Sky8807 1st Gear July 23, 2002 Share July 23, 2002 Is Stamford the best place to do wheel balancing and alignments? No comments on that, but I did not do any alignment job there so far. I thought most tyre shops shld offer the same kind of service? No true. Some are good others are the opposite Incl JB? Ratonale being that they are all computerised and thus... shldnt make any difference until the machine used is cxxk up one? Theory yes, but practical is different. The problems is that there is still the human elements in all this and thus the experience of the man doing the job counts. ↡ Advertisement Link to post Share on other sites More sharing options...
Sky8807 1st Gear July 24, 2002 Share July 24, 2002 Whenever the front suspension is disturbed, wheel alignment check is necessary. Chances are that the reading are out and need adjustments. Wheel balancing should be done on all four tyres for best results. If the front tyre is found worn or uneven wearing, should rotate the rear pair to the front if possible unless the rear is equally bad. The front tyre is important because if affect steering and control of the car. Whatever it is the front tyre should be the better ones if replacement is not the solution. After driving for sometimes, alignment will be slightly out from the original setting, if left unattended, tyre will wear unevenly and by that time is slightly too late. Tyres rotation is also important because as the front tyres wear due to hardwork of gripping, steering and stopping, it will wear in a certain pattern, rotation ensure even wear for all four tyres. Link to post Share on other sites More sharing options...
Guyver 1st Gear July 27, 2002 Share July 27, 2002 How do i know whether is my wheel alignment is out? I've never done anything like that since i started driving in 1998.... So for my car now... how do i tell that i need to do a wheel balancing? Link to post Share on other sites More sharing options...
Cool Neutral Newbie July 27, 2002 Share July 27, 2002 Wheel alignmnt is out can be detected by if you put your steering wheel straight and it goes terribly left or right. WHeel balancing can be detected at high speed, you feel that it is quite bumpy or uncomfotable. But yours is not sport rim, cannot be fixed.. I think Link to post Share on other sites More sharing options...
Sky8807 1st Gear July 28, 2002 Share July 28, 2002 How do i know whether is my wheel alignment is out? Slight alignment out does not show easily. By the time you realise it, alignment would have been bad. Tyre wear is one indication. Steering wheel veering abrutly to either side another. As a guide wheel alignment recommended to be check between 16 -24 months . I've never done anything like that since i started driving in 1998.... So for my car now... how do i tell that i need to do a wheel balancing? If you front wheel balancing is out, steering vibration will be felt at certain speed. If you do wheel balancing recommended to do on all four wheels. Recommended to do wheel balancing annually. Link to post Share on other sites More sharing options...
Guyver 1st Gear July 30, 2002 Share July 30, 2002 Ok.... i know i know.... no sports rim... let me see what i can do.... hmm.... Link to post Share on other sites More sharing options...
Cool Neutral Newbie July 31, 2002 Share July 31, 2002 Friend.. don't any how spent money.. unless you decide to keep the car or not. If you do decide to keep your car.. I am offering you free service to soundproof your entire car. (you need to purchase the material). I am dying to rape your car !!! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 31, 2002 Share July 31, 2002 Tried the Lexus rims yet? Link to post Share on other sites More sharing options...
Guyver 1st Gear July 31, 2002 Share July 31, 2002 Can do partial sound proofing or not.... not full one lah.... just to keep out some noise... if can spend less than $100 to do up... then quite ok.... Link to post Share on other sites More sharing options...
Guyver 1st Gear July 31, 2002 Share July 31, 2002 Won't be trying... confirmed on STC that IS200 16" PCD is 114.3... so got to give it a miss liao.... Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 1, 2002 Share August 1, 2002 You better be sure whether you want to sell away the car first or not you can use AeroForm without accumat. Link to post Share on other sites More sharing options...
Guyver 1st Gear August 5, 2002 Share August 5, 2002 I don't know.... really depend on the market... then..... but if can spend abit of $$ to do sound proofing... good enough liao... Link to post Share on other sites More sharing options...
Timmz Neutral Newbie November 9, 2007 Share November 9, 2007 my experience of computerized alignment is this: 1) set up the reflectors on the wheels 2) get the correct database for your car 3) run the programs 4) see the readings 5) adjust something of the linkages under the car 6) the end I smell something wrong with this, they do not run the program again to verify that what they had done gets the alignment back into spec. but they always say good that u came 2 themcoz it is mis-aligned........ fishy. how can they confirm that they adjusted correctly wo confirmation of taking the readings again? Link to post Share on other sites More sharing options...
Weichien Clutched June 2, 2010 Share June 2, 2010 Hey bros and sis. need advice badly. i understand that badly align wheels will "drift" to either left or right. but for my condition i drift to both side sometime left sometime right. the car can never be straight. like eat snake later people think i drink driving. Hv just changed my normal streeing settings to "euro setting" Is this got to do w alightment? Link to post Share on other sites More sharing options...
Newcar 1st Gear June 2, 2010 Share June 2, 2010 (edited) my experience of computerized alignment is this: 1) set up the reflectors on the wheels 2) get the correct database for your car 3) run the programs 4) see the readings * Position steering wheel straight & lock it with mechanism* 5) adjust something of the linkages under the car 6) the end I smell something wrong with this, they do not run the program again to verify that what they had done gets the alignment back into spec. but they always say good that u came 2 themcoz it is mis-aligned........ fishy. how can they confirm that they adjusted correctly wo confirmation of taking the readings again? Just sharing some add on (In above bold text) . Which mostly some technician miss it..... todate, only experienced 1 good wheel technician whom dont lock steering while adjusting. But, alignment is perfect..! Edited June 2, 2010 by Newcar Link to post Share on other sites More sharing options...
5936 1st Gear June 2, 2010 Share June 2, 2010 Where did u do it? In Sg or My. Many years ago, like many here, JB is my place to svc car. Some of them dont have updated car model software for wheel alignment-- so they tamba any close to it model lah. although alignment was done, but still feel something is not right.. Like being shortchanged. pay for technology but get traditional svc. Most of them like to install adjustable camber nut at front shocks. If kena bumps alignment also KO easily. Link to post Share on other sites More sharing options...
Newcar 1st Gear June 3, 2010 Share June 3, 2010 (edited) Mine was done in perling on last sat. Has been there for past 1 yr through a friend recommendatin...! But, sad to say that the tires technician had left his job there on 31th May as he need to move to PuChong, KL area...! Emm...! Hard for me to search for another good tires technician...! Edited June 3, 2010 by Newcar ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Planetary alignment
Planetary alignment
Wheel spacers - the real truth...
Wheel Spacer, where to buy?
Wheel Spacer Installation DIY
Steering wheel off centered from seat.
