Cybertech 4th Gear May 3, 2004 Share May 3, 2004 Any good products for keeping the windscreen glass clean and clear and remove those oily layer. Used Rain-x before, result is good but cause wiper to shudder. And Autoglym Glass cleaner, heard will left those small blue residue particules after effect. Any good recommendation here? ↡ Advertisement Link to post Share on other sites More sharing options...
Protege 1st Gear May 3, 2004 Share May 3, 2004 Bro, my suggestion to you is not to touch the windscreen. If not you will be in trouble when it start to judder. Anyway if you really want, just use your usual dishwashing cleaning liquid like Mama Lemon. By the way, if you are facing a juddering problem, let me know as I got lobang to solve it. Cheers!! Link to post Share on other sites More sharing options...
Soya Supersonic May 3, 2004 Share May 3, 2004 u can try the foamy 3M glass cleaner. v.good. Link to post Share on other sites More sharing options...
Cheekg99 Neutral Newbie May 3, 2004 Share May 3, 2004 My friend just use newspaper to wipe ... Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 4, 2004 Share May 4, 2004 My friend just use newspaper to wipe ... Me too Link to post Share on other sites More sharing options...
Tea3 Neutral Newbie May 5, 2004 Share May 5, 2004 Are you referring to the inside or outside? I use mama lemon & newspaper to clean the inside but still got an oily layer. I used Autoglym but what you said is true - small powdery residue. Flakes off from windscreen that drop onto the dashboard. Link to post Share on other sites More sharing options...
Soya Supersonic May 5, 2004 Share May 5, 2004 i combine the 3M cleaner wif newspaper. dem effective. Link to post Share on other sites More sharing options...
Leonknapp Clutched May 10, 2004 Share May 10, 2004 Any good products for keeping the windscreen glass clean and clear and remove those oily layer. Used Rain-x before, result is good but cause wiper to shudder. And Autoglym Glass cleaner, heard will left those small blue residue particules after effect. Any good recommendation here? Use a claybar. no mess and its prob the most effective cleaner for the windscreen!! Link to post Share on other sites More sharing options...
Ic3ncok3 Neutral Newbie May 10, 2004 Share May 10, 2004 i use the autoglym glass polish.......seems to work well, no shudder and u dun get much water makrs after rain also.......havent tried the glass cleaner yet tho so dunno how it compares........ Link to post Share on other sites More sharing options...
Spaceman Neutral Newbie May 10, 2004 Share May 10, 2004 i've got juddering problem on my ride, so what's the secret formula???? Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 11, 2004 Share May 11, 2004 Hi there, I am only washing my ride with shampoo and not even waxing it and the juddering is not even surfacing. That's something for you to ponder over. Cheers. Link to post Share on other sites More sharing options...
AngelEye Neutral Newbie May 14, 2004 Share May 14, 2004 kiwi glass cleaner and newspaper.. Link to post Share on other sites More sharing options...
Discoburg Supersonic May 15, 2004 Share May 15, 2004 My friend just use newspaper to wipe ... Thats what i am using too and its the best. Link to post Share on other sites More sharing options...
Epson Neutral Newbie May 22, 2004 Share May 22, 2004 yoz bro, i'm facing jubbering problem after using that power Rain-x.. how to stop the jubbering huh? pls help wor~ thanks Link to post Share on other sites More sharing options...
Slayer Clutched May 22, 2004 Share May 22, 2004 yoz bro, i'm facing jubbering problem after using that power Rain-x..how to stop the jubbering huh? pls help wor~ thanks with rain-x , .. intermitent wipe is good enough. u'd need to experiement with different dosage of rain-x as u apply on your windscreen. start with small amount .. Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 23, 2017 Share December 23, 2017 ok, so rain-x leaves a film on the glass after extended period of time. so anyone used anything good so far to repel water of the glass surfaces ? I don't mind my car body dirty ... but I just want to ensure that visibility is as good as possible during rainy weather. Link to post Share on other sites More sharing options...
able712 1st Gear December 26, 2017 Share December 26, 2017 I've used Glaco ultra and it make the wiper judder too... 1 Link to post Share on other sites More sharing options...
dcb Turbocharged January 10, 2018 Share January 10, 2018 Ceramic coating ok, so rain-x leaves a film on the glass after extended period of time. so anyone used anything good so far to repel water of the glass surfaces ? I don't mind my car body dirty ... but I just want to ensure that visibility is as good as possible during rainy weather. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
how to remove micro/fine scratches on windscreen
How to remove stubborn stain on windscreen?
Automatic (robotic) vacuum cleaner
New Age Polish --> Volkswagen Portfolio
Best water repellent
New Age Polish --> Hyundai Portfolio
