Andrewkb Neutral Newbie July 10, 2005 Share July 10, 2005 Just curious, does any of you grease your door hinges ? Or just some WD40 regularly will do ? ↡ Advertisement Link to post Share on other sites More sharing options...
Ahhuat 1st Gear July 10, 2005 Share July 10, 2005 mine still has a glob of grease on it.. should grease from time to time.. dont think wd40 is good enuff to replace good ol grease! Link to post Share on other sites More sharing options...
Hoppe Clutched July 10, 2005 Share July 10, 2005 agreed. WD will do the job fine. or maybe you can use the KY Jelly if theres any leftovers in your drawers. Link to post Share on other sites More sharing options...
Ahhuat 1st Gear July 10, 2005 Share July 10, 2005 dont bother with KY, just blow ur nose onto the hinges! Btw, why was this qn raised anyway? Does anyone have creaky hinges? If so, need to also check if they are rusted. In that case, WD can work. But IMHO, i find that grease works best for hinges, in general. Link to post Share on other sites More sharing options...
Dipstick Neutral Newbie July 10, 2005 Share July 10, 2005 Agree with you. Grease is the word. WD40 may not last long after some rain or car washes. Link to post Share on other sites More sharing options...
Crv2004 Clutched July 10, 2005 Share July 10, 2005 Just curious, does any of you grease your door hinges ? Or just some WD40 regularly will do ? No need want lar Link to post Share on other sites More sharing options...
Wheeler Neutral Newbie July 10, 2005 Share July 10, 2005 (edited) Its ok to grease the hinge but dunt gtrease the arm ( the mechanism in between the hinges). I once gease it and my car door can't remain open especially when the wind blows or at a side slope... it just lose the spring effect of holding the door open (if u get wat I mean) Edited July 10, 2005 by Wheeler Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear December 31, 2009 Share December 31, 2009 Old dusty thread . . . kack kack. Any bro know where to buy grease? Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 31, 2009 Share December 31, 2009 after a heavy downpour, you can feel that the WD40 will be washed off completely. using grease is better as it can last longer. Link to post Share on other sites More sharing options...
Opel17 6th Gear December 31, 2009 Share December 31, 2009 Old dusty thread . . . kack kack. Any bro know where to buy grease? I bought grease [hair gel jar size] from Homely Hardware Superstore, for my equipment servicing jobs. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 31, 2009 Share December 31, 2009 TORINO AMK PTE LTD. 5022 Ang Mo Kio Industrial Park 2 #01-09 Link to post Share on other sites More sharing options...
Octopus 3rd Gear December 31, 2009 Share December 31, 2009 I feel oil is better than grease, cos grease is too thick to get into the small gap in door hinges to lubricate. Singer oil for sewing machine is good but need more frequent application cos its rather light. Also can use engine oil. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 31, 2009 Share December 31, 2009 Hinges should always be greased. Oil will flow away and disappear, grease doesn't. There are certain applications that you should use oil and certain applications it should be grease. Using WD40 for everything is one of the worse thing anyone can do. It is just a very light oil that disappears very soon. It is meant as a quick fix to loosen a bolt or as water displacement as what the WD stands for. 1 Link to post Share on other sites More sharing options...
Octopus 3rd Gear December 31, 2009 Share December 31, 2009 (edited) Oil base lubricant are also used for door hinges in BITOG forum. Refer: http://www.bobistheoilguy.com/forums/ubbth...2251&page=1 Theory is the grease won't be able to penetrate deep into the hinge where the pin are to lubricate. A thicker oil lube would do a better job. Oil won't just "flow away and disappear" like you mentioned, they will leave behind a slippery residue. To add: Grease is good for protecting hinges against rust and water-resistance by coating on the external. Edited December 31, 2009 by Octopus Link to post Share on other sites More sharing options...
Chiangauto Clutched January 1, 2010 Share January 1, 2010 normal WD40 will do,but if you really want good one.maybe can try ZX1 supergrease Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 1, 2010 Share January 1, 2010 If you have this mini grease gun, it will be very easy to introduce grease right into the metal contact surfaces. Link to post Share on other sites More sharing options...
sx99 1st Gear April 22, 2018 Share April 22, 2018 Where can u get the grease to oil door hinges? Any brands? Link to post Share on other sites More sharing options...
Kurty Supercharged April 23, 2018 Share April 23, 2018 Where can u get the grease to oil door hinges? Any brands? https://www.wd40specialist.com/products/spray-gel maybe can try this type, gel/grease? personally, i find grease works better as compare to WD40. is there grease spray? ↡ Advertisement Link to post Share on other sites More sharing options...
Who's your favorite lau-chiobu actress ?
Your Choice : Margarine or Butter...................
Your favorite car air fresherner
What u do if your wife doesn't want to make out with u?
ChangeYourFlight.com cancel and refund bookings
What your favourite brand of beer and where to drink
Does your insurance includes coverage for PARF / COE?
