Vtim 3rd Gear July 31, 2003 Share July 31, 2003 only you will know ↡ Advertisement Link to post Share on other sites More sharing options...
Orixy 2nd Gear September 30, 2003 Share September 30, 2003 Hi there, I'm new to this forum and so far have been very much excited by all the cool technical discussion threads by you guys! :) Like to learn what's the practical use of installing the heatsink onto oil filter and cooling it down? I've heard that engine and its lubricating oil needs a certain optimum temp to operate at its best. If we cool the oil down too much, will it decrease performance instead? Regards Link to post Share on other sites More sharing options...
Vtim 3rd Gear October 1, 2003 Share October 1, 2003 If we cool the oil down too much, will it decrease performance instead? Here in Singapore, we do a lot of start stop traffic and with the added fact that humidity is higher, the oil in the Auto Tranny will runs hotter than those in other countries So, if the added power increase over stock engine, like adding in piggy back ECU..etc... (in the case of Modeldriver's Stream), it's better to add a AFT Oil cooler to prolong the life span of the Auto Tranny Link to post Share on other sites More sharing options...
Esky Neutral Newbie October 2, 2003 Share October 2, 2003 This reminds me of a site my fren sent me: http://www.cool-collar.com/ Link to post Share on other sites More sharing options...
Vtim 3rd Gear October 2, 2003 Share October 2, 2003 I think the inline cooler will be more effective than this Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 3, 2003 Share October 3, 2003 I think I saw it was going for S$10 the last time I was there but can't confirm on it. But it fits only certain filter size only. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 4, 2003 Author Share October 4, 2003 Where? Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 4, 2003 Share October 4, 2003 Mcwell. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 4, 2003 Author Share October 4, 2003 I thought someone mentioned he saw at McWell for $50 ? For $10 .. I think quite worth it... will check with them then .. Hope the fin is long enough to provide cooling effect.... Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 4, 2003 Share October 4, 2003 I remembered I saw a S$10 price tag on it. But as it din fit my oil filter cos it's too small for my filter, I passed on it. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 20, 2016 Share December 20, 2016 more then 10 years later. Anyone tried this? Seems turbo cars are hot. oil filter heat sink may help cool things down. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 20, 2016 Share December 20, 2016 more then 10 years later. Anyone tried this? Seems turbo cars are hot. oil filter heat sink may help cool things down. VW car has a heatsink of some sort. It's the oil cooler. Oil flows passed the filter media into this cooler with fins. Coolant is piped around the fins and return to cooling system. The problem is the interface of oil vs coolant, inside the oil cooler. When the interface leaks or breaks, engine oil is send to the cooling system. Then the cooling system stopped working and engine overheat. If you want to diy oil filter heatsink, you'd probably need to put a fan to blow at the heatsink. It's safer than running the cooling system through it. 2 Link to post Share on other sites More sharing options...
mdsidddik5573 Neutral Newbie January 2, 2017 Share January 2, 2017 Check this out guys ... it's sold in Japan. Simple concept, just mount in onto your oil filter and it's blade will help cool the oil filter down. Just a simple heat sink concept. Maybe a few CPU heatsink mount together also can ;-) Himalayan Salt Lamps: Himalayan Salt Lamps is the best lamp . This is very modern lamp in our modern civilization.There are many kinds of lamp that looks very beautiful.To know more please visit this link: http://www.jpost.com/PromoContent/5-Amazing-Himalayan-Salt-Lamps-You-Can-Buy-Right-Now-441101 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 3, 2017 Share January 3, 2017 VW car has a heatsink of some sort. It's the oil cooler. Oil flows passed the filter media into this cooler with fins. Coolant is piped around the fins and return to cooling system. The problem is the interface of oil vs coolant, inside the oil cooler. When the interface leaks or breaks, engine oil is send to the cooling system. Then the cooling system stopped working and engine overheat. If you want to diy oil filter heatsink, you'd probably need to put a fan to blow at the heatsink. It's safer than running the cooling system through it. Looking at ease of drawing heat away from the engine. Was thinking along the lines of taking a laser printer toner thats used. Dismantle the long strip of magnet. Take cable tie and tie it to the bottom of the engine oil pan. I imagine it will draw heat away. But worried I magnetize the piston fillings that is worn off and somehow make things worst off . Would the oil filter trap all the metal that is worn off the piston or am I over "worried" of the effects ? Link to post Share on other sites More sharing options...
Kb27 Supersonic January 3, 2017 Share January 3, 2017 Looking at ease of drawing heat away from the engine. Was thinking along the lines of taking a laser printer toner thats used. Dismantle the long strip of magnet. Take cable tie and tie it to the bottom of the engine oil pan. I imagine it will draw heat away. But worried I magnetize the piston fillings that is worn off and somehow make things worst off . Would the oil filter trap all the metal that is worn off the piston or am I over "worried" of the effects ? There are commercially available products with magnet to trap ferrous material at oil filter and also oil drain plug. Oil drain plug is ok, when you removed it, any filings can just wiped off the tip. Oil filter have to be careful, that it's replaced before the magnet is removed. Otherwise, all the trapped filings could flow back into the engine. Then again, some people say they don't find any magnetic filings at the oil drain plug. The engine has many other types of metallic alloys that's not ferrous, not able to be picked up by magnet. If you put something below the oil pan, you have to be careful, it doesn't hit something near the ground while you're driving. Link to post Share on other sites More sharing options...
engineoilterry Neutral Newbie January 27, 2017 Share January 27, 2017 where to buy ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Air Purifier Discussion - tips and info
Recommendations for light kitchen carpentry and sink works
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
