Zacer Clutched October 14, 2006 Share October 14, 2006 must be OPC car price. ↡ Advertisement Link to post Share on other sites More sharing options...
Glyuen 3rd Gear October 15, 2006 Share October 15, 2006 wah...why resurrect this old thread... Link to post Share on other sites More sharing options...
Sk_wan Neutral Newbie April 12, 2013 Share April 12, 2013 Hi,i'm new here juz curious is ok to drive with the ABS light on & off I have send to a ws but the use their computer keep checking witbout any fault... Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 12, 2013 Share April 12, 2013 Hi,i'm new here juz curious is ok to drive with the ABS light on & off I have send to a ws but the use their computer keep checking witbout any fault... ABS warning light on means yr abs got problem. It might not function when u need it. Might b a sensor problem. Each wheel has a sensor. Maybe connection loose. Better get it chk n fixed fr safety sake. Link to post Share on other sites More sharing options...
Sk_wan Neutral Newbie April 16, 2013 Share April 16, 2013 Hi, thanks but do u know where I can get it done in Singapore??? Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 16, 2013 Share April 16, 2013 Hi, thanks but do u know where I can get it done in Singapore??? Fr something as sensitive as abs e best is go to agent. But b prepared to pay agent prices. Or u try reset yr ecu n see if it helps. Link to post Share on other sites More sharing options...
Swingarm 1st Gear April 16, 2013 Share April 16, 2013 Hi,i'm new here juz curious is ok to drive with the ABS light on & off I have send to a ws but the use their computer keep checking witbout any fault... Did you chg ur steering wheel? Last time when i change my steering wheel to momo, the abs light is on. Tried so many ws but not able to solve it. When i revert back, the abs light goes off. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 17, 2013 Share April 17, 2013 Fr something as sensitive as abs e best is go to agent. But b prepared to pay agent prices. Or u try reset yr ecu n see if it helps. Hi bro, how do u actually 'reset the ecu?' This morning, it was raining so heavy and while I was on the way home after fetching my girl to school, suddenly the ABS light up. Later, I went to work abt an hour later, I was praying very hard that it won't light up. Well, luckily it didn't light up. But I just want to know how to try n reset the ecu which u mentioned in case it happened again. Thks in advance. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 17, 2013 Share April 17, 2013 Hi bro, how do u actually 'reset the ecu?' This morning, it was raining so heavy and while I was on the way home after fetching my girl to school, suddenly the ABS light up. Later, I went to work abt an hour later, I was praying very hard that it won't light up. Well, luckily it didn't light up. But I just want to know how to try n reset the ecu which u mentioned in case it happened again. Thks in advance. U can do a standard soft reset of yr ecu by disconnect yr battery + terminal fr a couple of hrs then reconnect back. It sud then go to factory settings. It wil take some time to re-learn yr driving style so u might feel performance a little funny after that but no prob. Just drive as u normally do n soon it re-learns yr driving style n sud b fine. If yr abs light still comes on after that...u need to send to agent fr a through check of yr abs. Link to post Share on other sites More sharing options...
HP_Lee 5th Gear April 17, 2013 Share April 17, 2013 Hi all, I have just placed my deposit for my Chevrolet Aveo, sedan. Can anyone pls advice me on the spare parts of Chevrolet? is it expensive?? I have heard that Mitsubishi's spare parts is much cheaper to source.. I have sooo many questions abt Chevrolet. I know nothing about this brand, the support, the parts, the servicing (is it expensive)... Can someone pls HELP!?! You dun know, and yet you still buy.. Woah! bro.. good luck to you. Link to post Share on other sites More sharing options...
Nodtviedt 2nd Gear April 17, 2013 Share April 17, 2013 You dun know, and yet you still buy.. Woah! bro.. good luck to you. Good or bad luck, he would have known by now... the post is 8 years old! Link to post Share on other sites More sharing options...
Sk_wan Neutral Newbie April 20, 2013 Share April 20, 2013 I have asked the ws guys to reset after reset is still on n off so I wana to ask whether is ok to drive with it ? have any of you guys out there face the same problem as my ? Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 20, 2013 Share April 20, 2013 I have asked the ws guys to reset after reset is still on n off so I wana to ask whether is ok to drive with it ? have any of you guys out there face the same problem as my ? The light is telling u there is a problem wh yr abs. U can still drive but if u emergency brake yr abs might not activate only. Link to post Share on other sites More sharing options...
Sk_wan Neutral Newbie April 20, 2013 Share April 20, 2013 Thanks u guys out there..for the informention, one last thing anyone drive a 1.4l aveo vgis seden car here how much is your fuel consumption ? Cos my car from full tank till hit end marking is only ard 350km only is rather low my frens driving suzuki swift can reach ard 480km for one full tank. Link to post Share on other sites More sharing options...
Mdaspro Neutral Newbie July 10, 2014 Share July 10, 2014 I own a secondhand Chevrolet Aveo and recently the ABS dashboard light has been switched on while I'm driving. The car is stopping while driving. I went to local service shop (Autobacs) for diagnosis, but they could not carry out the diagnosis and recommended me to go to Chevrolet service agents. I was checking in these forums, I found that RDY Autocare at AMK specializes with Chevrolet. Does anybody have any experience there? Any other shop? Pls share... Link to post Share on other sites More sharing options...
Crossangel Neutral Newbie July 10, 2014 Share July 10, 2014 Hi,i'm new here juz curious is ok to drive with the ABS light on & off I have send to a ws but the use their computer keep checking witbout any fault... I use to owe a aveo, the abs light could be cause by an actual fault of abs sensor. During my 1 yr ownership of it, I had replace two abs sensor. Link to post Share on other sites More sharing options...
izzy0707 Neutral Newbie June 19, 2018 Share June 19, 2018 Hi all , I just placed a deposit of 1000 of a used car CHEVROLET AVEO 1.4M selling at 22,800? with bodykit for 3 years and 4 monthss? is it ex for you guys? what are your opinions? first time buying a car here. soo quite noob ↡ Advertisement Link to post Share on other sites More sharing options...
Help with STA report remarks
HELP! Upstairs neighbour causing sleepness nights
Exporting Gmail Contacts (Pls help)
MOM help FTs look for jobs ?
MyResponder app to call SCDF
