Zacka Neutral Newbie April 23, 2005 Share April 23, 2005 Hi. I just did my servicing. And when i return from my workshop, and i tried to brake, there is a screeching sound. Sounds like metal rubbing with metal sound. Some told me that this is due to the cheong verison of the brake pad. Is this true? ↡ Advertisement Link to post Share on other sites More sharing options...
York Clutched April 23, 2005 Share April 23, 2005 u replaced ur brake pad is it.... Link to post Share on other sites More sharing options...
Zacka Neutral Newbie April 23, 2005 Author Share April 23, 2005 yup changed my brake service my engine change the oil change the filter the plugs But now got sound. Y? It's actually my fren's car, a Nissan Sunny. I went back to the workshop they say its' like tt one. How? Link to post Share on other sites More sharing options...
York Clutched April 23, 2005 Share April 23, 2005 obviously...chiong or lower quality pad... Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 23, 2005 Share April 23, 2005 You are right, it's a metal to metal contact noise, chance your mechanics did not realise the need to apply cushioning grease or compund betwen the two components. The metal to metal contact noise is generated when the the caliper comes into contact with the pad. Depending on the type of pad used, normally installation polymer compound or high temp synthetic grease are applied. Such application will reduce the metal to metal contact. Link to post Share on other sites More sharing options...
Sky8807 1st Gear April 23, 2005 Share April 23, 2005 they have to sand down the new pads to remove the noise. if like that one then everytime anyone change brake pad kenna noise lah. don't make sense Link to post Share on other sites More sharing options...
Essentiale Neutral Newbie April 23, 2005 Share April 23, 2005 go back and make the workshop sort it out man... Link to post Share on other sites More sharing options...
Zacka Neutral Newbie April 24, 2005 Author Share April 24, 2005 Thanks guys, i'll go back to the workshop and ask them. Maybe i'll change the pad to the original ones if there is a need. The sound makes the car sounds so old... Thanks Guys! Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 24, 2005 Share April 24, 2005 Bro, should be due to the brake pad used are not original Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 24, 2005 Share April 24, 2005 Try asking the workshop to install brake pad shims, they should have done that so don't let them charge you extra for their slip up Link to post Share on other sites More sharing options...
Essentiale Neutral Newbie April 24, 2005 Share April 24, 2005 yeah dont pay anymroe when you go back Link to post Share on other sites More sharing options...
Yansen Neutral Newbie April 24, 2005 Share April 24, 2005 You are right, it's a metal to metal contact noise, chance your mechanics did not realise the need to apply cushioning grease or compund betwen the two components. The metal to metal contact noise is generated when the the caliper comes into contact with the pad.Depending on the type of pad used, normally installation polymer compound or high temp synthetic grease are applied. Such application will reduce the metal to metal contact. hi, isnt it the pad being grinded by the disc? Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 25, 2005 Share April 25, 2005 I am refering to the back side of the pad not the face that comes into contact with the disc. With new pad if the dics surface is still flat without burnt or glaze markes ( hot spots ) then go ahead and use it if not send for surface skimming and honing. With proper skiming and honing to reduce the cutting tool directional marks , complete with proper washing to get rid of all the cutting metal particles, there should not be any more braking noise.When to surface comes into contact and one must be softer than the the other if not logicallay noise with be produce. Link to post Share on other sites More sharing options...
Gearoil 1st Gear April 25, 2005 Share April 25, 2005 One way is to put some damping materials on the back of pads and the other is to prepare the pads appropriately like chamfering the edges of pads slightly before installing, cleaning away brake dust and make sure rotors are not badly 'eaten away' or surface needs to be grind ( honed) to reduce the uneven contact between pads and rootors. Also ensure that the brake pistons do retract ( that is wheels can turn freely with just a little friction) when there is no postitve presure within the caliper. Do install recommeded pads or good quality ones. Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie April 25, 2005 Share April 25, 2005 its quite normal ba.....after sometimes the sound would so away... Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 25, 2005 Share April 25, 2005 Try asking the workshop to install brake pad shims, they should have done that so don't let them charge you extra for their slip up Last time I changed the pads, I tried to get new shims, but seems most w/s don't have them as the're not normally changed. I just told the mech to do what yeobh said, apply some good grease to the shims. Never had brake squeak b4. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 25, 2005 Share April 25, 2005 For those pads that use shims,apply sythetic grease as cushion and for those that do not use shims apply polymer compound. Link to post Share on other sites More sharing options...
Helixtrd Neutral Newbie April 26, 2005 Share April 26, 2005 Hi. I just did my servicing. And when i return from my workshop, and i tried to brake, there is a screeching sound. Sounds like metal rubbing with metal sound. Some told me that this is due to the cheong verison of the brake pad. Is this true? Hi Zacka, Interested to know what brand of brake pad u are using. ↡ Advertisement Link to post Share on other sites More sharing options...
Understanding Anti-lock Braking System (ABS)
How to deal with noisy neighbour who play stupid drum
Braking - "Croaking" Sound
Screeching sound when braking
Noisy Harley bikes!
Noisy Harley bikes!
Noisy aircon compressor
Toyota Camry 2.0L (2007) Braking Issue
Ten automakers to make automatic braking a standard feature
