Unknown_G7 Neutral Newbie October 17, 2002 Share October 17, 2002 Hello guys I have two problems below! Hope someone can help me! 1)My signal indicator had a problem! Most of the time when I on the signal to either side, at first it will flash and giving clicking sound (NORMAL). After few seconds it will stop flashing and no clicking sound too (THE SIGNAL LIGHT IS STILL ON EXCEPT FLASHING). What's wrong with that? 2)I noticed that my dashboard meter light was getting dim when I switched on the headlight at night time. I had just changed new battery! ↡ Advertisement Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 17, 2002 Share October 17, 2002 Hi there Unknown Trouble shooting for wiring is a tedious process. This two problems seems to be affiliated with the alternator. Any problems with the rest of the electricals? Wat's your drive? Regards Lester Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie October 17, 2002 Author Share October 17, 2002 (edited) No problem with other electricals! So you mean that something is wrong with the wiring, right? Normally who will do the wiring? 1992 toyota corolla Edited October 17, 2002 by Unknown Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie October 18, 2002 Author Share October 18, 2002 Does anyone know whether there's any other possiblities that cause the fault? Link to post Share on other sites More sharing options...
N3m0 Clutched April 12, 2018 Share April 12, 2018 Hi. Can i know what is wrong if my temperature indicator is red. What do i need to check. Link to post Share on other sites More sharing options...
29daan Neutral Newbie May 22, 2018 Share May 22, 2018 The dashboard problem is something I had too, I just switched the light bulbs. Even if this is not the problems it's still worth doing, really small but nice datail. ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
P2096 Check engine light
Use your blinker!
Use your blinker!
Queuing to turn left into side road - signal lights or hazards?
Engine check light on after topping up gas
