Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi My Part list dun have Expenables like washers, plugs. Else can provide Part Number.. ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 Yeohbh has said that the the whole shebang is blackmail. The A/C dryer hardly gives any problem. If we don't service the dryer, they will void the warranty for the A/C system. If they want to replace it every 40k as stated in the manual, either it is damn lousy or it is pure blackmail. Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 the dryer is optional if working need not to change cause the dryer can last quite long at least 4 to 5 years brother , is their stupid labour is damm expensive , so u ops for the normal 20k is 200 plus for sure . Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 Buy from ACDelco? BTW, I check with Mann oil filter distributor, they don't carry the supersize one. I got one from Song Yi. Has GM label on it but we all know they are ACDelcos. Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 any way the air con is only for 1 years warranty only right , maybe cause i read the warranty book say so .And my is already just 1 year plus 5 days . Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 Can check how what mm size is the drain plug. I'm checking out Fumoto. They list all Daewoos use 14mm - 1.5 Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi Part list didnt mentioned on Drain Plug. Have Oil Pan, Oil Pan Gasket but no Drain Plug. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 (edited) Nevermind. I order the Fumoto drain plug for Daewoos. Just reach under flick switch, oil flows! See pics. Edited October 27, 2004 by Genie47 Link to post Share on other sites More sharing options...
Dwoon 1st Gear October 27, 2004 Share October 27, 2004 How I wish mine was that easy......... Even if have the drain valve, I still have sump guard to remove 1st. Link to post Share on other sites More sharing options...
Yeoman Neutral Newbie October 27, 2004 Share October 27, 2004 Bravo Sifu, when teach me har? mi eager to learn leh....... errrrgh Sifu and also u still have not teach me the power of lighting bolt using middle finger leh........... Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 I suggest go online and buy the Fumoto Valve if you intend to do this. When DIY, replace the drain plug with the Fumoto. Next time change oil, no need to remove drain plug. Just flick the switch. Save a lot of headaches. Link to post Share on other sites More sharing options...
Yeoman Neutral Newbie October 27, 2004 Share October 27, 2004 u switching to fumoto also? how much? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 USD27 plus normal shipping. Takes 3wks. Next oil change install. After that, can easily drain. Link to post Share on other sites More sharing options...
Cracker 1st Gear October 27, 2004 Share October 27, 2004 SO the airdryer thing is optional ??? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 NO. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 (edited) Update on this DIY oil change thingy. It failed on the filter removal part. I was using those cheapo $5.00 Taiwan made crap tool. Poorly finished, the damn tool cut me. The filter has been mangled but trust me, it is not broken. Guys who do oil filter study sweat buckets before they can saw one open. Got fed up because of poor tools. I prefer the bicycle chain type filter wrench but I can't seem to find it anywhere. Good thing I got cheap Delo 400. I filled it up with it. I can cut my loses by asking the SA mech to remove the filter and put in the remainder I have since the filter takes about 1/2 a quart. Edited October 27, 2004 by Genie47 Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 very inovative way of changing oil yourself save a lot of trouble .well done brother Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 As soon as I can find a better filter wrench. This was the kind of crap I was using: ↡ Advertisement Link to post Share on other sites More sharing options...
ATF oil change
ATF oil change
Change Disc Rotors
Change Disc Rotors
Would you help to change another car's tyre in another country?
Do I need to change tire ?
