Ckoonyin Neutral Newbie February 26, 2007 Share February 26, 2007 (edited) Dear bros and lao jiaos, have having a problem that is driving me nuts. Basically, i am experiencing this knocking sound when i start my engine whe it is cold especially in the morning. I have went back to the mechanic and they have tightened the belt and lubricated the pulleys but problem persist and i think it is getting worst in terms of duration of the noise. It does goes away when the engine warms up but it comes back again once engine cools done. I have attached a short video clip which i have taken as it is hard for me to describe the sound. Help pls!! p/s: the attached clip is in 3gp format. For those who do not have a player, it can be downloaded here http://www.download.com/3GP-Player-2006/30...4-10613952.html knocking.3GP Edited February 26, 2007 by Ckoonyin ↡ Advertisement Link to post Share on other sites More sharing options...
Wintersonata Clutched February 26, 2007 Share February 26, 2007 I have a similar problem once with my Sonata... after some troubleshooting, it appears be the oil/gas regulator leak or something... just change it and the issue is resolved.. Hope it helps... or it could be the idle pulley ball bearings... Link to post Share on other sites More sharing options...
Aros Neutral Newbie February 26, 2007 Share February 26, 2007 Bro. are you using fully seyn oil ? Link to post Share on other sites More sharing options...
Ckoonyin Neutral Newbie February 26, 2007 Author Share February 26, 2007 yeap, just did my 1k servicing and they are using Shell Helix Ultra. Why leh? Link to post Share on other sites More sharing options...
Ckoonyin Neutral Newbie February 26, 2007 Author Share February 26, 2007 oh but in your case after warming up it is ok? As for the pully ball bearings, you are refering to those which the engine belt is wrapped around? Link to post Share on other sites More sharing options...
Aros Neutral Newbie February 27, 2007 Share February 27, 2007 mine previously got the sound of knocking too, so the machanic suggest to change the engine oil to semi syn. so now the knocking sound is gon't. Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 Could it be the tappet sound??? Some tick, tick, ticking.... Link to post Share on other sites More sharing options...
Trex101 3rd Gear February 27, 2007 Share February 27, 2007 This does sound like piston slap.... I thought only GM car got this type of problem. Link to post Share on other sites More sharing options...
Ckoonyin Neutral Newbie February 27, 2007 Author Share February 27, 2007 Hey guys, thank you for your kind effort in viewing the video. So in summary what I believe that can be done is to change the oil to Semi Syn? Other than that, what else can I do to resolve the problem? What can I tell to the mech to resolve the problem? The hard part is by the time I drive to the workshop, the engine is warmed up liao and no more sound :( Any advise? Link to post Share on other sites More sharing options...
Tangrol Neutral Newbie November 9, 2012 Share November 9, 2012 Hi... sorry to dig up such an old thread.. may i know whether the issue is finally resolved and how... me having same problem for 07 latio... Thanks Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 9, 2012 Share November 9, 2012 Hi... sorry to dig up such an old thread.. may i know whether the issue is finally resolved and how... me having same problem for 07 latio... Thanks why not bring to WS check? Link to post Share on other sites More sharing options...
Watwheels Supersonic November 9, 2012 Share November 9, 2012 Hi... sorry to dig up such an old thread.. may i know whether the issue is finally resolved and how... me having same problem for 07 latio... Thanks Maybe can try using lower temperature and thinner viscosity of syn engine oil eg. 0W30? Link to post Share on other sites More sharing options...
Tangrol Neutral Newbie November 9, 2012 Share November 9, 2012 A bit tricky coz the rattling sound is only for the first 10 sec or so.. After tt no more... Don know how to show WS.. lol. Thinner EO helps? How? Thnx Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 27, 2012 Share November 27, 2012 Could be the oil filled tappet adjusters leaking. Link to post Share on other sites More sharing options...
Tcx607 4th Gear November 28, 2012 Share November 28, 2012 Use mineral oil (thicker oil) - 10-50W for your engine. rule of thumbs, any mileage above 100K should change to mineral oil Link to post Share on other sites More sharing options...
Tripleh 1st Gear November 28, 2012 Share November 28, 2012 I had same kind of problem before. It was the secondary air pump ( smog pump) problem. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 28, 2012 Share November 28, 2012 A bit tricky coz the rattling sound is only for the first 10 sec or so.. After tt no more... Don know how to show WS.. lol. Thinner EO helps? How? Thnx Cud it b yr engine design e top of engine where cams r all oil drain down to sump. U start it takes a few seconds to pump up e oil to cams. Or yr oil filter not original n oil drains out when u park? ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
Spam calls starting from 31290xxx
Marriage registration fees in Singapore to increase
Everything about ice creams
When anything happens…CHANGE CAR!
SCHNELL Engine Oil 5W40
