  • 1
  • Search this thread
  • Reply to this topic
13 replies to this topic | 0 praises
#1
Posted 08 February 2002 - 02:10 PM
Dptm
  • THREAD STARTER
  • Dptm
    2nd Gear
    Author Image
    110
Thinking of giving my engine compartment a cleanup, it's dusty and a little greasy.
How do u guys do it?
What solution do i use for this?
Do i need to cover/wrap up certain parts?
Heard that some car wash offer engine wash by spraying water directly at the compartment, is it advisable to do that or is better to use a rag to clean it?
Pardon my long list of questions.
#2
Posted 08 February 2002 - 02:13 PM
Turbobrick
  • Turbobrick
    Moderator
Better to cover the electrical and air intake components up with plastic bags, then use rags soaked with Diesel or degreaser and wipe the engine area, a brush will help too. Then rinses with a water hose but with a nozzle to spray the water in a mist rather than just spraying loads of water at your engine. Prevents flooding of hidden components. wink.gif
____________________________________________
I'm in GMT -5:00 time zone
#3
Posted 08 February 2002 - 04:45 PM
Dptm
  • THREAD STARTER
  • Dptm
    2nd Gear
    Author Image
    110
don't have access to hose, staying in HDB, guess will have to use a rag and soaked with clean water for the final wipe then.
#4
Posted 08 February 2002 - 04:49 PM
Turbobrick
  • Turbobrick
    Moderator
Yeah, a damp rag will wipe off the degreaser good enough, may need a couple of wipes though. Depends how greasy is your engine..... tongue.gif
#5
Posted 09 February 2002 - 09:19 AM
Madarmour
  • Madarmour
    Author Image
    8,675
That would be much safer than using the hose.
Henry Ford once said: “Whenever I see an Alfa Romeo, I raise my hat?
#6
Posted 09 February 2002 - 09:42 AM
Sky8807
  • Premium member
    Sky8807
    5th Gear
    Author Image
    1,317
Tools required for the job
1. paint brush(clean)
2. cleaning agent (washing detergent also can)
3. rags or cloth
4. small container forthe cleaning agent
5.water hose
For the dusty part, use brush to brush it off and dry rags to wipe and clean it
For the greasy part, get some detergent and mix with water in a container, a little concentrate will help, and brush the affected area.
After than use water to hose it or wash it away. If you use water hose, only precaution is - do not spray directly on the electrical parts. Should be ok.
In HDB car wash point, you can use a hose, 20c give you approx 2 pail or about 5 gall of water. It deliver by the quantity and not timing so no worri about the water not enough, get a hose and connect to it and hose down the area required. Dry it with rag and cloth. That should do the job
JT
#7
Posted 09 February 2002 - 11:11 AM
Ghostrider
  • Premium member
    Ghostrider
    Supercharged
    Author Image
    5,860
What I am doing now is......
Use car wash shampoo (I using the cheapo Shell shampoo) to wash the engine bay.
Use a paint brush (soft type) and clean the whole engine bay with the shampoo. Make sure that all your plug cables are secure. U dun wan water to get into the engine.
Then after you are thru with it, just take small amount of water to rinse off the washed parts. When you are done, start the engine to warm up the engine to rid of all the water. After a while (like 5-10 min) then stop the engine. Spray a bit of WD40 on a paper towel & wipe the engine cover & plug cables and other rubber parts, that will clean it and give a slight shine.
If you too free then use wax to wax all the painted parts. Wah la....U are done liao !! :)
If your engine is very dirty, then you may have to use a degreaser before you start to shampoo.....
I got no signature ??
#8
Posted 07 April 2002 - 02:54 PM
Turbobrick
  • Turbobrick
    Moderator
Know any workshop or detailer who steam cleans the engine bay?
I've seen many workshops giving "courtesy" engine wash but they just hantam degreaser and use a jet hose to spray the engine directly! shocked.gif
#9
Posted 07 April 2002 - 04:43 PM
Mondeo
  • Mondeo
    6th Gear
    Author Image
    3,670
"Son of the Gun" is not bad. For washing/cleaning engine compartment better DIY when the engine is cool down.
[purple] [url "http://www.avnc.cm.hk"][b] AVNC.com.hk [b][/url]
#10
Posted 07 April 2002 - 06:55 PM
Turbobrick
  • Turbobrick
    Moderator
I heard Simple Green is quite good also, but I'm thinking of a full steam cleaning service by workshop or detailer. Any JB lobang? wink.gif
#11
Posted 07 April 2002 - 07:12 PM
Yongwd
  • Premium member
    Yongwd
    4th Gear
    Author Image
    735
let me know if u have any workshop doing steam cleaning of the engine compartment. Make sure they dun mix diesel with water and spray onto the engine.
>Singapore, an island where all the slow drivers converge<
#12
Posted 07 April 2002 - 07:17 PM
Turbobrick
  • Turbobrick
    Moderator
Yeah, that's what most workshop do, just mix diesel and whack. If they do that to my brick I'll personally whack the diesel cocktail up their arses! mad.gif
#13
Posted 07 April 2002 - 10:37 PM
Mondeo
  • Mondeo
    6th Gear
    Author Image
    3,670
#14
Posted 14 September 2018 - 02:46 PM
Ct3833
  • Ct3833
    Author Image
    7,568
does anyone have workshop in SGP that will do engine compartment cleaning to recommend? thanks in advance.
  • 1
Dynamics Mechanic Pte Ltd
Quick Reply
