Roberttan 5th Gear January 15, 2013 Share January 15, 2013 yup FOC repaired at all stamfords FOC only for customer bought the tyres from them? ↡ Advertisement Link to post Share on other sites More sharing options...
Pms 3rd Gear January 15, 2013 Share January 15, 2013 Theres 3 types of repair. 1) Internal Patching 2) Mushroom Plug 3) The classic "Gummy Worm" Read up on the mix reviews over the internet and it seems the classic worm is still the best. Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 15, 2013 Share January 15, 2013 Theres 3 types of repair. 1) Internal Patching 2) Mushroom Plug 3) The classic "Gummy Worm" Read up on the mix reviews over the internet and it seems the classic worm is still the best. May I know what is Gummy Worm? Number 1 and 2 very common but 3 dun noe? Link to post Share on other sites More sharing options...
Pms 3rd Gear January 15, 2013 Share January 15, 2013 The common worm like looking tyre repair kit that you can find easily in stores. Its the cheapest and reliable because the compound will vulcanize and mate with the tyre when done correctly. The mushroom plug has the best sealing but the steel belting of the tire will cut the rubber plug away after some time. Internal patching while it seal from the inside, it does not seal the hole in which water can seep through to the steel belt thus corroding it. Usually most shop will use rubber cement to seal the hole after internal patching. Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 16, 2013 Share January 16, 2013 The common worm like looking tyre repair kit that you can find easily in stores. Its the cheapest and reliable because the compound will vulcanize and mate with the tyre when done correctly. The mushroom plug has the best sealing but the steel belting of the tire will cut the rubber plug away after some time. Internal patching while it seal from the inside, it does not seal the hole in which water can seep through to the steel belt thus corroding it. Usually most shop will use rubber cement to seal the hole after internal patching. Mr PM, do you know 1 of the key rational behind the internal repair? the tyre mechanic can only inspect your tyre internally with tyre removed from rim for any onternal injury. and are you aware of how the sticky worm is inserted into the hole? practically they are FORCING it into your hole in order to seal the hole. base on my understanding the total diameter of the worm in U shape + the pushing kit is almost 5 - 10 time of the punctured hole,thus sometime it could cause the hole tearing or eventually after running for some distance same thing will occure. AGAIN the idea is IS your tyre safe to continue serve you after the repaired? Is risky to have a tyre repaired externally with hidden or internally injured tyre. Tyre only fail when your car is on the move especially at high speed Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 16, 2013 Share January 16, 2013 Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 16, 2013 Share January 16, 2013 Mr,Yeoph the screen shown clearly EMERGENCY TIRE SEALANT KIT so this repair kit is for Emergency or temporary repair only So best is still get the professional people do it in the recommended way (INTERNAL). Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 16, 2013 Share January 16, 2013 I did not mention that this is a permanent repair. I have been selling tyre changes and wheel balancers since 1976 right up to 1987. If you are old enough and have connections with tyre shops, you could recall the super power tyre changer from Repco Australia. This tyre changer was very quickly replaced by FAIP tyre changer from italy. I write not to teach tyre changer history in Singapore but just to prove to you that I know why I am taking because of my long association with the auto service industry in Singapore. I love to be corrected if you happen to know more technically on this subject than me Link to post Share on other sites More sharing options...
Pms 3rd Gear January 16, 2013 Share January 16, 2013 Mr PM, do you know 1 of the key rational behind the internal repair? the tyre mechanic can only inspect your tyre internally with tyre removed from rim for any onternal injury. and are you aware of how the sticky worm is inserted into the hole? practically they are FORCING it into your hole in order to seal the hole. base on my understanding the total diameter of the worm in U shape + the pushing kit is almost 5 - 10 time of the punctured hole,thus sometime it could cause the hole tearing or eventually after running for some distance same thing will occure. AGAIN the idea is IS your tyre safe to continue serve you after the repaired? Is risky to have a tyre repaired externally with hidden or internally injured tyre. Tyre only fail when your car is on the move especially at high speed Yes sir, safety first. This was what I gather from people experiences in the forums located is the states. Singapore road and driving is nothing compared to them. Anyway is you want a peice of mind, this is the correct way to repair a tyre. http://www.rma.org/tire_safety/tire_mainte...ty/tire_repair/ Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 17, 2013 Share January 17, 2013 Yes sir, safety first. This was what I gather from people experiences in the forums located is the states. Singapore road and driving is nothing compared to them. Anyway is you want a peice of mind, this is the correct way to repair a tyre. http://www.rma.org/tire_safety/tire_mainte...ty/tire_repair/ THANKS FOR YOUR COMMENT we are here to share our personal view and experience , and each of every one has own preference. just some believe tyre just for you to roll on the road because i dont drive fast ,only from pt A to pt B happy driving Link to post Share on other sites More sharing options...
Coolsahara Neutral Newbie July 16, 2015 Share July 16, 2015 Please try this website (puncturedtyre.com) if you need 24/7 tyre and battery services in Singapore. Link to post Share on other sites More sharing options...
Timex1441 1st Gear June 16, 2016 Share June 16, 2016 A few days ago, i had a slow leak in 1 tyre due to a nail. Went to this shop "Tan Eng Hua Tyre" at Blk 721 Clementi West St 2 (near the Sheng Siong). Very efficient service and cheap, only $8 for a patch. Highly recommended. 2 Link to post Share on other sites More sharing options...
alex976 5th Gear June 16, 2016 Share June 16, 2016 A few days ago, i had a slow leak in 1 tyre due to a nail. Went to this shop "Tan Eng Hua Tyre" at Blk 721 Clementi West St 2 (near the Sheng Siong). Very efficient service and cheap, only $8 for a patch. Highly recommended. Thanks Timex1441, Please dun go to stamford tyres, they charge $18 a patch for my isuzu D max (same size as a SUV), I went to their loyang branch yesterday evening. Until nw heart still abit pain. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear June 16, 2016 Share June 16, 2016 Thanks Timex1441, Please dun go to stamford tyres, they charge $18 a patch for my isuzu D max (same size as a SUV), I went to their loyang branch yesterday evening. Until nw heart still abit pain. so how did Stamford Tyres repair the tyre? Link to post Share on other sites More sharing options...
Beregond Supersonic June 16, 2016 Share June 16, 2016 Thanks Timex1441, Please dun go to stamford tyres, they charge $18 a patch for my isuzu D max (same size as a SUV), I went to their loyang branch yesterday evening. Until nw heart still abit pain. internal patch 18buks is cheap. external worm patch 18 buks is chop carrot head. Link to post Share on other sites More sharing options...
AKB48 1st Gear June 16, 2016 Share June 16, 2016 so how did Stamford Tyres repair the tyre?So expensive. Got warranty is it Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear June 16, 2016 Share June 16, 2016 So expensive. Got warranty is it ??? Link to post Share on other sites More sharing options...
Mercury1 Turbocharged June 16, 2016 Share June 16, 2016 Thanks Timex1441, Please dun go to stamford tyres, they charge $18 a patch for my isuzu D max (same size as a SUV), I went to their loyang branch yesterday evening. Until nw heart still abit pain. 18 bucks for internal patching ? Or using the worm plug? ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
