Neutrino Supercharged June 3, 2018 Share June 3, 2018 (edited) I'm still on SH cable and use TP plugs to send signal to study and bedroom. Get 80mbps easily in all rooms so enough for me. If I change to fibre I suppose I would have to change the TP plugs???? because a fibre router wouldn't send signal through two pre cast concrete walls would it???? or if it did the signal would be substantially degraded?? Any free fibre installations around now? Edited June 3, 2018 by Neutrino ↡ Advertisement Link to post Share on other sites More sharing options...
Phluvcat 6th Gear June 3, 2018 Share June 3, 2018 I'm still on SH cable and use TP plugs to send signal to study and bedroom. Get 80mbps easily in all rooms so enough for me. If I change to fibre I suppose I would have to change the TP plugs???? because a fibre router wouldn't send signal through two pre cast concrete walls would it???? or if it did the signal would be substantially degraded?? Any free fibre installations around now? Wah you still on cable. ST told me early Apr this year phase out cable and I just changed to fibre...sibeh gin! Link to post Share on other sites More sharing options...
inlinesix Supersonic June 3, 2018 Share June 3, 2018 I'm still on SH cable and use TP plugs to send signal to study and bedroom. Get 80mbps easily in all rooms so enough for me. If I change to fibre I suppose I would have to change the TP plugs???? because a fibre router wouldn't send signal through two pre cast concrete walls would it???? or if it did the signal would be substantially degraded?? Any free fibre installations around now? I think cable is more ex than fibre. To change to cable, you need to have fibre junction box installed. From the junction box, it needs to go into a modem before going into TP plugs. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 3, 2018 Share June 3, 2018 I'm still on SH cable and use TP plugs to send signal to study and bedroom. Get 80mbps easily in all rooms so enough for me. If I change to fibre I suppose I would have to change the TP plugs???? because a fibre router wouldn't send signal through two pre cast concrete walls would it???? or if it did the signal would be substantially degraded?? Any free fibre installations around now? The fibre terminates in a ONT. Then outputs a cat 5/6 to be connected to a regular router, if you want them to split to wired or wireless ethernet to multiple devices. ONT is just like your cable modem. But it convert fibre signal to ethernet while cable modem converts RF signal to ethernet. So anything after the ethernet is the same. I assume your TP plugs is connected using the AC lines with ethernet interface. In that case, you can still use the same TP plugs. 1 Link to post Share on other sites More sharing options...
Zxcvb Turbocharged June 3, 2018 Share June 3, 2018 $29 500mbps per month M1. No problems at all. Speed is more than enuff. Pay more for 1GB can't feel any difference, getcthe cheapest will do. 5 Link to post Share on other sites More sharing options...
ALTK Turbocharged June 3, 2018 Share June 3, 2018 $29 500mbps per month M1. No problems at all. Speed is more than enuff. Pay more for 1GB can't feel any difference, getcthe cheapest will do. Bro u using the M1 provided router? Did u check what’s the uploading and downloading speed on WiFi? Im currently using SH...may wanna jump ship. 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 3, 2018 Author Share June 3, 2018 Thats right. Am on the 1Gbps plan at $39.90 per month. At that price, it is 1GB now. Finding excuse to go mah. If not the Mrs won't let me go one. She scared i buy back more useless toys. U can sign up on m1 website.. Not necessary to go to pc show Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 3, 2018 Share June 3, 2018 (edited) different times. different speed. Bro u using the M1 provided router? Did u check what’s the uploading and downloading speed on WiFi? Im currently using SH...may wanna jump ship. Edited June 3, 2018 by Ysc3 1 Link to post Share on other sites More sharing options...
Tiger1 6th Gear June 3, 2018 Share June 3, 2018 I'm still on SH cable and use TP plugs to send signal to study and bedroom. Get 80mbps easily in all rooms so enough for me. If I change to fibre I suppose I would have to change the TP plugs???? because a fibre router wouldn't send signal through two pre cast concrete walls would it???? or if it did the signal would be substantially degraded?? Any free fibre installations around now? I am with SH 1g fibre. You can call them to recontact. As for bandwidth, I am staying in a 115sqm house and connection is very strong throughout the entire house. Router in the living room and I can still receive inside my toilet when I am having my private "meeting". I recommend using Asus router. Average speed I and getting easily 175 download and 350 upload. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic June 4, 2018 Share June 4, 2018 different times. different speed. What device you used? Usually download and upload speed difference will not be that wide. Link to post Share on other sites More sharing options...
Mustank Hypersonic June 4, 2018 Share June 4, 2018 prawn tube? Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 4, 2018 Share June 4, 2018 What device you used? Usually download and upload speed difference will not be that wide. my desktop pc. the speed readings very inconsistent. i'll try to get one tmr morning when d/l is supposed to be faster !! Link to post Share on other sites More sharing options...
inlinesix Supersonic June 4, 2018 Share June 4, 2018 my desktop pc. the speed readings very inconsistent. i'll try to get one tmr morning when d/l is supposed to be faster !! For PC with ethernet connection, it should be as close as your plan. Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 4, 2018 Share June 4, 2018 For PC with ethernet connection, it should be as close as your plan. yup ... I am wired up with a cat7 cable ... and on a good day/time, my d/l reading will be as high as 9xx mbps !! Link to post Share on other sites More sharing options...
inlinesix Supersonic June 4, 2018 Share June 4, 2018 yup ... I am wired up with a cat7 cable ... and on a good day/time, my d/l reading will be as high as 9xx mbps !! I am not sure what cable i am using. Just plug mine into wifi router. I got 884 download and 932 upload. That's SH broadband. Link to post Share on other sites More sharing options...
Lala81 Hypersonic June 4, 2018 Share June 4, 2018 SH has a 28 dollar plan also right. I won't change if i were u. 1 Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 4, 2018 Share June 4, 2018 I am not sure what cable i am using. Just plug mine into wifi router. I got 884 download and 932 upload. That's SH broadband. cat6 up to 1gbps, cat7 is up to 5gbps? anyway, I sign up 1gbps is coz I am hoping it can help with the video feeds on my ipcams I have at home. 1 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 4, 2018 Author Share June 4, 2018 SH has a 28 dollar plan also right. I won't change if i were u. Not sure about the $28 plan. Why shouldn’t I change? ↡ Advertisement Link to post Share on other sites More sharing options...
Fibre broadband
Fibre broadband
MyRepublic Vs Whizzcomms
I got charged for Global SMS by Singtel, and they cannot do anything!
yuu Rewards Club app
Broadband provider WhizComms’ server breached by third party; customers’ information stolen
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
M1 fiber broadband down? 21 Dec 2020
