Surf2004 Clutched August 22, 2005 Share August 22, 2005 I've just got a punctured tyre. Will patch it soon. I'll like to know if it's safe to travel at high speed (>160km/h) with a patched tyre because I travel to Malaysia often. My tyres are Michelin Pilot Preceda (205/45/R16). Advice pls. TIA ! ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 22, 2005 Share August 22, 2005 When you say patch, I assume a small nail went into your tire and it is not on the side wall. If yes, personally, no problem with mine. Have it (patch), done it (NS trip). Link to post Share on other sites More sharing options...
Surf2004 Clutched August 22, 2005 Author Share August 22, 2005 It's not on the side wall. Still dun know what object pierced my tyre as I can't see any nail sticking on it. It's a 2cm rupture. Happened at BKE to woodlands last night. Loud bang heard. Going to Stamfordtyre during lunch time to fix it. Hope that it's not so bad that I need a replacement ! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 22, 2005 Share August 22, 2005 2cm??!!! a bit too long for a damage.. Link to post Share on other sites More sharing options...
Teddi Neutral Newbie August 22, 2005 Share August 22, 2005 For safety, change a new one lor. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 22, 2005 Share August 22, 2005 It's not on the side wall. Still dun know what object pierced my tyre as I can't see any nail sticking on it. It's a 2cm rupture. Happened at BKE to woodlands last night. Loud bang heard. Going to Stamfordtyre during lunch time to fix it. Hope that it's not so bad that I need a replacement ! Can a 2cm lobang be patched? Even if can patch, I wouldn't dare to use it at high speed. Perhaps can keep as spare tyre instead? Link to post Share on other sites More sharing options...
Protege 1st Gear August 22, 2005 Share August 22, 2005 I've just got a punctured tyre. Will patch it soon. I'll like to know if it's safe to travel at high speed (>160km/h) with a patched tyre because I travel to Malaysia often. My tyres are Michelin Pilot Preceda (205/45/R16). Advice pls. TIA ! Hi bro, I am using a similar tyre and size as you. Had a puncture and I drove up to NS with speed around 140-160. No prob. But my patch is different. Its patch from the inside with a special patch glue or something. Not the usual method which they push rubber from the outside into the tyre. Cheers!! ↡ Advertisement Link to post Share on other sites More sharing options...
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
