Jman888 Moderator June 18, 2018 Share June 18, 2018 I don't have fibre. Starhub cable is fine for my needs. But I use Home plugs for room to room coverage. Simple to set up and no problems. Can't you use them with fibre??? If I ever upgrade to fibre, which will only be if Starhub discontinues cable BB. then I'd use Home plugs for room to room coverage. Starhub contractor suppose to come to check if the trunking can be used for the new data lan cable. The contractor say no problem can even squeeze in 2 line if i want, I ask them if they can remove the coax cables but they dun dare to remove it. Apparently the contractor still differentiate starhub and the old SCV, he keep saying the the coax cable belongs to SCV so he can only lay the data cable using the same trunking, job done in 20min and left. I didn't commit to re-contract and they already have the data point done Oh btw the guy told me about 50% of the island already on fiber, and the old coax cable will be phase out by end of the year or next year, not sure how true. ↡ Advertisement Link to post Share on other sites More sharing options...
Mustank Hypersonic June 19, 2018 Share June 19, 2018 M1 shares notndoing well as I like it to be Should I hold or should I release? Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 19, 2018 Share June 19, 2018 M1 shares notndoing well as I like it to be Should I hold or should I release? share with me lah ! 1 Link to post Share on other sites More sharing options...
Neutrino Supercharged June 19, 2018 Share June 19, 2018 Starhub contractor suppose to come to check if the trunking can be used for the new data lan cable. The contractor say no problem can even squeeze in 2 line if i want, I ask them if they can remove the coax cables but they dun dare to remove it. Apparently the contractor still differentiate starhub and the old SCV, he keep saying the the coax cable belongs to SCV so he can only lay the data cable using the same trunking, job done in 20min and left. I didn't commit to re-contract and they already have the data point done Oh btw the guy told me about 50% of the island already on fiber, and the old coax cable will be phase out by end of the year or next year, not sure how true. Thanks for that. Did the contractor charge you for running the new data lan cables which I presume are for fiber??? And did they do the data point for you which again I presume is for fiber??? Link to post Share on other sites More sharing options...
Jman888 Moderator June 19, 2018 Share June 19, 2018 Thanks for that. Did the contractor charge you for running the new data lan cables which I presume are for fiber??? And did they do the data point for you which again I presume is for fiber??? No charge for running the 2nd fiber data lan (free for certain length which i can't remember), main one has to be less than 2m away from ONT point. Can call their sales hotline for more detail. 1 Link to post Share on other sites More sharing options...
DACH Supersonic June 19, 2018 Share June 19, 2018 (edited) M1 shares notndoing well as I like it to be Should I hold or should I release? You go become M1 CEO and DIY the share prices problems. Edited June 19, 2018 by DACH Link to post Share on other sites More sharing options...
Mustank Hypersonic June 19, 2018 Share June 19, 2018 (edited) You go become M1 CEO and DIY the share prices problems. ðWah piangz! If I so satki, I drive g class liao loh Edited June 19, 2018 by Mustank 1 Link to post Share on other sites More sharing options...
Jman888 Moderator June 28, 2018 Share June 28, 2018 after recontract with 1Gbps and linksys router, the wifi speed i get is quite slow although detected speed is 800mbps+, actual speed test is almost the same as when i was on 300Mbps plan. i understand my ipad mini (1st gen) and iMac (2009) has its limitation (iMac can't even detect 5Ghz network). Could it be the setting on the router or the devices, or the position of the router? Not really bother me since i pay the same price as before and the speed very minimum slight better than before Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 28, 2018 Share June 28, 2018 after recontract with 1Gbps and linksys router, the wifi speed i get is quite slow although detected speed is 800mbps+, actual speed test is almost the same as when i was on 300Mbps plan. i understand my ipad mini (1st gen) and iMac (2009) has its limitation (iMac can't even detect 5Ghz network). Could it be the setting on the router or the devices, or the position of the router? Not really bother me since i pay the same price as before and the speed very minimum slight better than before actually a lot of devices cannot detect 5ghz ... all my ipcams cannot detect 5ghz. and i think all these speed detecting website all buay zhun one ... per my previous captures, my d/l speed only about 200 mbps on my 1gbps plan ... but i can d/l a 2gb file very fast. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic June 28, 2018 Share June 28, 2018 after recontract with 1Gbps and linksys router, the wifi speed i get is quite slow although detected speed is 800mbps+, actual speed test is almost the same as when i was on 300Mbps plan. i understand my ipad mini (1st gen) and iMac (2009) has its limitation (iMac can't even detect 5Ghz network). Could it be the setting on the router or the devices, or the position of the router? Not really bother me since i pay the same price as before and the speed very minimum slight better than before Even iPhone x, the best I could hit is 150mbps. It is limitation of router. If you use Ethernet port, the speed is close to 1gbps. It is strange that 5Ghz cannot be detected Link to post Share on other sites More sharing options...
