac shop is that?
#3
Posted 18 May 2018 - 09:48 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
In Defu Lane 10. Whats up?
#4
Posted 19 May 2018 - 01:07 AM
supersen
  • supersen
    1st Gear
    Author Image
    82
any air con specialist in the west?
will be good that can repair compressor as well or get a 2nd hand compressor for my lancer glx
thanks guys appreciate any input !
#5
Posted 19 May 2018 - 10:22 AM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,602
If there is no leak,  there should not be a need to top up.
I think the issue is whether it is a slow or fast leak.
My concern is leak due to wear and tear when the vehicle gets older when the seals degrade.
Discoburg praised this
#6
Posted 19 May 2018 - 10:41 AM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
Yeah I also read that the ac is close loop, shouldn’t need to top up.
#7
Posted 19 May 2018 - 11:08 AM
Mkl22
  • Mkl22
    Author Image
    9,135
Yeah I also read that the ac is close loop, shouldnât need to top up.
Fridges are 100% closed as the compressor is hermetically sealed.
Home aircon is close to 100% as there are still joints. In a car for sure there are more joints and vibration causing a little more leaks over the years.
So for a car Aircon over a long period of time the Aircon gas does get a little depleted.
It depends on how old your car is. So it’s normal for an old car to have the gas depleted.
Discoburg, Columbian78 and BanCoe praised this
#8
Posted 19 May 2018 - 01:14 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
It depends on how old your car is. So itâs normal for an old car to have the gas depleted.
Mine is 2 years and 7 months.
#9
Posted 19 May 2018 - 01:40 PM
Mkl22
  • Mkl22
    Author Image
    9,135
seems Likely a leak then. Monitor how long it takes for it to become warm again. Next step will be to go back and inject a dye to see where the leak is.
Edited by Mkl22, 19 May 2018 - 01:41 PM.
#10
Posted 19 May 2018 - 01:45 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
Thanks for the advice. If near future ac not cold then will have to find an ac shop to solve the leak problem.
#11
Posted 19 May 2018 - 01:52 PM
Fitvip
  • Fitvip
    Author Image
    7,979
If there is a leak, normally, the air-con mechanic is able to trace where the leak is. The rate of leak will increase. No point topping up repeatedly.
The common place where the refrigerant leaks is at the fan coil, the one under the dash.
Mine leaked when the car was about 9 years old. Replaced the coil and it functions normally again.
#12
Posted 19 May 2018 - 02:23 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    52,907
AC was not cold a few days back so went to a car ac shop near my workplace. Mechanic checked and said ac gas not enough and need to top up. However he also told me that itâs usually a leakage somewhere as car do not need to top up ac gas at all. Ask me to monitor. Is what he said true on the car do not need to top up ac gas at all if there is no leak?
Yes it’s true.
No need to top up at all.
Either the cooling coil or condenser.
#13
Posted 19 May 2018 - 02:27 PM
RogerNg_185295
  • Premium member
    RogerNg_185295
    5th Gear
    Author Image
    1,538
That one have to dismantle whole dashboard
#14
Posted 19 May 2018 - 03:09 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    32,774
My experience with a/c gas leak is the evaporator coil.
Bcuz that place is often wet due to the a/c hot/cold.
The wetness eventually corrode the coil and pipes and then it leaked.
#15
Posted 19 May 2018 - 03:26 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    79,014
I changed once the condenser of my c4.
The one side by side with radiator.
QUOTE
do to others what you want others to do to you......
#16
Posted 19 May 2018 - 03:28 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    52,907
But if 2 years 7 months should still be under warranty.
#17
Posted 19 May 2018 - 07:33 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
Will try my luck with AD as I never go back to do servicing with them after the 10K.
Any recommended workshop to let them check?
#18
Posted 19 May 2018 - 07:47 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    52,907
I go to Kim Aircon at Ubi bro.
He managed to solve all of my aircon issue.
http://www.sgcarmart...s.php?MID=11500
#19
Posted 19 May 2018 - 08:56 PM
Discoburg
  • THREAD STARTER
  • Discoburg
    NOS-ed
    Author Image
    18,715
Will visit Kim the following week after my osaka trip. Thanks for the recommendation.  :a-m1212:
#20
Posted 19 May 2018 - 09:30 PM
Cypher
  • Premium member
    Cypher
    4th Gear
    Author Image
    574
The last time my aircon leaked, the compressor is somewhat affected due to lack of refrigerant/lubricant. After repair cannot get the same level of cooling as before..
Discoburg, BanCoe and 1 Anonymous member praised this
I'm a healthy student.
Dynamics Mechanic Pte Ltd
Designer ICE Enterprise LLP
Designer ICE Enterprise LLP  |  Rating   Submit Review
Reviewed by Senghui  |  Neutral Newbie
First vist from a friend recommendation. Front speakers and tweeter not working with intermittent front display and radio screen going off. Extreme messy wiring from ex owner of my car. Spoke to Raymond about my problems and he patiently explained the possible root cause and how he can assist to rectify. End result was great and reasonably priced without hard selling. I... » Read More
Precise Auto Service
Precise Auto Service  |  Rating   Submit Review
Reviewed by shengfoo  |  Neutral Newbie
Got my car to service here again and again. Just super impress by their services and it takes short time to be done as well. The price is reasonable, the waiting room is comfortable, the customer services are helpful and more. Just great to have this workshop available in Singapore. » Read More
Related Motor Directory search on sgCarMart.com : Air Conditioning
Quick Reply
Tags: cold, hot, aircon, air-con and 1 more...
