Steptronic Supercharged October 16, 2018 Share October 16, 2018 I can do both. On tracks, using both legs very helpful. Normal driving one leg only. You want to practice with both legs, go for those simulators, you will get used to it. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 16, 2018 Share October 16, 2018 i always thought left foot is for the clutch only, where last time we have cars with clutch and manual gears. Link to post Share on other sites More sharing options...
Macrosszero Turbocharged October 16, 2018 Share October 16, 2018 I did tried stepping brake with my left. I almost jerk till throw out. Than I concluded my left foot left sensitive than my right foot. Must be some sort of illness. It is just muscle memory and training. Just like how few people can write properly with both hands. The right foot is primarily used to modulate the throttle in small increments, or brake smoothly. We rarely panic brake as a matter of daily driving. I personally feel that some accidents can be avoided if drivers simply brake harder but that's another story. If you are used to driving stick your left leg is conditioned to press down hard and gently release as you locate the clutch biting point thus muscle memory carries over if you attempt to brake with your left foot the first few times. You really have to concentrate when you are left-foot braking. 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 16, 2018 Share October 16, 2018 Right foot should be use for brake Otherwise you gan cheong your both leg press both GG 2 Link to post Share on other sites More sharing options...
Gnahp Supercharged October 16, 2018 Share October 16, 2018 I can do both. On tracks, using both legs very helpful. Normal driving one leg only. You want to practice with both legs, go for those simulators, you will get used to it. I can do both now too as I have both type of bikes that is right foot brake and left foot brake just need to chant "left foot brake left foot brake left foot brake..... " for a minute before I switch from the other type and vice versa Link to post Share on other sites More sharing options...
Vratenza Supersonic October 16, 2018 Share October 16, 2018 Don't tempt @radx Follow traffic rules = right way of driving Dun be cb on the road = right way of driving Courteous on the road = right way of driving I don't care what leg you use to drive. You can use your middle leg for all I care Later I going to try braking with left leg.... But i suspect I will feel very uncomfortable driving with my groin kiap close all the time..... As @Angcheek always say... Package too big.... 2 Link to post Share on other sites More sharing options...
Vid Hypersonic October 16, 2018 Share October 16, 2018 Don't tempt @radx Later I going to try braking with left leg.... But i suspect I will feel very uncomfortable driving with my groin kiap close all the time..... As @Angcheek always say... Package too big.... [laugh] That bugger likely using his 3rd leg to drive already. 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 16, 2018 Share October 16, 2018 Don't tempt @radx Later I going to try braking with left leg.... But i suspect I will feel very uncomfortable driving with my groin kiap close all the time..... As @Angcheek always say... Package too big.... if use both leg , need to close up tight ...... very uncomfortable . Long drive will end with cramp . 6 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 16, 2018 Share October 16, 2018 [laugh] That bugger likely using his 3rd leg to drive already. Alamak , You knew me well . Not easy to control the 3rd leg to press on the brakes with correct force u know 4 Link to post Share on other sites More sharing options...
RadX Moderator October 16, 2018 Share October 16, 2018 NbZ Hahah 2 Link to post Share on other sites More sharing options...
Optramagnum 6th Gear October 16, 2018 Share October 16, 2018 Any method which don't cause accident or damage to car is a good method... I know.. Say like never say like that. :) Link to post Share on other sites More sharing options...
awhtc 6th Gear October 16, 2018 Share October 16, 2018 (edited) The correct method to brake in the event of accident in front is to brake hard initially then gradually release the brake if there is still reaction distance. This will achieve a shorter braking distance, enable you to keep the brake fully depressed if needed and allow the car behind you to react. Edited October 16, 2018 by awhtc Link to post Share on other sites More sharing options...
inlinesix Supersonic October 17, 2018 Share October 17, 2018 The correct method to brake in the event of accident in front is to brake hard initially then gradually release the brake if there is still reaction distance. This will achieve a shorter braking distance, enable you to keep the brake fully depressed if needed and allow the car behind you to react. Just fully depress as hard as possible while switching on hazard light for 5 sec ABS will improve braking distance and enable steering input. Link to post Share on other sites More sharing options...
Jamesc Hypersonic October 17, 2018 Share October 17, 2018 Alamak , You knew me well . Not easy to control the 3rd leg to press on the brakes with correct force u know Yah lah see beautiful girl stop suddenly. 2 Link to post Share on other sites More sharing options...
Angcheek Hypersonic October 17, 2018 Share October 17, 2018 Yah lah see beautiful girl stop suddenly. they got to bend over ... ...... E BRAKE ! 3 Link to post Share on other sites More sharing options...
flashbang Turbocharged October 18, 2018 Author Share October 18, 2018 (edited) Left foot on brake puts your legs in an unnatural position, not comfortable for day to day driving. Not to mention bad habit of resting foot on brake pedal. Seen quite a few cars driving around on highways and brake light is always on..... Edited October 18, 2018 by flashbang 1 Link to post Share on other sites More sharing options...
Philipkee Twincharged October 18, 2018 Share October 18, 2018 they got to bend over ... ...... E BRAKE ! Remind me of the time after passing report I was walking just behind a female nurse when she suddenly bent over to pick up something. Imagine the rest 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 18, 2018 Share October 18, 2018 Left foot on brake puts your legs in an unnatural position, not comfortable for day to day driving. Not to mention bad habit of resting foot on brake pedal. Seen quite a few cars driving around on highways and brake light is always on..... Brake light always on, might be due to brake switch fault. Even when they stop and turn off the engine, the brake light will still be on. Then the battery will go flat the next morning. ↡ Advertisement Link to post Share on other sites More sharing options...
Future of Driving
Future of Driving
PSA: Driving in Malaysia and How To Handle Accidents and Theft
Old WW2 Relic disposals
Class 4 Driving License
Brake Pads
Brake Pads
Weekend car driving into Malaysia
