Papercup Neutral Newbie June 13, 2005 Share June 13, 2005 Hi, Anyone of you guys know about this grade of ATF? Is it the same as Dexron III? ↡ Advertisement Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear June 13, 2005 Share June 13, 2005 i think Type T-IV is a grade in itself... driving a toyota? if so, you'll have to use only Toyota branded T-IV ATF... or if you can find it, Mobil ATF-3309.. Link to post Share on other sites More sharing options...
Genie47 1st Gear June 14, 2005 Share June 14, 2005 Toyota Type T-IV according to Gene is equivalent to Dexron VI. Lots of friction modifiers. Slippery and smooth. Maybe that is the reason why Toyota FC so good. Link to post Share on other sites More sharing options...
Papercup Neutral Newbie June 14, 2005 Author Share June 14, 2005 From what I read in GMTech. Aveo and Optra is suppose to use this grade of ATF. Hmmm... does it mean we can't use other type? Link to post Share on other sites More sharing options...
Genie47 1st Gear June 14, 2005 Share June 14, 2005 Actually Dexron ATF is backwards compatible. Dexron-III is the lowest the GMDAT cars can use. In other words if you have ATF that is better than Dexron-III like IV, V or VI. More advanced in formulation = better performance when it comes to ATF. Link to post Share on other sites More sharing options...
Papercup Neutral Newbie June 14, 2005 Author Share June 14, 2005 (edited) OIC! Thanks for the info! Now time to go search for those Dexron IV and above ATF Edited June 14, 2005 by Papercup Link to post Share on other sites More sharing options...
EventH 1st Gear June 18, 2005 Share June 18, 2005 Can transmission that require Dexron III use T-IV grade ATF? Actually the Toyota brand T-IV cost around $26 for 4L. Link to post Share on other sites More sharing options...
Papercup Neutral Newbie June 18, 2005 Author Share June 18, 2005 I think can. If according to what Genie47 had mention above, T-IV should be equal to Dexron IV. And Dexron is backward compatible. Link to post Share on other sites More sharing options...
Ddt121 Neutral Newbie June 18, 2005 Share June 18, 2005 i really suggest you go with the original ATF from Toyota. I asked many shops and mechs for my brother's car. All of them told me to stick with the Toyota one. auto tranny very expensive to repair. Link to post Share on other sites More sharing options...
EventH 1st Gear June 20, 2005 Share June 20, 2005 Actually I saw the Toyota T-IV selling at $26 for 4L (quite cheap) ... just wondering whether I can use that to flush my Nissan Sunny AT .... A big well known shop is selling the same Toyota T-IV 4L for $70 Link to post Share on other sites More sharing options...
Genie47 1st Gear June 20, 2005 Share June 20, 2005 T-IV is very high grade ATF. Very high standard and very slippery. Can use. Just don't go adding racing ATF into your street car. Not good enough. Link to post Share on other sites More sharing options...
Ddt121 Neutral Newbie June 20, 2005 Share June 20, 2005 hey bro, care to share where you saw the T-IV selling at $26? ekekeke.... better not try on N16 leh... keekeke..though backward compatible, i dont really dare to try...kekekeke.. i only use Dexron III Mercon. Link to post Share on other sites More sharing options...
EventH 1st Gear June 20, 2005 Share June 20, 2005 The oil shop is at Veerasamy across the road from Lian Song. Link to post Share on other sites More sharing options...
Ddt121 Neutral Newbie June 20, 2005 Share June 20, 2005 you mean the shop opposite Lian Siong Spare parts at blk 633? Link to post Share on other sites More sharing options...
EventH 1st Gear June 20, 2005 Share June 20, 2005 yah ... not the Lavender Lian Siong. Link to post Share on other sites More sharing options...
Ddt121 Neutral Newbie June 20, 2005 Share June 20, 2005 ok, maybe ask my bro to go ask around there. thanks, bro. Link to post Share on other sites More sharing options...
EventH 1st Gear June 24, 2005 Share June 24, 2005 Cheaper source of Toyota T-IV ATF at Bukit Merah area. Most shops $24-$25 for 4L. The uncles there actually advise against machine flushing. They say waste too much oil. They rather change 4L + ATF filter at shorter intervals than go for major flush at 40-50k. Normal 1.6L cars use less than 4L for ATF change. Further more, one even say that the excess Link to post Share on other sites More sharing options...
No666 Neutral Newbie June 25, 2005 Share June 25, 2005 Hi Is the uncle who gave the advice ready to back up his words if the transmission break down and pay? Is it more likely that he does not have the machine thus discouraging flushing? Understand transmission can last longer with regular and proper maintenance and ATF change. Take a chance or not I rather take care to save my pocket. If unsure call KATC at 6 4565200 they know better. Good luck ↡ Advertisement Link to post Share on other sites More sharing options...
Automatic (robotic) vacuum cleaner
Mother of all Avian Influenza * (H*N*)
Automatic Whole Car Cover with Remote Control
Acceleration -- CVT vs auto
Clutch for Volvo V40 T4 2013 Price?
Volkswagen Announces Recall for DSG Transmission
Most expensive car wash
