Andrewkb Neutral Newbie April 1, 2003 Share April 1, 2003 I was reading a magazine the other day and came across an analysis of different light weight wheel nuts. One point was mentioned: The effect of 1kg saved on the wheel (by using the nuts) is equal to 10kg saved on the whole vehicle ! Is this true ? ↡ Advertisement Link to post Share on other sites More sharing options...
Arkaneslayer Neutral Newbie April 1, 2003 Share April 1, 2003 i read something similar in torque magazine this month ... 10kg... removing the spare tyre would have a similar effect i suppose. the question is how is the 10kg translate to power gains.. Link to post Share on other sites More sharing options...
GDIzen Neutral Newbie April 1, 2003 Share April 1, 2003 By reducing the unsprung weight, the power can be transmitted to the ground more effectively and less inertia to turn the wheels, hence faster response! CAVEAT: Although the lug nuts would have to be combined with lightweight wheels to make a real difference from the stock rims. ie not much effect if you're using them with heavy rims IHMO. Link to post Share on other sites More sharing options...
Vtim 3rd Gear April 1, 2003 Share April 1, 2003 CAVEAT: Although the lug nuts would have to be combined with lightweight wheels to make a real difference from the stock rims. ie not much effect if you're using them with heavy rims IHMO. yes, your right about that Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 1, 2003 Share April 1, 2003 Yep, you're right.... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 1, 2003 Share April 1, 2003 The more weight you can remove from the car, the better HP/weight ratio and hence better acceleration and top speed... The same concept as the Lotus Elise.... Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 1, 2003 Share April 1, 2003 (edited) Becareful those nuts too, I saw at PG there was a Type R fly its one front wheel to track side and whole car stratched a long line on the track. all becoz of those nuts can catch the pressure and spin mot that strong. Edited April 1, 2003 by Mondeo Link to post Share on other sites More sharing options...
Soya Supersonic April 1, 2003 Share April 1, 2003 "..The more weight you can remove from the car, the better HP/weight ratio and hence better acceleration and top speed..." Like dat means i have to drive naked when i go PG next time. Link to post Share on other sites More sharing options...
Jazziegirl Clutched April 1, 2003 Share April 1, 2003 please tell me when you going to PG naked hoh! that one i MUST see and definitely will bring digicam! Link to post Share on other sites More sharing options...
Soya Supersonic April 1, 2003 Share April 1, 2003 eeeee...so hum-saab. Inside car cannot see lah but i heard less weight oso advantageous in open karting..... Link to post Share on other sites More sharing options...
Jazziegirl Clutched April 1, 2003 Share April 1, 2003 u dem good ah! let u win! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 1, 2003 Share April 1, 2003 Post: eeeee...so hum-saab. Inside car cannot see lah but i heard less weight oso advantageous in open karting..... This, I got to see.. Link to post Share on other sites More sharing options...
French_porn Neutral Newbie October 19, 2003 Share October 19, 2003 me looking fo those light weight nuts. any brand to recommend? or any website to browse to? thks... Link to post Share on other sites More sharing options...
French_porn Neutral Newbie October 19, 2003 Share October 19, 2003 (edited) are the taiwan made ones worth it? i mean are they durable? Edited October 19, 2003 by French_porn Link to post Share on other sites More sharing options...
Ghostling Neutral Newbie October 19, 2003 Share October 19, 2003 Hello French_porn , I had some feedback from my friends about the cheaper nuts. They were saying that the cheaper nuts are more prone to break. They were saying brands like RAYS , ENKKI are better.. By the way , racing nuts should be tighten manually using a torque wrench. Hopes this helps! just my 2 cents worth. good luck! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 19, 2003 Share October 19, 2003 usually the taiwan made one is not so durable... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 19, 2003 Share October 19, 2003 Now the trend is not to use those lightweight aluminium nuts as they will crack eventually if air gun is being used to lossen the nut...stainless steel nut is a better options but they don't come cheap too... Link to post Share on other sites More sharing options...
French_porn Neutral Newbie October 19, 2003 Share October 19, 2003 (edited) what is the difference in the weight between the stainless steel one and the aluminium? and what is the weight of the nuts to be consider lightweight? Edited October 19, 2003 by French_porn ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Hubs
Wheel Hubs
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
P2096 Check engine light
