carloverguy2017 5th Gear December 27, 2018 Share December 27, 2018 So I bought a used 10 year old car. What happens next year if I go for inspection and inspection fails ? I suspect the cat in the exhaust was modified or deleted ... Can I buy a cat to install ? ↡ Advertisement Link to post Share on other sites More sharing options...
flashbang Turbocharged December 27, 2018 Share December 27, 2018 Then you end up with a lemon car. Pray it's a common make and you can find a scrapyard cat, else you have a very expensive display car. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 27, 2018 Share December 27, 2018 The answer is obvious what. If the exhaust system has been tempered with, especially with the cat, the inspection test will be immediate failure. You could be facing a fine too for tempering with the cat. Link to post Share on other sites More sharing options...
Mockngbrd Supersonic December 27, 2018 Share December 27, 2018 (edited) You will have to buy new exhaust system lo. So easy. If you buy a cat to install, it will have to be oem and original. Also you will need to instruct the welder to do swee swee or else you will still fail if there are visible welding marks. Edited December 27, 2018 by Mockngbrd Link to post Share on other sites More sharing options...
WangWang888 5th Gear December 27, 2018 Share December 27, 2018 So I bought a used 10 year old car. What happens next year if I go for inspection and inspection fails ? I suspect the cat in the exhaust was modified or deleted ... Can I buy a cat to install ? Why not send it for inspection first. Then if really fail, find the dealer if u had just bought it recently 1 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic December 27, 2018 Share December 27, 2018 If 2nd hand, by now dealer wipe hand clean liao. Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear December 27, 2018 Author Share December 27, 2018 If 2nd hand, by now dealer wipe hand clean liao. Yaloh... Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 27, 2018 Share December 27, 2018 (edited) So I bought a used 10 year old car. What happens next year if I go for inspection and inspection fails ? I suspect the cat in the exhaust was modified or deleted ... Can I buy a cat to install ? you suspect only, why not send the car for an inspection and see how it goes. If it fails , go get it fixed . there is no need to live in uncertainty. It may not even fail and may not be catalytic converter unless you have credible evidence to think so. It depends on what car, catalytic converter should be less than S$500 Edited December 27, 2018 by Ct3833 2 Link to post Share on other sites More sharing options...
SiLangKia Supersonic December 27, 2018 Share December 27, 2018 (edited) So I bought a used 10 year old car. What happens next year if I go for inspection and inspection fails ? I suspect the cat in the exhaust was modified or deleted ... Can I buy a cat to install ? Impreza S-GT right? go to the scrapyard gt a stock exhaust set, then swap to that for your inspection. Many yards around, can try Kheng keng, got a stock exhaust for my FD there Edited December 27, 2018 by SiLangKia 8 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear December 27, 2018 Share December 27, 2018 If the CAT is removed, the Engine Check light sure lightup one. Of course, the way to fix it, is to REMOVE the check light bulb lor. Problem solved. So when you turn on the engine before cranking it, did the CEL light up for lamp test ? Anyway, 2008 car, anyhow test will also pass lor. Only car registered 2014 onward need to worry, it is said to be very regimental lor, a slight mod also will fail the test. So I bought a used 10 year old car. What happens next year if I go for inspection and inspection fails ? I suspect the cat in the exhaust was modified or deleted ... Can I buy a cat to install ? 1 Link to post Share on other sites More sharing options...
DACH Supersonic December 28, 2018 Share December 28, 2018 Go for the emissions test and then decide the next course of action. 2 Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear December 28, 2018 Author Share December 28, 2018 If the CAT is removed, the Engine Check light sure lightup one. Of course, the way to fix it, is to REMOVE the check light bulb lor. Problem solved. So when you turn on the engine before cranking it, did the CEL light up for lamp test ? Anyway, 2008 car, anyhow test will also pass lor. Only car registered 2014 onward need to worry, it is said to be very regimental lor, a slight mod also will fail the test. I am not aware of this 2014 "rule" . This is something new. Yes thanks for all comments, I didn't want to inspect it since it's not due until 2019 year end. Just want to know what will happen and how to resolve if it does fail. I had a friend who's been driving rex for many years whom told me he highly suspect the cat was amiss. No CEL though. Maybe I too overly worried.. haha Link to post Share on other sites More sharing options...
Xers007 Supercharged December 28, 2018 Share December 28, 2018 Pay some workshop to send in your car for inspection. For some reason they can always pass inspection no matter how mod a car is. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 29, 2018 Share December 29, 2018 I am not aware of this 2014 "rule" . This is something new. Yes thanks for all comments, I didn't want to inspect it since it's not due until 2019 year end. Just want to know what will happen and how to resolve if it does fail. I had a friend who's been driving rex for many years whom told me he highly suspect the cat was amiss. No CEL though. Maybe I too overly worried.. haha Cars without the Cat smell not the same,very pungent,Cars with Cat,almost little or no smell. 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 29, 2018 Share December 29, 2018 Cars without the Cat smell not the same,very pungent,Cars with Cat,almost little or no smell. yup. And hence LTA / TP a;ways can smell and pull the mod car aside Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear December 31, 2018 Author Share December 31, 2018 Cars without the Cat smell not the same,very pungent,Cars with Cat,almost little or no smell. Yup.. that's what my initial suspect. I thought car engine haven't warm up, hence the smell. But even after I drove back home, stop the car, still smell that strong exhaust smell. That's why I posted this thread. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 31, 2018 Share December 31, 2018 Yup.. that's what my initial suspect. I thought car engine haven't warm up, hence the smell. But even after I drove back home, stop the car, still smell that strong exhaust smell. That's why I posted this thread. I think if you drive to Sin Min or Ubi area, may kenna stop and ask to check exhaust liao Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 31, 2018 Share December 31, 2018 Was your MIL in the car when got the smell? ↡ Advertisement Link to post Share on other sites More sharing options...
New Subaru XV
New Subaru XV
Vicom Annual Car Inspection
test
test
2015 Forester 2.0
2015 Forester 2.0
Advice on exhaust.
Advice on exhaust.
testing again
testing again
