  • 1
  • Search this thread
  • Reply to this topic
2 replies to this topic | 10 praises
#1
Posted 15 July 2018 - 02:45 PM
DACH
  • THREAD STARTER
  • DACH
    2Fast2Furious
    Author Image
    50,186
Just to share as a friend underwent a surgery due to this. Take note if you have persistent abdominal pain, it should not be ignored.
https://www.healthli...m/health/hernia
What is a hernia?
A hernia occurs when an organ pushes through an opening in the muscle or tissue that holds it in place. For example, the intestines may break through a weakened area in the abdominal wall.
Hernias are most common in the abdomen, but they can also appear in the upper thigh, belly button, and groin areas. Most hernias aren’t immediately life-threatening, but they don’t go away on their own. Sometimes they can require surgery to prevent potentially dangerous complications.
Common hernia types
Inguinal hernia
Inguinal hernias are the most common type of hernia. They make up about 70 percent of all hernias, according to the British Hernia Centre (BHC). These hernias occur when the intestines push through a weak spot or tear in the lower abdominal wall, often in the inguinal canal.
The inguinal canal is found in your groin. In men, it’s the area where the spermatic cord passes from the abdomen to the scrotum. This cord holds up the testicles. In women, the inguinal canal contains a ligament that helps hold the uterus in place.
This type of hernia is more common in men than women. This is because a man’s testicles descend through the inguinal canal shortly after birth, and the canal is supposed to close almost completely behind them. Sometimes, the canal doesn’t close properly and leaves a weakened area prone to hernias.
Hiatal hernia
hiatal hernia occurs when part of your stomach protrudes up through the diaphragm into your chest cavity. The diaphragm is a sheet of muscle that helps you breathe by contracting and drawing air into the lungs. It separates the organs in your abdomen from those in your chest.
This type of hernia is most common in people over 50 years old. If a child has the condition, it’s typically caused by a congenital birth defect. Hiatal hernias almost always cause gastroesophageal reflux, which is when the stomach contents leak backward into the esophagus, causing a burning sensation.
Umbilical hernia
Umbilical hernias can occur in children and babies under 6 months old. This happens when their intestines bulge through their abdominal wall near their bellybutton. You may notice a bulge in or near your child’s bellybutton, especially when they’re crying.
An umbilical hernia is the only kind that often goes away on its own as the abdominal wall muscles get stronger, typically by the time the child is 1 years old. If the hernia hasn’t gone away by this point, surgery may be used to correct it.
Incisional hernia
Incisional hernias can occur after you’ve had abdominal surgery. Your intestines may push through the incision scar or the surrounding, weakened tissue.
What causes a hernia?
Hernias are caused by a combination of muscle weakness and strain. Depending on its cause, a hernia can develop quickly or over a long period of time.
Common causes of muscle weakness include:
  • failure of the abdominal wall to close properly in the womb, which is a congenital defect
  • age
  • chronic coughing
  • damage from injury or surgery
Factors that strain your body and may cause a hernia, especially if your muscles are weak, include:
  • being pregnant, which puts pressure on your abdomen
  • being constipated, which causes you to strain when having a bowel movement
  • lifting heavy weight
  • fluid in the abdomen, or ascites
  • suddenly gaining weight
  • surgery in the area
  • persistent coughing or sneezing
Am I at the risk of hernia?
The factors that increase your risk of developing a hernia include:
Conditions such as cystic fibrosis can also indirectly increase your risk of developing a hernia. Cystic fibrosis impairs the function of the lungs, causing a chronic cough.
What are the symptoms of hernia?
The most common symptom of a hernia is a bulge or lump in the affected area. In the case of an inguinal hernia, you may notice a lump on either side of your pubic bone where your groin and thigh meet.
You’re more likely to feel your hernia through touch when you’re standing up, bending down, or coughing.
If your baby has a hernia, you may only be able to feel the bulge when they're crying. A bulge is typically the only symptom of an umbilical hernia.
Other common symptoms of an inguinal hernia include:
  • pain or discomfort in the affected area (usually the lower abdomen), especially when bending over, coughing, or lifting
  • weakness, pressure, or a feeling of heaviness in the abdomen
  • a burning, gurgling, or aching sensation at the site of the bulge
Other symptoms of a hiatal hernia include:
In some cases, hernias have no symptoms. You may not know you have a hernia unless it shows up during a routine physical or a medical exam for an unrelated problem.
How is hernia diagnosed?
Inguinal or incisional hernias are usually diagnosed through a physical examination. Your doctor may feel for a bulge in your abdomen or groin that gets larger when you stand, cough, or strain.
If you have a hiatal hernia, your doctor may diagnose it with a barium X-ray or endoscopy.
