Makbyv Neutral Newbie January 16, 2004 Share January 16, 2004 When I accelerate my Lancer up to and beyond 80km/h, the "womming" noise can be heard from the front & seem to be from the engine compartment. When the speed reach 100km/h & beyond, the noise get louder. Can anyone enlighten me on what could be the problem with my car. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Darkness Neutral Newbie January 16, 2004 Share January 16, 2004 sounds like fan / alternator belt...might be timing belt too...i have this problem too...mechanic said it was the former so he change but still got noise so he said could be timing belt also (but half day job to change timing belt) so i skip that part and living wif it for now.....maybe if got time i will go down and try changing it. Cheers Darkness Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 16, 2004 Share January 16, 2004 It would be ideal if u could be a bit more specific .... wats womming noise ?? Do you hear the sound only on the move or even when stationary ? Try revving when stationary , do you hear it ?? At 100 kph , you should be at around 2500 rpm right , try it when stationary. Then it would be suffice to track whether its actually a problem with a moving part or a drive part of the car Link to post Share on other sites More sharing options...
Makbyv Neutral Newbie January 16, 2004 Author Share January 16, 2004 The sound seem like coming from the engine. It's hard to write the sound. I could only hear it coming when moving. Link to post Share on other sites More sharing options...
Makbyv Neutral Newbie January 16, 2004 Author Share January 16, 2004 I've change the timing belt already! Any other part?? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 16, 2004 Share January 16, 2004 how old is the lancer....i know the latest has CAI so that could be the reason Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 16, 2004 Share January 16, 2004 hi s2p2, if not the cai then what could be the reason? Link to post Share on other sites More sharing options...
Michel Neutral Newbie January 16, 2004 Share January 16, 2004 (edited) Maybe it could be tyre noise? My friend has a 'womming' sound problem when he drives during the afternoon, but at low speed. As he accelerates, the sound is reduced. Don't know where the sound is from. But my other friends and I always suspected it could be the tyres (maybe due to balding) Edited January 16, 2004 by Michel Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 16, 2004 Share January 16, 2004 does it sound like a 'tiger/lion roaring' sound? Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 16, 2004 Share January 16, 2004 There are few possibilities for this "womming " noise generated by imbalance or eccentric rotating components. a) The front tyres maybe under inflate or there is a possibility of localised heat built-up in one of the tyre , the heat can cause tyre ply separation. The localised heat-up area can be due to a minute hole puncture (the penetrating object is still stuck in position )or heavy sudden braking b)Faulty front wheel brearings c)Faulty front drive shafts d)The newly installed timing belt is loose due to wrong tension during the initial set up. e)If your mechanics did not change the timing belt tensioner when replacing the timing belt, the old tensioner can also be the cause of the problem. Hope this helps Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 16, 2004 Share January 16, 2004 Could be the front tires. What tires you have on now? Some tires tend to be noiser at high speeds Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 16, 2004 Share January 16, 2004 frankly, also cannot confirm, but uneven wear of tyre also produce that sound Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 17, 2004 Share January 17, 2004 sounds like tyre noise... Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 17, 2004 Share January 17, 2004 (edited) is your lancer a 2nd hand car? Edited January 17, 2004 by Epsilon Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 22, 2004 Share January 22, 2004 I think it's best you come to our meetup on Friday night at Bishan & we ride in your car to ascertain where is the cause of the noise is coming from Link to post Share on other sites More sharing options...
Aeledkawy Neutral Newbie January 9, 2017 Share January 9, 2017 I have the same problem but it's start 60 km and stop 80km Link to post Share on other sites More sharing options...
armend Neutral Newbie November 29, 2019 Share November 29, 2019 On 1/9/2017 at 2:58 PM, Aeledkawy said: I have the same problem but it's start 60 km and stop 80km did you fix it now cuz Im having the same problem ? Link to post Share on other sites More sharing options...
Ki113r 1st Gear December 18, 2019 Share December 18, 2019 On 11/30/2019 at 4:58 AM, armend said: did you fix it now cuz Im having the same problem ? I had this issue, because wheel bearing worn out. Changed it and no more sound. ↡ Advertisement Link to post Share on other sites More sharing options...
How problematic is VW's 7 speed DSG?
Intermittent rattling noise, car in ICU
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
OMEGA low speed juicer
