Rustyz 5th Gear February 5, 2007 Share February 5, 2007 Check ur private Messages ↡ Advertisement Link to post Share on other sites More sharing options...
Ccssgm 1st Gear February 5, 2007 Share February 5, 2007 Link to post Share on other sites More sharing options...
Boyboy 1st Gear February 5, 2007 Share February 5, 2007 there are easy DIY ways to make it softer. the beep is still there so technically i guess it's legal. can always remove the insulation if going for inspection. some old rags/foam and rubber band does the job easily Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie February 5, 2007 Share February 5, 2007 Don't try to tamper with the speed limit device. For you need to go inspection and they will check on it. The easiest way is to place a piece of magnet onto the casing of the speed limit device. By doing that, it actually keep the beeping sound softer. The best part is when u meet with an ROV, just kick the magnet off the casing. And it will goes back to normal again! Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 5, 2007 Author Share February 5, 2007 I also got think of taping up but cant find the beeper hole sia.. Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 5, 2007 Author Share February 5, 2007 mine is not ding dong but beep beep beep and still got clicking sound ! Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 5, 2007 Author Share February 5, 2007 One thing is the device is mounted at the passenger side beside the door and passengers tend to kick the box when getting off the van. Sooner or later the box sure tio kick out !wahahah! Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 5, 2007 Author Share February 5, 2007 Magnet..wow! Din know magnet could soften the beeping. Do I have to get a strong magnet or juz a small one ? Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie February 5, 2007 Share February 5, 2007 (edited) size doesn't matters, it how strong the charges the magnet is. the thing will stop it from beeping. I tried it while working part time for a Electronics Company going to ppl's house repair tv. Most people in the company use magnet to reduce the beeping sound. U need to understand how the speaker works. It uses positive and negative charges to move the speaker to create sound. By putting a magnet nearby, you can disrupt it normal functionality and reduce the sound. Try it and tell me the outcome. I use this method while driving van coz i hate the beeping sound and i always drive above 70km/h... Edited February 5, 2007 by Powerkeong Link to post Share on other sites More sharing options...
Ccssgm 1st Gear February 5, 2007 Share February 5, 2007 If I'm Not Wrong......The Beeper Is at Centre of the Device...... Link to post Share on other sites More sharing options...
Boyboy 1st Gear February 6, 2007 Share February 6, 2007 mine was mounted behind the center console leh (aircon, radio area). no worries abt kicking off, but i only located it during my inspection . after tt then i went to silence it Link to post Share on other sites More sharing options...
Flameevil Neutral Newbie February 6, 2007 Share February 6, 2007 its onli 10km/h difference... unless u speed over the limit all the time Link to post Share on other sites More sharing options...
Nothingtodo 1st Gear February 6, 2007 Share February 6, 2007 So.... U or yr dad must be one of those speedsters that overtake private cars on expressways. Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 6, 2007 Author Share February 6, 2007 I go try then let u know again..gonna use a small magnet to find where the speaker is !hehe! Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 6, 2007 Author Share February 6, 2007 Thou its 10km/h difference but it can be irritating when talking to passenger or listen to radio esp 4D results! Link to post Share on other sites More sharing options...
Gabriel 1st Gear February 6, 2007 Share February 6, 2007 i think mine is @ 75km/h not veri sure though... coz beeping sound goes well with music played... Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 6, 2007 Author Share February 6, 2007 On the contary, I dare not anyhow overtake cars on expressways coz vans' side mirrors are concave in shape and hence cars tend to look farther but in actual fact they are nearer. Vans being taller can be daunting to even travel at higher speed wor..esp vans like Liteace, Hiace etc. During braking, vans are more unstable and tougher to stop at higher speeds..no ABS, no good brakes, no good grip tyres etc and the load U are carrying makes it even harder to brake in time. Heavy braking can make the van "drift ". The rear can slide to one side. For ppl who drove vans are usually the ones who uses the van to make a living..hence I dun think anyone with a sound mind would attempt high speed on roads. If buang, lost of income, pay for damges to the van and worse compensate the goods they are carrying at the time . Link to post Share on other sites More sharing options...
Rollagt 5th Gear February 6, 2007 Author Share February 6, 2007 if the beeping is ding dong like those cab type then maybe its okie..but mine is sharp beeping.whaaha! ↡ Advertisement Link to post Share on other sites More sharing options...
How problematic is VW's 7 speed DSG?
60kmh speed limiters a must for lighter lorries in S'pore from Jan. 1, 2024
Safety or money first?
OMEGA low speed juicer
Emission-cheating devices installed in some trucks and buses in Singapore
Low Engine Oil Warning
