Condor82 Neutral Newbie February 2, 2010 Share February 2, 2010 good information ↡ Advertisement 1 Link to post Share on other sites More sharing options...
JashaanAutosport Neutral Newbie February 17, 2010 Share February 17, 2010 good stuff :) 1 Link to post Share on other sites More sharing options...
Rion03 Neutral Newbie March 19, 2010 Share March 19, 2010 thumbs up 1 Link to post Share on other sites More sharing options...
Chiangauto Clutched April 2, 2010 Share April 2, 2010 Thanks for sharing.good thread must always on top. 1 Link to post Share on other sites More sharing options...
Krado Clutched April 5, 2010 Share April 5, 2010 I've been using this online calculator: http://www.rimsntires.com/rt_specs.jsp Tyre + Rim sizes. 1 Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear April 5, 2010 Share April 5, 2010 just to add. personally, I prefer to read from this website, Link you need Java application to view it. for those who wish to upsize rims/tyres, do take note of the speed change between actual vs. speedometer reading. but one thing to note (perhaps not to everyone) -> you upsized your rims/tyres to look good. so i would suggest you to hit, "Speedometer reading with non-stock tire is x.x% too slow." "When your speedo reads 60mph, you are actually traveling xx.xmph. Although speedometer is no longer accurate but I'm sure you will love the look.~ 1 Link to post Share on other sites More sharing options...
Rtxm Neutral Newbie April 9, 2010 Share April 9, 2010 Actually when fitting tire sizes there are only 2 things to consider. 1. Tyre overall height (using tyre size calculators which every knows and wad this thread is abt ) affects speedometer and odometer readings as a rule of thumb max overall +/- 10mm or 2% difference whichever is lower. 2. Tyre width ( which most people seem to be overlooking ) affected by ur full lock turning or fender. manuals provide you with stock specifications which definitely gives you clearance. Usually increasing by 20-30mm shldn't be a prob but varies from car to car. If u want even wider tires which come with bigger rims, Aftermarket mods can be done to accomodate required specifications and widths. eg.rims with proper offset,fender roll/widen etc. At the end of the day, jus consult ur workshop. They should have the expertise for size conversions and allowable fitments for most car models. 1 Link to post Share on other sites More sharing options...
Autom Neutral Newbie April 19, 2010 Share April 19, 2010 Hi Need some help here, Looking for 2nd hand tyre size 185 or 175/80/R14. VERY VERY urgent please call Allan H/P: 98310824 1 Link to post Share on other sites More sharing options...
DeathAngel Neutral Newbie May 2, 2010 Share May 2, 2010 good stuff 1 Link to post Share on other sites More sharing options...
Chiangauto Clutched May 13, 2010 Share May 13, 2010 thanks for your link. Link to post Share on other sites More sharing options...
Qes78 Neutral Newbie May 14, 2010 Share May 14, 2010 I've always used the calculator from the miata.net website. But that's because I a miata owner and enthusiast 1 Link to post Share on other sites More sharing options...
Dek-johanson Neutral Newbie May 14, 2010 Share May 14, 2010 thats cool 1 Link to post Share on other sites More sharing options...
Chris84 Neutral Newbie May 18, 2010 Share May 18, 2010 hi.. will there b ani diff in FC if i change my rim from 16' to 17' ?? 1 Link to post Share on other sites More sharing options...
Sg993 Neutral Newbie June 5, 2010 Share June 5, 2010 Thanks for the info.. 1 Link to post Share on other sites More sharing options...
Kelove Neutral Newbie August 12, 2010 Share August 12, 2010 i want to turn my bike into a rigid frame chopper so i am looking for info to do this on the cl350. I already cut the frame and have it stripped down to the motor only. I found weld yourself rigid kit on ebay .I will have a local welding shop do the work) but need more finishing info on it. _______________ f150 wheels 1 Link to post Share on other sites More sharing options...
Strudel- 1st Gear August 12, 2010 Share August 12, 2010 Heres a really good one for you guys. http://www.importjap.com/download/2/ 1 Link to post Share on other sites More sharing options...
Aaronlkl Supersonic August 26, 2010 Share August 26, 2010 This is useful.. 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 4, 2010 Share October 4, 2010 My recommendation to be stickied with the top post. http://ejelta.com/tiresize/index.html It is very flexible. For example, I will use the Aveo as an example: The stock 13" tires on the Aveo are 155/80-13. So to link the page to someone so that he can decide what tires to use on the Aveo will be: http://ejelta.com/tiresize/index.html?tiresize=155/80-13 For more information on how to link see here: http://ejelta.com/tiresize/linking.html great link, solve my problem and save me to start a new thread. [thumbsup] ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
New Study Explores Connection Between The Size Of Your Manhood And Sports Cars
Tire size not available in Singapore, how?
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
