Boy_vin Neutral Newbie February 19, 2005 Share February 19, 2005 As the question above asks... last time when i drive my suzuki swift...FC about 11-12km per litre...then 1 day i hand itchy want to try flush out the water inside & put new water inside... i got buy 1 bottle of green colour coolant frm Autobacs la...then i mix it myself. suprisingly...after i do tat...the FC for that tank of petrol & the nxt tank is around 16km per litre... i juz flush the water out frm my civic yest...see whether can better the FC.. Ani bros out there...wat do u tink of this method....how often shd 1 flush out the tank?? ↡ Advertisement Link to post Share on other sites More sharing options...
Othello Supersonic February 19, 2005 Share February 19, 2005 FC about 11-12km per litre...then 1 day i hand itchy want to try flush out the water inside & put new water inside... i got buy 1 bottle of green colour coolant frm Autobacs la...then i mix it myself. suprisingly...after i do tat...the FC for that tank of petrol & the nxt tank is around 16km per check manual for coolant change frequency.Should be around 2 years. but your FC improvement is abit ........ maybe got other factors in as well ?? Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie February 19, 2005 Share February 19, 2005 owners manual is 2 yrs or every 40k. where u do regular servicing at SA they will do it as a routine. got them to service my car..fuel consumption still the same. maybe ur old radiator is dirty and thus the engine gets v heated..thus burn more petrol...but if u flush the water liao..engine gets cooler and smoother..thus burn less... Link to post Share on other sites More sharing options...
Boy_vin Neutral Newbie February 19, 2005 Author Share February 19, 2005 i see.. thanks man... 1 more thing i like to ask... bout my civic air-con....pple advice mi to chack wiring & clean throttle body... ani bro here noe hw much it cost in SG to do wiring & throttle body clean? Link to post Share on other sites More sharing options...
Hoppe Clutched February 19, 2005 Share February 19, 2005 one qn, can use normal water for radiator? For old radiator, is there any special formula to put in to reduce the problems of rusts,etc that may compounded over the years? Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 19, 2005 Share February 19, 2005 For normal jap cars, Guess can use Ethyl Glycol(spelling?) the green type for the older models. Can buy at most petrol stations or spare part shops. Try to check the mix ratio (usually 50/50) & how much water in the cooling system. Read the instructions on the bottle & owner's manual to be sure. Newer cars have different type so u have to check your manual for details. Conti cars use another type again. Always make sure u put the correct type & mix ratio of water to coolant as per instructions for best results. In SG we got no winter so no need to flush at winter time. Just check the lifespan & flush accordingly. Link to post Share on other sites More sharing options...
Mivec9 1st Gear February 19, 2005 Share February 19, 2005 As the question above asks... last time when i drive my suzuki swift...FC about 11-12km per litre...then 1 day i hand itchy want to try flush out the water inside & put new water inside... i got buy 1 bottle of green colour coolant frm Autobacs la...then i mix it myself. suprisingly...after i do tat...the FC for that tank of petrol & the nxt tank is around 16km per litre... i juz flush the water out frm my civic yest...see whether can better the FC.. Ani bros out there...wat do u tink of this method....how often shd 1 flush out the tank?? confirm ur previous coolant contains lots of rust and no longer able to "cool" Link to post Share on other sites More sharing options...
Mivec9 1st Gear February 19, 2005 Share February 19, 2005 yes just do a flush of the radiator, then follow by add coolant + water will do. ↡ Advertisement Link to post Share on other sites More sharing options...
Do officials still check the 3/4 tank rule at causeway?
Changing of Spark Plugs