Jman888 Moderator June 28, 2018 Share June 28, 2018 Even iPhone x, the best I could hit is 150mbps. It is limitation of router. If you use Ethernet port, the speed is close to 1gbps. It is strange that 5Ghz cannot be detected really that bad! my ipad get around 100mbps, and iMac around 200-300mbps, but Android phone can get around 600mbps though. old devices cannot detect 1Gbps 5Ghz network but were able to connect to the 300mbps 5Ghz network, dun understand why actually a lot of devices cannot detect 5ghz ... all my ipcams cannot detect 5ghz. and i think all these speed detecting website all buay zhun one ... per my previous captures, my d/l speed only about 200 mbps on my 1gbps plan ... but i can d/l a 2gb file very fast. Link to post Share on other sites More sharing options...
Vratenza Supersonic June 28, 2018 Share June 28, 2018 I never save on my router because that is usually the bottleneck for whatever internet connectivity you are paying the telcos for. Have been using this Asus RT-AC88U since launch and it has served me well for all my surfing and wifi streaming needs in the house. https://www.asus.com/sg/Networking/RT-AC88U/ It has built in Link Aggregation trunking which I connect to my managed switch and on to my NAS for 2Gbps throughput all said....people who knows me will know that I usually over-spec my tech purchase and setup....LOL...it's always a want rather than a need. really that bad! my ipad get around 100mbps, and iMac around 200-300mbps, but Android phone can get around 600mbps though. old devices cannot detect 1Gbps 5Ghz network but were able to connect to the 300mbps 5Ghz network, dun understand why 1 Link to post Share on other sites More sharing options...
Ysc3 Twincharged June 28, 2018 Share June 28, 2018 really that bad! my ipad get around 100mbps, and iMac around 200-300mbps, but Android phone can get around 600mbps though. old devices cannot detect 1Gbps 5Ghz network but were able to connect to the 300mbps 5Ghz network, dun understand why my handphones can detect 5mhz but the connection is not stable ... so I just stick to the 2.4mhz instead. I guess, that's just one of the aces hidden up the manufacturers' sleeves to push out one upgraded standard in the near future to squeeze more money out of the consumers ... maybe they will call it "Wireless 5.1 ?" Link to post Share on other sites More sharing options...
inlinesix Supersonic June 28, 2018 Share June 28, 2018 really that bad! my ipad get around 100mbps, and iMac around 200-300mbps, but Android phone can get around 600mbps though. old devices cannot detect 1Gbps 5Ghz network but were able to connect to the 300mbps 5Ghz network, dun understand why I use Linksys router from Starhub. Both 2.4 and 5 also stable Link to post Share on other sites More sharing options...
Ash2017 Twincharged June 28, 2018 Share June 28, 2018 Really hate to fall on to your router without wearing pants, sure tear beyond repair I never save on my router because that is usually the bottleneck for whatever internet connectivity you are paying the telcos for. Have been using this Asus RT-AC88U since launch and it has served me well for all my surfing and wifi streaming needs in the house. https://www.asus.com/sg/Networking/RT-AC88U/ It has built in Link Aggregation trunking which I connect to my managed switch and on to my NAS for 2Gbps throughput all said....people who knows me will know that I usually over-spec my tech purchase and setup....LOL...it's always a want rather than a need. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic June 28, 2018 Share June 28, 2018 You sure have some weird fetish to be walking pantless around a router..... Really hate to fall on to your router without wearing pants, sure tear beyond repair Link to post Share on other sites More sharing options...
Ash2017 Twincharged June 28, 2018 Share June 28, 2018 You sure have some weird fetish to be walking pantless around a router..... I know otherwise how to appear genuine when visiting you. By the way waiting for your excellent DIY project for a very very long time 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 10, 2018 Share November 10, 2018 https://www.straitstimes.com/business/companies-markets/starhub-to-stop-cable-services-from-july-next-year Q: What is needed to set up fibre service? A: Customers need a termination Point (TP) installed in their homes. Those without a TP can check if their addresses are ready for fibre services by entering their postal code at http://www.netlinktrust.com/ If the customers’ address is eligible, StarHub technicians will take care of the installation and activation of fibre services. Charges will be waived for the installation of the first TP and the optical network terminal for eligible customers. ↡ Advertisement Link to post Share on other sites More sharing options...
Fibre broadband
Fibre broadband
MyRepublic Vs Whizzcomms
I got charged for Global SMS by Singtel, and they cannot do anything!
yuu Rewards Club app
Broadband provider WhizComms’ server breached by third party; customers’ information stolen
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
M1 fiber broadband down? 21 Dec 2020
