Vit4wd 1st Gear July 2, 2007 Share July 2, 2007 The Chemlube brochure claims that Chemlube synthetic motor oil uses organic ester which is more expensive at US$3.20 / kg compared to hydrocarbon (PAO) used by other synthetic oils, which costs only US$2.10 / kg. How is Chemlube's organix ester, costing 50% more than conventional hycarbon more effective in protecting the engine? Perhaps, Genie, oue MCF in-house oil expert could shed some light on this? ↡ Advertisement Link to post Share on other sites More sharing options...
Tanjkp Clutched July 2, 2007 Share July 2, 2007 Did it mentioned Chemlube have the highest flashing point ? Did it state that the oil can be used for 25,000 miles/40,000 km or 1 year ? Some prominent names (race drivers) were mentioned in the old brouchure. Honda (KM) was carrying stock in the spare /Acc dept. The oil is selling in 1 litre packing so normally one need to buy 4 pack (4 litres) for most mid size cars. The price I last knew was $16.80 - 17.80 depend on which is chosen to buy W20 - W50. So for the 16.80 a 4 litre purchase is $67.2. Anyway, the price was when I last used it in 2004. Present ride have not phased in to use it as still under AD care. Link to post Share on other sites More sharing options...
Garlic 1st Gear July 2, 2007 Share July 2, 2007 More info and local distributor @ http://www.chemlube.com.my/product.html Its API SJ rating is a little old though as compared to other Ester based oils. Link to post Share on other sites More sharing options...
Garlic 1st Gear July 2, 2007 Share July 2, 2007 I checked out the price a few months back and its very near Redline territory. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 2, 2007 Share July 2, 2007 SJ is obselete for new cars already Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 3, 2007 Share July 3, 2007 even cxxxxxe got SL rating already. SJ is simply too old liao. Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 3, 2007 Share July 3, 2007 dun my car or me but my 2006 getz manual says minimum requirement is SJ but i use SL/SM rated oils la.. usually SJ oils i can only find in malaysian petrol kiosks Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 3, 2007 Share July 3, 2007 Been using this brand since 1994 when my mech intro to me... Tried its gearoil first...and my god...it was damn smooth lor...butt feeling was good. Then used the engine oil...although I did not stretch it to the 20,000mile....oil change was still at 10,000km...but still the engine felt peppy and not sluggish....maybe it could be stretch to 20,000km. Cost is either cheap nor expensive...if you compare just based on the word Synthetic Oil. But again, butt feeling is that its better than most of the oil that I have tried before. I think you can get the oil between 18-19 bucks a quart (almost 1 litre). Those old timer spare part shops at Sin Ming or Bukit Merah (Alexandra Village) would have stocks for it. Link to post Share on other sites More sharing options...
Apollo 1st Gear July 3, 2007 Share July 3, 2007 yup. chemlube really lube lube until shiok shiok. i ran it thru for 30k km though, with filter change very 10k km. still good. oil pressure at end life is a bit poorer. but recommend to do a engine flush before next change becos the oil is really expended. otherwise value for $$. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 3, 2007 Share July 3, 2007 used it on my previous mazzie protege and current ride, able to stretch it to 20,000km without any deterioration of performance. Engine still very torquey. I normally change it after 20,000km. Value fer $$$$$. Link to post Share on other sites More sharing options...
Garlic 1st Gear July 3, 2007 Share July 3, 2007 (edited) Yep, I remember reading an article about SJ oils damaging catalytic converters due to high levels of Zn, P and sulpherated ash, current SM and SL oils contain zinc free additives and and ashless dispersants. Edited July 3, 2007 by Garlic Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 3, 2007 Share July 3, 2007 thats why i feel its better to use SM as it has superior base stock over SL, and less of harmful additives, can make the meow meow last longer Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 4, 2007 Share July 4, 2007 Where you got your stuff for Chemlube ? I lost the number for the supplier...they use to do delivery to your workshop or your home FOC.... Now I get it off the counter at those spare part shops. Link to post Share on other sites More sharing options...
Apollo 1st Gear July 4, 2007 Share July 4, 2007 Beswick Trading 2 Jurong East Street 21 #04-32N IMM BUILDING Singapore 609601, 68961131 Link to post Share on other sites More sharing options...
Bfmstg Clutched July 10, 2007 Share July 10, 2007 now chemlube came with SM for 10w30, 10w40 liao. price slightly higher than older SJ. Link to post Share on other sites More sharing options...
Prata Neutral Newbie July 10, 2007 Share July 10, 2007 with API certification, i.e. the API donut?? Link to post Share on other sites More sharing options...
Bfmstg Clutched July 12, 2007 Share July 12, 2007 su be.. have a check here... http://eolcs.api.org/FindBrandByViscosity....iscosity=10W-30 Link to post Share on other sites More sharing options...
Prata Neutral Newbie July 12, 2007 Share July 12, 2007 bro... the chemlube diester engine oil (that we are referring to) is made by UltraChem Inc.; not by Chemlube International, Inc. besides, based on their data sheet for 10W30, i doubt it's a ester-based... http://www.chemlube.com/PDF02282007/Chemlu...LSAC%20GF-4.pdf you can check out Ultrachem's website here http://www.ultracheminc.com/cat_MotorOils.htm btw, they did mention that they are no longer participating in API certification liao... so i guess their formulation has not changed since their last SJ certification. cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
Mahathir proposes new regional currency based on gold
Synthetic leather car seats
Is your worth just based on that like?
Synthetic Fuels is the future!
Value based healthcare in singapore
Anyone into drinking organic vinegar for health?
Bardahl Synthetic Oil
Have you played in Sand-based Playgrounds before...
