  • 1
  • Search this thread
  • Reply to this topic
10 replies to this topic | 0 praises
#1
Posted 08 July 2018 - 06:22 PM
Shawrac
  • THREAD STARTER
  • Premium member
    Shawrac
    4th Gear
    Author Image
    564
Can Anyone VW car owners, advise if u had such experience code?
The code came out but it goes away after some distance. But this had been coming back a few time already.
As no error code when I drive to workshop. They can’t check for me!!!
Don’t feel comfortable.
Thanks
Changes so far:
K&N Air filter, KW Spring, 17" BBS Rims
#2
Posted 08 July 2018 - 06:31 PM
Sdf4786k
  • Premium member
    Sdf4786k
    Author Image
    9,203
Thanks
select the car pic.. the error should be there till you switch off the car
#3
Posted 09 July 2018 - 01:26 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    50,126
Don't the mechanics check for cracked vacuum hose when some intermittent "brake servo failure" code occurs?
#4
Posted 09 July 2018 - 03:07 PM
Shawrac
  • THREAD STARTER
  • Premium member
    Shawrac
    4th Gear
    Author Image
    564
Cracked vacuum hose. Wow. This sound bad!!
Will look into it
Don't want to be in bad shape then found the problem
Changes so far:
#5
Posted 09 July 2018 - 03:16 PM
Beregond
  • Beregond
    NOS-ed
    Author Image
    17,274
Thanks
check if your car brake fluid low or not. if low just top up and monitor a while first before doing any major stuff
#6
Posted 09 July 2018 - 07:16 PM
Shawrac
  • THREAD STARTER
  • Premium member
    Shawrac
    4th Gear
    Author Image
    564
Good advise. Something that I had outlook
Changes so far:
#7
Posted 09 July 2018 - 08:40 PM
Ct3833
  • Ct3833
    Author Image
    7,528
I thought mechanic is able to dump out error code from OBD?
#8
Posted 10 July 2018 - 03:54 PM
Keithchue
  • Premium member
    Keithchue
    6th Gear
    Author Image
    2,808
all codes are stored in the ODB, just need a scanner for reading them out.  all pro VAG cars are built this way
every day wont be the same after you make a wrong decision.
#9
Posted 10 July 2018 - 07:23 PM
Shawrac
  • THREAD STARTER
  • Premium member
    Shawrac
    4th Gear
    Author Image
    564
Thanks for the advice!
Cos when I went down, the error code is gone after travelling a while
But it comes on & off.
So when I am at the workshop, don't see the error code so cant track!
Changes so far:
#10
Posted 13 July 2018 - 03:15 PM
Shawrac
  • THREAD STARTER
  • Premium member
    Shawrac
    4th Gear
    Author Image
    564
Seem like it is good that not much VW owner got this issues. Cos till date seem like no one have gotten this issues before. Cos no actual case reply.
Hahahaha
Changes so far:
#11
Posted 24 July 2018 - 02:45 PM
takeiteasy_
  • Premium member
    takeiteasy_
    Author Image
    11
had been in this situation before with a scirocco, send to w/s and check and was a faulty wire connecting to ABS that causes these fault code. change the wire for $120 and no more error.
  • 1
Back to Volkswagen Auto Club  ·  Car Brands Top Reply to this topic
Quick Reply
Tags: touran, fault, code, brake, servo and 1 more...
