QQDreamer 4th Gear June 11, 2017 Share June 11, 2017 when looking at the engine mounts,what do we look out for if it is faulty?cracks? cracks and vibrations ↡ Advertisement Link to post Share on other sites More sharing options...
pravinfive Neutral Newbie June 27, 2017 Share June 27, 2017 Changed engine mounts (complete set) for my FD at AutoSaver Toh GuanWhat was the damage? Link to post Share on other sites More sharing options...
Alphas 2nd Gear June 27, 2017 Share June 27, 2017 How long does engine mount can last after changing?My cerato v1 changed mountings at 9 year, the rubber already start to disintegrate. I think reasonable time to 5-9 years depending on the quality of the rubber used. Link to post Share on other sites More sharing options...
Blueray Hypersonic June 27, 2017 Share June 27, 2017 What was the damage? around $800+. Link to post Share on other sites More sharing options...
SpeedyJIM Clutched June 29, 2017 Share June 29, 2017 around $800+.Super expensive..original mount $420.. labour max 200 Link to post Share on other sites More sharing options...
Dafansu Turbocharged June 29, 2017 Share June 29, 2017 Super expensive..original mount $420.. labour max 200 should be around this price for bread and butter cars. paid about 500 odd for my vios Link to post Share on other sites More sharing options...
Blueray Hypersonic June 30, 2017 Share June 30, 2017 Super expensive..original mount $420.. labour max 200 Civic FD full set engine mounts $420 ? Get from where ? Link to post Share on other sites More sharing options...
SpeedyJIM Clutched July 1, 2017 Share July 1, 2017 Civic FD full set engine mounts $420 ? Get from where ?Toh guan.. u call this guy 91394756 1 Link to post Share on other sites More sharing options...
GohBoonPinFred Clutched July 16, 2017 Share July 16, 2017 How long does mounting lasts? Mine changed at 150k now 224 k mechanic say spoil already 1 Link to post Share on other sites More sharing options...
Acewin 4th Gear July 30, 2017 Share July 30, 2017 How long does mounting lasts? Mine changed at 150k now 224 k mechanic say spoil already Very much depends on the road condition and your driving pattern. In general 150K around there. 1 Link to post Share on other sites More sharing options...
littlelight Neutral Newbie December 2, 2017 Share December 2, 2017 Hi all, need some advice for my 9 year old 2008 Toyota Altis before deciding if I should change my engine mounting. Went to a workshop recently to service my car and was told that my engine mounting requires a change and was quoted $600 to do so. Did a little research and so far what I have gathered is engine mounting requires a change when telltale signs of strong vibrations of the car while idling. There are vibrations while idling but it is not that obvious. I am in a dilemma because I would most probably scrap the car come next year's October and was thinking if I should change it or not. But at the same time I do not want to spend unnecessary money if not needed. Would appreciate if any gurus here can advise if I should proceed to change or not. TIA! 1 Link to post Share on other sites More sharing options...
Acewin 4th Gear December 2, 2017 Share December 2, 2017 Hi all, need some advice for my 9 year old 2008 Toyota Altis before deciding if I should change my engine mounting. Went to a workshop recently to service my car and was told that my engine mounting requires a change and was quoted $600 to do so. Did a little research and so far what I have gathered is engine mounting requires a change when telltale signs of strong vibrations of the car while idling. There are vibrations while idling but it is not that obvious. I am in a dilemma because I would most probably scrap the car come next year's October and was thinking if I should change it or not. But at the same time I do not want to spend unnecessary money if not needed. Would appreciate if any gurus here can advise if I should proceed to change or not. TIA! Why don't you seek a second option from another workshop. 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 2, 2017 Share December 2, 2017 If left 1 year no need to waste money. Just live with it or squirt some silicon into the crack! Link to post Share on other sites More sharing options...
littlelight Neutral Newbie December 2, 2017 Share December 2, 2017 Why don't you seek a second option from another workshop. Last year went to another workshop when I felt the vibration. Workshop only casually mentioned that could be due to engine mounting. But back then I asked if I should change it the guy told me not needed unless vibration becomes worse. This time round I went autobacs and was advised to change it. Anyway reason for me not going back to the same workshop cause the guy that I trust no longer works there and has already went back Malaysia. 1 Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 2, 2017 Share December 2, 2017 Hi bro, left 1 year if change all engine mounting abit sayang if you intend to scrap the car at the end of the 10th year. Ofcos if vibration really to much to tahan then have to change. I change Axio mounts over here : Eng Hup Autoparts Accessories Co387J Woodlands Rd Yew Tee Ind Est Singapore 677954. Tel 6769 0452 Much cheaper - you try call in check price. Link to post Share on other sites More sharing options...
littlelight Neutral Newbie December 3, 2017 Share December 3, 2017 Hi bro, left 1 year if change all engine mounting abit sayang if you intend to scrap the car at the end of the 10th year. Ofcos if vibration really to much to tahan then have to change. I change Axio mounts over here : Eng Hup Autoparts Accessories Co 387J Woodlands Rd Yew Tee Ind Est Singapore 677954. Tel 6769 0452 Much cheaper - you try call in check price. Thanks bro. Anyway any idea if I do not change will there be any safety issue? Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 3, 2017 Share December 3, 2017 (edited) Shldnt be. Juz that steering wheel will be like vibrator!!! Hahhahaha Oh but but.. Car lose power cos engine vibrate.. Cannot fully transfer power to yr wheels Edited December 3, 2017 by Digthis1 Link to post Share on other sites More sharing options...
littlelight Neutral Newbie December 3, 2017 Share December 3, 2017 Shldnt be. Juz that steering wheel will be like vibrator!!! Hahhahaha Oh but but.. Car lose power cos engine vibrate.. Cannot fully transfer power to yr wheels Ok thanks thanks! Asked this cause I remembered the mechanic was mentioning about safety hazard if never change. ↡ Advertisement Link to post Share on other sites More sharing options...
Teana repair/parts
Teana repair/parts
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