A barium X-ray is a series of X-ray pictures of your digestive tract. The pictures are recorded after you’ve finished drinking a liquid solution containing barium, which shows up well on the X-ray images.
An endoscopy involves threading a small camera attached to a tube down your throat and into your esophagus and stomach.
These tests both allow your doctor to see the internal location of your stomach.
If your child has an umbilical hernia, your doctor may perform an ultrasound. An ultrasound uses high-frequency sound waves to create an image of the structures inside the body.
Treatment options of hernia
Whether or not you need treatment depends on the size of your hernia and the severity of your symptoms. Your doctor may simply monitor your hernia for possible complications. Treatment options for a hernia include lifestyle changes, medication, or surgery.
Lifestyle changes
Dietary changes can often treat the symptoms of a hiatal hernia, but won’t make the hernia go away. Avoid large or heavy meals, don’t lie down or bend over after a meal, and keep your body weight in a healthy range.
Certain exercises may help strengthen the muscles around the hernia site, which may reduce some symptoms. However, exercises done improperly can increase pressure at that area and may actually cause the hernia to bulge more. It’s best to discuss what exercises to do and not do with your doctor or physical therapist.
If these changes don’t eliminate your discomfort, you may need surgery to correct the hernia. You can also improve symptoms by avoiding foods that cause acid reflux or heartburn, such as spicy foods and tomato-based foods. Additionally, you can avoid acid reflux by losing weight and giving up cigarettes.
Medication
If you have a hiatal hernia, over-the-counter and prescription medications that reduce stomach acid can relieve your discomfort and improve symptoms. These include antacidsH-2 receptor blockers, and proton pump inhibitors.
Surgery
If your hernia is growing larger or causing pain, your doctor may decide it’s best to operate. Your doctor may repair your hernia by sewing the hole in the abdominal wall closed during surgery. This is most commonly done by patching the hole with surgical mesh.
Hernias can be repaired with either open or laparoscopic surgery. Laparoscopic surgery uses a tiny camera and miniaturized surgical equipment to repair the hernia using only a few small incisions. Laparoscopic surgery is less damaging to the surrounding tissue.
Open surgery requires a longer recovery process. You may be unable to move around normally for up to six weeks. Laparoscopic surgery has a much shorter recovery time, but the risk of your hernia reoccurring is higher.
In addition, not all hernias are suitable for laparoscopic repair. This includes hernias where a portion of your intestines has moved down into the scrotum.
Potential complications of hernia
If left untreated, your hernia may grow and become more painful. A portion of your intestine could become trapped in the abdominal wall. This can obstruct your bowel and cause severe painnausea, or constipation. An untreated hernia can also put too much pressure on nearby tissues. This can cause swelling and pain in the surrounding area.
If the trapped section of your intestines doesn’t get enough blood flow, strangulation occurs. This can cause the intestinal tissue to become infected or die. A strangulated hernia is life-threatening and requires immediate medical care.
Preventing a hernia
You can’t always prevent the muscle weakness that allows a hernia to occur. However, you can reduce the amount of strain you place on your body. This may help you avoid a hernia or keep an existing hernia from getting worse. Prevention tips include:
  • not smoking
  • seeing your doctor when you’re sick to avoid developing a persistent cough
  • maintaining a healthy body weight
  • avoiding straining during bowel movements or urination
  • lifting objects with your knees and not your back
  • avoiding lifting weights that are too heavy for you
Outlook
It’s important to recognize the early signs of a hernia. An untreated hernia will not go away on its own. However, with early medical care or lifestyle changes, you can minimize the effects of a hernia and avoid life-threatening complications like strangulation.
Count-Bracula and Sunny praised this
Dream car: Lamborghini Murcielago 6.2
#2
Posted 15 July 2018 - 03:14 PM
Neutrino
  • Neutrino
    Supercharged
    Author Image
    6,585
Strange that CT scans are not mentioned as a method of diagnosing hernias.
There is no law without enforcement
#3
Posted 04 September 2018 - 11:35 PM
raymond_khoo
  • raymond_khoo
    2nd Gear
    Author Image
    129
i had hernia whilst i was serving NS when i was 20years old.
The doctor says that i'm one in a million. Usually men in their 40s 50s need to go thru open surgery hernia repair. That day.. crushed me... and i sucked thumb and signed the papers to go for the hernia surgery. My intestines were protruding outwards at the groin area.
What did i do?
It was lull period in NS. Eveyrone had ORD'ed. So i went to gym heavy weights during the day and played soccer at night daily.
Yep.
  • 1
Back to Healthcare & Wellness  ·  Non-Car Related Top Reply to this topic
Quick Reply
Tags: hernia, intestine injury and 4 more...
